Starting out the mirror looks like this:
To argue with a person who has renounced the use of reason is like administering medicine to the dead. ~ Thomas Paine
You can safely assume you've created God in your own image when it turns out that God hates all the same people you do. — Anne Lamott
Custom watch straps for sale
FOR SALE: watch straps!!
E36 DIY: My articles are now located in the E36 DIY page
Now go to the inside of the door panel and locate the plastic cover at the front corner of the door.
Insert a flat head screw driver carefully between the rubber window guide and the plastic cover piece. Apply gentle pressure, pushing the plastic piece towards you.
There are three plastic snaps that hold this in place and you want to gently release each one.
There is a plastic clip that holds the plastic connectors for the wires. Pop the wires out out of this.
With the cover removed the inside of the door will look like this:
A 10mm socket will be required to remove the 3 bolts holding the mirror in place.
While you are removing the last bolt, be careful not to let the mirror fall or scrape your paint.
Now, just press out the rubber grommet that the wire goes through and the mirror is free.
The mirror after it is removed
These are the tools I used:
Afterwards your door will look like this:
Hey I bought some M3 mirrors a few weeks ago. When I install them, do I have to take the door panels off or not?
Nope....I just happened to have already removed them.
Hey old skool - thanks for doing this.
BigBilly
1987 M6 Cinnabar Red (I think) / 2014 M5 Alpine White / 1998 328iC - sold
Hey everybody - it's been a while. Glad to see BF.com is still thriving.
Any pointers on care and feeding of an E24 are appreciated.
great writeup. very easy
anyone know of a DIY or thread describing using your existing non-M mirror motors in an M style mirror?
1998 E36 Euro M3/4/6 Aegean Blue/Ox Blood
2003 E46 M3 AW/Bl - sold
1997 E36 328i AW/DG - RIP
check the 3 series DIY FAQ at the top of the forum. I know people have done it. You have to pop the glass off first which can be a little tricky to do it right and not break it.
This was a great help for me, thanks
Replaced my broken mirrors, thanks for this...
How do you remove the mirror glass from the mirror housing on a 2002 330ci coupe? (Without breaking it)
good thread
Thanks for posting this Old Skool ! I just replaced my shattered housing
Thank you for the pics & instructions. My garage got narrower this weekend.
Rhinos57
I purchased power M3 mirrors to put on my 318is, but it seems that the wiring doesn't match or work no matter what I do. The instructions state that Green & Yellow (Left & Right); Green & White (Up and Down) But even though I tested the power of the current system, I can not get it to work. Any suggestions?
