Results 1 to 10 of 10
Thread: Self-Leveling E34??
    Hanford, California
    '94 BMW 530i
    Self-Leveling E34??
    Looking to get a set of lowering spring for my 94 530i, and all the vendors that I check, have a set for it, however all of them say they are for E34's Except Self-Leveling versions. How would I check and see if I have self-leveling. I dont wanna pick up a set of springs and have them not fit. thanks
    seth
    Apr 2002
    Bay Area, CA
    E90, E34 (retired)
    from this post http://www.bimmer.info/forum/showthr...light=leveling it seems self leveling in tourings were eliminated in '94.
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Self leveling was standard equipment 1992-1993 (525iT)
    then it was discontinued in the 525iT for model years 1994-1995.
    The 530iT debuted in 1994, and LAD (rear self-leveling) became an option for the V8 (530iT) in 1994-1995...so some may have it and some may not.
    The Tourings that have LAD will have a metal power steering reservoir that uses Pentosin CHF 11 S....which should be engraved into the reservoir's lid or on a sticker. Tourings with a regular suspension will have a smaller black plastic power steering reservoir that uses ATF (at least my 95 525iT does).
    The only other e34 5 series that had rear self leveling was the M5.
    Hanford, California
    '94 BMW 530i
    Beauty! So it seems only the M5 and the touring E34's have the sefl-leveling. Looks like my bank account is gonna take another hit today. Thanks guys
    seth
    Apr 2017
    Lusaka, Zambia
    1994 BMW 530i V8
    So many years passed the last comment but...
    Quote Originally Posted by Qsilver7 View Post
    I have a 1994 530i that I got for a project and surprisingly, it has a reservoir that says chf 11s ONLY. I got it, it had ATF in it and after a few kilometers, I would get a stiff steering and I assumed it was due to the ATF. Questions are:
    1. Is the car likely to have auto leveling suspension?
    2. How else other than from the stiffness and the reservoir caps can I know whether it has auto level or not?
    The power steering pump its using is #2105980 and needs replacement. Can I replace with a non-self leveling one?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    A E34 530 V8 limo usually does not have a SLS, you can easily see that when you look at the shocks, there goes a hose to the shock and the SLS shock looks like this http://forum.bmw5.co.uk/topic/119369...veling-shocks/
    Maybe you clean the filter and change the power steering fluid.
    Great White North
    various
    There were also a number of cars that got various pumps and fluid despite not having SLS, almost like bmw were emptying the parts warehouse at the end of the E34's production.
    Wisconsin
    '95 525it
    Quote Originally Posted by zubbie View Post
    Yes, my '95 540i, build date 10/94, specs CHF11s in its steering system.
    ATX
    Sundry old Grrrrmans
    ^I haven’t found rhyme or reason, but can confirm a strange couple different combos of model year/PS fluid. It does seem that most ‘95 540s spec the fancy stuff, however.
    - Brent
    www.angry-ass.com
    Quote Originally Posted by danespann View Post
    Every E34 needs the same things in the end.
    Jan 2017
    Carrboro, NC
    '91 525i (5sp)
    My 10/90 525 has the CHF sticker...
