Results 1 to 16 of 16
Thread: E36 Washers for More Negative Camber?
    Sep 2004
    Canada; Colder than Sweden!
    1993 325i Turbo, 1990 M3
    Anyone put in washers as shims rather than use camber plates for getting more negative camber in the front?
    What thickness of washer would use to get x degrees of camber?
    Nik
    Jul 2001
    F150, Suburban, M3
    Search..................... you'll find a ton of info.
    Social media weaponizes blandness - Sebastian Junger
    Mar 2003
    somers,ny
    ...many have gone the home depot route; but you can call Korman or Turner...they have kits...
    Aug 2002
    West Texas
    many...
    Here's some info i had saved from this board...
    Shim Thickness = Camber Change
    1.16mm = 0.5
    2.63mm = 1.0
    4.00mm = 1.5
    5.44mm = 2.0
    6.81mm = 2.5
    Stock bolt size is M12x1.75x20 (diameter x thread pitch x length) in
    Grade 10.9 (or higher, never less). You want to use bolts 5 or 10mm
    longer.
    Bolts - PN 91310A712
    Shims - page 3008. 12mm ID
    http://www.mcmaster.com/
    Chuck Brazeau
    www.BrazeauRacing.com
    1995 BMW M3 | 2003 BMW 330i ZHP | 2002 Range Rover 4.6
    2008 Ducati 1098 | 2002 Ducati 748s | 2001 Ducati 900SSie | 2008 Honda CBR600RR | 2002 Yamaha Roadstar Warrior
    Milford, MI
    95 325is NASA GTS2
    Quote Originally Posted by niks325i
    Nik
    Hey Nik,
    Getting ready for the season eh? Are you going to the first event at RRX? I'll be there, can't wait.
    There is a lot of info on shims just do a search. Washers should work fine.
    Eric H
    Sep 2003
    Winnipeg
    BMW 325is
    I have a question in regards to the limits of shimming.
    as you know you can generally shim as long as there is tire clearance, however if you look at the bottom of the strut, where it meets the hub, you'll notice a metal guide pin and a hole for it on the strut. This is in the middle of the two mounting points. Can you Shim to the point where that guide pin does not reach or is not secured in the hole?
    I hope you don't need more clarification?
    http://www.realoem.com/bmw/showparts...43&hg=31&fg=10
    Thanks.
    1995 BMW 325is - CAI | JC Chip | M3 Cams | Fan Delete
    Feb 2004
    Fort Collins, CO
    1994 325i, 1999 528iT
    I would say that guide nub is pretty useless. Once you torque down the 3 bolts that hold the strut to the steering knuckle, it ain't going nowhere, imho.
    Kent
    Oct 2002
    Charlotte, NC
    E46iT, MK6 TDi, Z31Chump
    Sep 2003
    Winnipeg
    BMW 325is
    Thanks for the info. I have new M12 bolts (25mm long) on the way with Grade 8 washers.
    If that nub is useless I will add more washers for more camber!
    Sep 2003
    Winnipeg
    BMW 325is
    any other opinions before I shim the hell out of my struts? is that guide pin useless?
    Thanks again.
    Sep 2003
    Birmingham, UK
    M3 3.2 in bits and a 540
    this thread is exactly what i was looking for.. was thinking about correct sided evo top mounts, and a few washers/shims to set the camber.
    the nub isn't much use, i was swapping the shocks on a 3.2 about a week ago, and saw this didn't have the locating pin.
    Giftschrank Projekt
    Jul 2003
    nova
    4 bmw's & a ford p/u
    Quote Originally Posted by tatawaki
    until the top of the tire hits the strut......
    Jul 2003
    Edm, AB
    92 325is, 91 Previa ftw
    is there a write up on this anywhere...I remember seeing one before...?
    Los Angeles County
    328is,xj Cherokee4x4
    i think im going to be shimming my front struts to achieve some more neg camber for the track, has anyone had good luck with this kit from bimmerworld? also, in this exploded view of our strut/hub, do those 3 holed shims go right inbewteen where the bottom of the hub bolts to the hub near fig.3-4?
    clik sig 4 17" tires
    Sep 2003
    Winnipeg
    BMW 325is
    Quote Originally Posted by toopercentmlk
    any kit will work, as long as they are hardened washers, and that you get longer bolts. I picked mine up from a hardware store.
    your placing the washers in between the strut and spindle. giving the 'shimming' affect. the bottom of the strut will be more outward than the top giving you more camber. its easy!
    Feb 2004
    Fort Collins, CO
    not quite. the strut isn't moving when you add negative camber this way.
    when you add the washers between the bottom of the strut and the spindle, you are 'kicking out' the bottom of the spindle/hub/wheel combination while leaving the top of the spindle/hub/wheel combination unchanged, thus more negative camber. the position of the strut in space should be unchanged.
