First...
I'm not starting this thread to spark a safety debate.
I just wanna know if anyone has comepletely removed the passenger
airbag and how to go about doing it.
I have seen all the threads about changing out the steering wheel.
I havn't seen write ups on the passenger side.
You have to remove the dash then it's pretty easy from there. It's bolted to a cross-member underneath the dash which you just take out a few bolts and unhook some electrical stuff.
2 bolts 2 wires 2 minuets
just dont lay underit when removeing it couse it will fall on your head
(dont ask how i know)
by the way anyone wanna buy an airbag? i got both
So I took out the passenger side...
Piece of cake.
Then went to remove the drivers side...
It appears that it is actually part of the steering wheel cover.
Am I correct in assuming this?
It said on the contraption "DO NOT ATTEMPT TO DISASSEMBLE"
So I didn't.
Where can I go from here?
