Results 1 to 2 of 2
Thread: dasc upper rad hose
    Mar 2003
    Pennsylvania
    93 318is
    dasc upper rad hose
    i was wondering if anyone has found an upper radiator hose that fits better than the one supplied in the kit? (m42)
    i measured it with the hood closed, and it is about 1/2" from the bottom of the hood. that shouldnt be a problem, but it would look better if it was lower. anyone have any problems with air because of it being higher than the top of the radiator?
    Nov 2003
    Los Angeles, CA
    '04 M3, '95 318, '03 R6, RIP: '99 318TI, '01 M3
    Oem 318
    Quote Originally Posted by J37X
    You can use the OEM 318 hose with some modification. You need to cut about a half an inch off one end to have it clear the pulleys.
    -Chad
