Couldn't wait any longer. The coupe is quick, but there are too many Porsche Turbos around my way that need a wake up call.
I purchased a used SQ2 Vortech ERT kit. I will be getting it this weekend.
Water injection will be following shortly behind to keep the power up on the hot days.
Anyway, it will be nice to have boost again!!!:
2013 MCB F10 M5 BMS
2014 Rubicon
2007 997 Turbo
2011 C6 Z06
2007 Shelby GT500
Are you OBDII? Then, would that be the kit which uses the stock injectors and software, and only uses a rrfpr to supply the extra fuel required? Ive wondered, how is it that, without a device to rescale the HFM, all the extra air flow under boost, which far exceeds stock limits, ie 5.0v out of the hfm, doesnt trigger CE lights?
___________________
Paul E
'11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
http://s11.photobucket.com/albums/a173/boostm3/
allright Greg, I knew you couldnt stay away after you had a taste of it in your red demon!!
what kinda kit did you go with?
RENNtech 168mm Pulley and Tune | VRP Carbon Fiber Airbox | JP Shorty Headers | Eisenmann Race Exhaust | RENNtech Digital Lowering Module | 19" HRE 547R
459 RWHP, 522 RWT
Thanks for the support guys!
Psk 145 - You know I miss having the red M3's top end pull!
I would have to say the M coupe would be right up there stock till about 120 mph! After that the supercharged M would really spool up!
Regarding the kit, it comes with 36lb injectors but I will have access to 24s as well. The kit runs the stock HFM for OBD2. I will mix matching a few parts with a friends kit to make things optimal. Since the kit was designed for an OBD1 car, I will need the inlet pipe from a friends RMS OBD2 kit. The rest should be gravy...
Will be shooting for 8psi of boost with the water spray.
I will be sending my DME for reprogramming to accomodate the need for more air, fuel etc...
Oh yeah!
2013 MCB F10 M5 BMS
2014 Rubicon
2007 997 Turbo
2011 C6 Z06
2007 Shelby GT500
Nice GREG!! Damn.. ur SC again! SiCK!
06' BMW 530xi
02' Porsche 911 Carrera
11' BMW X3
Willy,
Got to keep up with the Jones'!
2013 MCB F10 M5 BMS
2014 Rubicon
2007 997 Turbo
2011 C6 Z06
2007 Shelby GT500
Welcome back to the wonderful world of getting blown, Greg!!
Greg, so youre installing the OBDI ERT kit on your OBDII application...from what I understand, the OBDI kit was much better equipped than their obd2 one...Thats why I thought you only had a rrfpr to work with. If I may ask, who are you sending your OBDII ecu to for reprogramming? Since youre really making up your own kit out of some OBDI and some OBDII parts, wouldnt the tuner have to have your car their on the dyno in order to tune it properly? Without actually seeing the results of your HFM signal at part and full throttle, plus many other sensors, I dont know how accurately they'll be able to tune you...Let me know...thanks.I will be sending my DME for reprogramming to accomodate the need for more air, fuel etc...
___________________
Paul E
hey greg.. where are u getting the software done?? Im looking for software also.
06' BMW 530xi
11' BMW X3
Probably just go for a stage 1 OBD2 burn. I won't be HP crazy at first, as long as things aren't lean.
May be sending the DME to Karl at AA. Not sure yet. A friend knows him well, so I may go with him. I've read great things about him, so I feel confident that he would do the right thing.
Again it's a project...
My car goes in next week for a bunch of warranty stuff, so I will wait till after to strap the boost on. Though it's a friend working on the car(who's a member here), if a rep shows up, they get all bent out of shape when they see the blow dryer tucked under the bonet.
2013 MCB F10 M5 BMS
2014 Rubicon
2007 997 Turbo
2011 C6 Z06
2007 Shelby GT500
Damn noone has software for a 328 I can get my hands on.
06' BMW 530xi
11' BMW X3
William,
Have you spoken to Karl? You may also want to call Osh Kosh Bigosh... How hard would it be for you to convert your car to a obd1 325 setup? Is that even possible?
2013 MCB F10 M5 BMS
2014 Rubicon
2007 997 Turbo
2011 C6 Z06
2007 Shelby GT500
It'd be pretty simple to convert to OBD-1. Then, just have someone burn a chip for your motor. Then, you could go to bigger injectors rather than just running your injectors into static duration...
BTW, Willy, what are you using for a MAF clamp? or are you?
