Mirror, mirror, tell me who is the nicest?
Hope with this mod, can keep the heat low on the hood to prevent short life of my paint.
PS: Do you guys put htis in your bimmers?
Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
Seems to me, most of us are alot more concerned with the temps that develop in the area Under the hood, than Over it!
___________________
Paul E
'11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
http://s11.photobucket.com/albums/a173/boostm3/
Thats a teeny turbo.
93' 325iS
2JZ-GTE Powered BMW is complete.
2JZ Powered E36 / 3" Garret Front Mount Intercooler / 3" Exhaust / HKS EVC Boost Controller / Twin Plate OS Giken Clutch / Carbon Fiber Hood / M3 Bumpers and Skirts / M3 LED Mirrors / Euro Taillights / Clear Corners / Euro Ellipsoids / 18" Hamann Replica Wheels / 4-way Adjustable Coilovers / Momo Shift Knob / Momo Milennium Steering Wheel / Alpine Head Unit / Alpine Type X Components in custom Kick Panels / Alpine Amplifiers / Alpine Type R Subs
Originally Posted by MZKozan
Are you Kidding? It's strigth T4 with a 2.5" out let turbine
Exactly... i prefer that the heat is going for the hood, than back to the engine...Originally Posted by paul e
325is 92 non-vanos
AA Supercharger (9.5psi @ 7000rpm)
85mm pulley and new hyperboost DV
Good for the paint on your hood, not so good for your engine.
Whos had a problem with heat from the engine bay destroying paint on the hood anyway?! Start a thread on good ways to vent the heat from under the hood, and youll have alot more interest.. Cept I think there are alot of those threads here already.
___________________
Paul E
With the turbo mounted that close to the hood, it would likely be an issue, but for cars with the turbo located at the bottom of the exhaust manifold, this is not a problem. I've been running my car with the hood padding removed for years and it has been fine.Originally Posted by paul e
In this case, I would have only padded around the turbo area as padding the whole hood with that stuff is going to hold in the heat more.
Or you could wrap the turbo... its a way better solution...Originally Posted by Josh
325is 92 non-vanos
I would think the engine bay temps would be higher resulting in higher coolant temps. I would rather repaint the hood than replace the engine and/or all the associated parts over time.
BBS RC 18X8.5 et13:245/40/18:Koni SA/H&R Sport/M5 3mm Upper Spring Pads/M5T 25mm/20mm Swaybars/Racing King Subframe Inserts/Magnaflow High Flow Cats/Magnaflow Exhaust/3 Inch Tips/Euro Clears/32%Tint/40% on Windshield/6500K HID H1's Headlights and Fogs/Depo Smilies/Factory Shadowline Trim/Shadowline Grill/93 Octane EAT Chip/M5 License Plate Holder/UUC Short Shift Kit/3.15 LSD/ More to Come...
Well guys, let tell you something, the VR4 Mitsu, the EVO, etc etc turboed cars, if you open the hood you will see anm aluminum wrapp just like I have in my hood.
So why a factory turbo car has this thing sticky in it's hood?
Put a louver in the hood over the turbo...
Diego, as Mikea says, your much better off venting the hot underhood temps out .... That will protect BOTH the hood paint, AND the engine bay equipment, and keep things running cooler..... A triple threat attack is Much better than simply insulating the hood.
___________________
Paul E
I have removed even the factory insulation
The E46 compact (maybe others too but I'm not sure) doesn't have anything there. Even the insulation on the E36 is more for sound proofing than heat insulation.
Engineered for emotions
