Front bumper (M3)
sideskirts (M3)
97+ nosepanel
A pint or so? I need to call the paint shop soon so how much should they make? I've already got plenty of reducer, primer and clear. And that flexicrap too. It's granite silver metallic if that makes any difference.
When I did my skirts and shot the greys on my front and rear bumpers, I mixed an entire quart.
When I got done, I ended up pouring the rest of the paint I did not use back into the quart can, which almost completely filled it up.
Mix ratio was 50% reducer to base paint w/harder added.
Hope that helps.
If you're doing base/clear then a pint should be fine. You don't have to have build with it, just enough for even coverage.
which color do you have ?Originally Posted by hammdy
E36 325I EURO MODEL
M3 ORI MIRROR'S
M3 ORI DOOR MOULDING'S
M3 ORI FRONT BUMPER
M3 ORI LIP SPOILER
M3 ORI REAR BUMPER
M3 ORI REAR BUMPER DIFUSER
M3 ORI SIDE SKIRTS
M3 ORI 17" WHEEL'S
M3 STREEING WHEEL HALF LEHTER/WOOD
VDO GAUGES PANEL
HARDTOP
HARDTOP LIFTER
BILSTEIN SHOCK'S
BREMBO DISC'S
SUPERSPRINT END'S
ORI CLEAR LIGHT ALL AROUND
K&N PANEL FILTER
Euro Angel Eye Headlight Kit(BLACK FINISH)
CHIP
INSIDE ORIGINAL WOOD FINISH
MB QUART 325.02 COMP+SOUNDSTREAM AUDIO SYSTEM.
Also e38 model and E39 model
it a QT. Don't knock the flex agent !! I wish I used it on my nose and will be spraying again...
Bob
OK a pint it is. Thanks guys!
granite silverOriginally Posted by Bmw325IAC
That's paint hammdy, NOT beer!Originally Posted by hammdy
Just thought I'd slip that in to make sure you didn't get them confused...
I only buy beer in pint X 30 form.Originally Posted by Seeker
