hey all!
i just got some wheel and tire care package from Costco. well i was reading the back of the wheel cleaner can and it says to try it in an inconspicuous area first... does that mean the product can mess up the wheel finish? my M68s are not that hard to clean and i can get them clean just by wiping the dust off, they feel Teflon-like to the touch. is it a good idea to use products like that or should i just stick to auto-shampoo?
how do you keep your rims clean?
also, has anybody had any bad experiences with a touchless car wash?
nevermind the finish, just scratched the sh|t out of one of my brand new rims at the "touchless" car wash............
i'm an idiot, shouldn't have been there in the first place. from now on, i'll wash it by hand ONLY...
Only you should touch your finish.
Sorry to hear about your unfortunate accident.
All wheel cleaners are either Acids, or an Alkaline/base product either way if you have aluminum uncoated wheels you can get them screwed up, or they do not have a clear coat they can get screwed up. Picking a wheel cleaner is a very tricky thing.
Yeah, Hype's right.
I wash my wheels with car wash soap and water, same stuff I use on the body of the car. I dry them thoroughly, then I put a nice thick coat of pure carnuba wax on them. Make sure it's 100% pure carnuba wax with NO CLEANERS ( like Meguiar's #26 Paste wax).
Remove the wax like you would any wax, should protect the finish for a while. And each time after that when you clean your wheels, just use soap and water, they'll clean right up and be protected.
Silver is right. The paint on your wheels is similar to your car's paint. A good coat of wax will allow you to clean them with soap and water. A couple of tips...
- Keep a different cloth or rag for washing wheels only. You don't want residual brake dust dragging across your hood.
- Don't forget to dry your wheels.
- Be sure to clean the inside of the wheel too. I've seen too many that were ruined because the brake dust ate thru the wheel in the back and stained them black forever.
Nick
Current: '07 VW Fahrenheit GTI; 2010 BMW s1000rr
Past: 2003 M3, 6M, Steel Grey, Koni Yellows
2012 Triumph Thruxton
1995 M3, Cosmos on Black Vaders
1993 325i Sport and Cold weather (limited slip!) packs, 5M
Carnauba is so nineteen-hundreds.....
I use an acrylic application which I also use for wax on my car. It works pretty good.
Even though the wheels are clearcoated like your paint, they get much hotter than the body and wax melts away. So its not as effective. I use a teflon "wax" like Eagle one for the wheels.
By the way, a great wheel cleaner (although pricey at $15/bottle) is P21!!!!
What would Crockett and Tubbs do?
1994 E36 Hellrot/Black 325is
2007 E92 Jet Black/Saddle Brown 335i
NEVER use car wash! scratches the hell out of the paint!! Grab some good wheel cleaner, for my aluminums i grab a nice set of metal polish to finish it off!
I first soak my wheels with diluted purple power that gets all the brake dust going then rinse and after im done washing the car I clean the weeks with a different sponge and then I use spray ultimate quick wax. I know its not recommended but I had great results. it also helps that I have a low dust brake pads.
Current
-1997 BMW M3 4Door Artic Silver w/ Black Interior Daily
Past
-2001 BMW 325i
-1999 BMW M3 Vert White
-1981 VW Rabbit Pickup (Caddy) 2.0 ABA
"I don't care if the door gaps are straight. When the driver steps on the gas, I want him to shit his pants." - Enzo Ferrari
First I spray down my wheels and tires with water as I'm spraying down the rest of the car, then I spray a good amount of Simple Green on them and wipe them down, then I make sure the sidewall is clean before applying my Sonax tire shine. They always look immaculate afterward.
Current
Past
-2001 BMW 325i
2002 M3 Journal
I use Mother's Ultimate Detailer with a microfiber almost exclusively on my painted 17" Borbet's. It always works great but I never let them get that dirty.
