Results 1 to 11 of 11
Thread: Transmission fluid leak
    Mar 2002
    Aliso Viejo, CA
    99 323i
    Has anyone had transmission fluid leak from the 2 threaded holes in the center of their transmission?
    steve
    95 M3
    [IMG][/IMG]
    Mar 2002
    Aliso Viejo, CA
    99 323i
    here's the correct link to the pic.
    http://www.dtmpower.net/ppost2/water...CF0030-med.JPG
    steve
    95 M3
    [IMG][/IMG]
    Feb 2004
    Ozarks
    E70 X5D & R56 MCS
    Im having the same d@mn problem right now. Im worried that its going to get onto my clutch and cause it to burn up Im so pissed at my car right now.
    Have you found a fix yet?
    -Kyle 1995 Custom Turbo M3 SOLD!
    Jul 2001
    San Diego
    whatever is there
    thats a drain hole. could be ur rear main seal. and for the standard trans to leak is not as common. if thats what it is pull it out. put a new front gasket on it, and a new rear main, make sure u get hte dealer 1 which comes w/ the tool.
    This shop ripped me off and they'll rip you off too!
    ~~~> Autobahn EBAY ID: 1autobahn1
    444 Vernon Way, El Cajon, CA 92020
    619-444-2290
    Feb 2004
    Ozarks
    E70 X5D & R56 MCS
    its a 5 speed.. Im not looking forward to pulling the tranny out again.
    the rear main motor seal has already been replaced like 50 miles ago
    Feb 2004
    Ozarks
    E70 X5D & R56 MCS
    when you say rear main seal your talking about the tranny rear main seal correct? bc I already replaced the rear main in the engine.
    Jun 2003
    Vancouver, BC
    1997 M3
    Possible leaks from that area are the rear main on the engine (you already replaced) and an input shaft seal on the transmission.
    Jul 2001
    San Diego
    whatever is there
    maybe u didn't put it in correctly
    619-444-2290
    Feb 2004
    Ozarks
    E70 X5D & R56 MCS
    Im sure I did and Its not motor oil leaking its tranny fluid wich would have nothing to do with the rear main on the engine.
    Mar 2002
    Aliso Viejo, CA
    99 323i
    it ended up being the input shaft seal, obviously the tranny needs to be dropped. do your self a favor and do the output shaft seal at the same time, the output shaft seal wasn't leaking but it was about to.
    steve
    95 M3
    [IMG][/IMG]
    Feb 2004
    Ozarks
    E70 X5D & R56 MCS
    I have taken the tranny out but have yet to take the seal out. where is the output shaft seal and which exaclty is the input shaft seal? I can see a seal right when you take that black plate that the throw out bearning rest on but I cant take it out.
