Results 1 to 15 of 15
Thread: how to run a wire through the firewall???
    Aug 2003
    Huntington Beach, CA
    M3's = Sold..for now
    im posting this for my bro so i dont know exactley what hes doing..he just yelled up to me to post this for him..i think its for one of his gauges, he has to run a wire and he cant figure out how to get it thru the firewall.. help:
    Nov 2003
    madison, WI
    89 325ix, 85 eta
    (not laughing at you, but funny post....)
    yell down you can go through a hole under the carpeting below the glovebox or i think there is a space to go through near the steering column.
    Hold on let me get my laptop and read this on the toilet.
    --DrDub
    Nov 2002
    So.California
    1995 M3
    You want info on a method or a routing?
    Aug 2003
    Quote Originally Posted by Balthazarr
    just a spot to go through
    Feb 2004
    NC
    05 Yukon Denali,01 MB s430,99 Tacoma,95 M3 Turbo
    Heres a pic of the spot to run the wire through .
    1995 M3 Custom Turbo, Turbonetics T66 BB,72lb injectors, Sias Tuning PnP Tec 3, IBM T30,PLX M250 wideband O2 sensor,Blitz SBC-iD Built low CR 8.5:1 motor CP Pistons,ARP head & main studs,Metric Mechanic HP Valve springs,walbro 255hp,BMP FPR,Modified fuel rail # 6 SS feed line,3in ss custom magnaflow exhaust,Lower level turbo intake,AA six puck disc, Spec Stage IV PP ,AA differential bracket,AA strut tower brace,UUC UD Pullies,UUC short shifter,UUC tranny mounts,UUC clutch stop,Fluidyne HP radiator.M3 LTW wheels Est..1001 rwhp!
    Http://members.cardomain.com/bassmasterM3
    (DIY custom turbo)
    Jun 2003
    HB, CA
    95 M3
    Quote Originally Posted by Bassmaster
    did you have to drill that hole? and for some reason i cant locate that on my car althought i know the area right where the pic is at. I just wanted to simply run a thin wire (18gauge) thru the firewall. need at little more info then just a point tho like what do i need to remove to get to the hole and what not (if that makes sense). um yeah any help is appreciated though right now i just have some wires sittin in my cabin waitin to be routed.
    Nov 2002
    So.California
    1995 M3
    I would say look for the grommet where the throttle cable goes through.
    I think 18 gauge would fit.
    Dec 2001
    Sacramento, CA
    '04 GT3, '04 Lexus GX470, '92 Toy 4x4 ("Pablo")
    From memory ( while back), there is a hole under the glovebox area carpet, against the firewall. You will need to pull back the carpet. On the drivers side there is really only two options that I could find. 1, steering cloumn gromet, 2. fuse box gromet (this will require you to pull out the fuse panel (in the engine compartment) to get to the wire).
    1995 M3 (sold)
    1997 M3/4 (sold)
    2004 GT3
    2008 E90 M3 on order -- week 23 build -- DCT and 19's!
    Aug 2002
    Southeastern U.S.
    Yes
    If you have an automatic, there's an oval-shaped hole a few inches above the socket for the clutch stop. I presume that it's usually occupied by the clutch hydraulics on a manual.
    Jun 2003
    HB, CA
    95 M3
    i have a 5speed. im going to try to find that hole under the carpet i guess. that seems to be the easiest of the bunch so far.
    Orlando, FL
    1995 BMW M3
    Hole thorugh firewall
    you should probably use an existing firewall hole since it's sealed with paint rather than drill your own.
    Just tap through the existing hole's plastic plug.
    <a href="http://madlinux.com/bmw.htm"><img alt="Rasse mich nie" border="0" src="http://madlinux.com/sucko.jpg" /> </a>
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    Bass... Is that hole drilled, or does it exist, or was it used by a screw? Is it Driver or Passenger side?
    ___________________
    Paul E
    '11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
    http://s11.photobucket.com/albums/a173/boostm3/
    Jul 2003
    nova
    8 BMW's & a Ford p/u
    passenger side footwell, up behind the glove box, all the way to the side of the car is a rubber grommet with a number of unused holes. easy to see if you look at it from the engine side. look under the "tray" for the positive battery post.
    Jul 2004
    Texas
    13E70X5M
    This is another option....on the driver's side, under the dash where the cables run through the firewall and into the fusebox, there are these round semi-punched divets in the plastic. I used a sharp pointed object to punch holes around the diameter and then used a tiny flathead to finally punch it out completely. I ran wires through there and into the fusebox compartment.
    EDIT: Oh, the picture shows the sharp punches I made around the diameter of the circle. Another round untouched divet is shown below and to the left of the one I modified.
    jjr
    Oct 2022
    USA
    Z3
    Sorry to bump this from way back, I feel it may possibly help others. I just wanted to say THANK YOU, Argento, for your comment about the plastic semi-punched holes on the plastic behind drivers side footwell.
    Spent a LOT of time trying to get a wire through the factory harness opening on my 2001 Z3 but just wasn't going to fit, and I didn't want to damage anything. (Basic dashcam fuse-tap type application.)
    Almost through in the towel until I saw those punches and found your post. I'll be cancelling my installation appointment and spending more time with my family flying in for Thanksgiving. Thanks a million sir.
