Bimmerforums Upgrade Garage The Tire Rack
Page 6 of 152 FirstFirst 123456789101112131415163156106 ... LastLast
Results 126 to 150 of 3780
Thread: PLEASE READ BEFORE POST: The ultimate wheel/tire fitment thread.
  1. #126
    Jun 2005
    SOUTH FLORIDA
    2001 330CI
    Jim,
    One more question. You said around 40mm. I found these Sizes: 18" x 8" ET 35 & 18x9.5" The ET is the offset? If that's the case, is 35 still too low?
  2. #127
    Jan 2005
    Flushing, NY
    2000 328CI
    Still a relative noobie. I am looking to upgrade to 18's on my 2000 328CI. I saw some rims online that I'm looking to get.
    Style 71
    18x8 47mm offset in front
    18x8.5 50mm offset in rear
    Will those fit on my car?
    Also, I would need to get tires for them. I've heard 225/40/18 for the fronts and 255/35/18 on the rears. Does that sound right?
    Sorry for the basic question, but thought I'd try my question on this thread.
    Thanks in advance.
  3. #128
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The tire sizes you mention would be correct but a 50mm offset may need a spacer to kick the wheel out a little.
    If I can help let me know.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  4. #129
    May 2001
    Denver, CO
    2013 335i xdrive msport
    Okay Jim help me out here:
    18x9 front
    18x9.5 rear
    225/40 is too stretched out front and 245/35 is too stretched out back....i was thinking
    235/40 out front and 255/35 out back, is that possible?
    ~Chris
  5. #130
    Oct 2002
    Columbus, Ohio
    99 M Coupe
    [Fitment on a M coupe]
    Will a 18x9.5 ET25 fit a 99 M Coupe rear if I add a 15mm spacer? It normally has a 8mm offset. Thanks for helping a newb understand this offset stuff.
    Z3 Registration Database
    Mods Done: ESS/RMS/Custom Vortech V2 S/C Kit, Aquamist 1S Kit, Spal 16" Fan, 18" BBS RG-R w/red center caps, Engine Fan Delete, ///M logo Chrome Oil Cap, Imola Red Roundels, Clear Front Marker Lights, ///M Badge below Rear Oddments Box, ///M Valve Stem Caps
    Mods Next: City Lights, Silver turn signal bulbs, Front CF Splitters, CF Sunroof, Sport Gills, Chrome Light Switch, Chrome Kidneys, Central Lock button, Paint Imola Red (Washer Nozzles, Rear Spoiler, Door Handles, Engine Cover)
    [/font]
  6. #131
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Neither of the sizes are stretched on those wheels. You are within spec on all of those tires. I think the tire sizes you list may work but you may have to roll the fender lips as well. I do know that the 225/40R18 and 245/35R18 will fit with no modifications.
  7. #132
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Cozog, I think the wheels will work even without the spacer. I would think at the most a 10mm spacer would be all you would need and you could still be hubcentric in a 5mm spacer.
  8. #133
    Jun 2005
    SOUTH FLORIDA
    2001 330CI
    Maya STM 19s??
    Jim,
    Found something I'm really digging. Looking to put the Maya STM 19's. Can I go with a 19 x 9 or 9.5 in the rear? What tires size should I go with?
  9. #134
    Aug 2002
    South Bend, Indiana
    BMW 525I
    It would depend on the offset of the wheel and the size tire you use.
  10. #135
    San Diego, California
    2/91 Build NVM50
    Would a 255/35 be a better bet than a 265/30 on a 19x9.5 rear wheel ?
    38 offset
    This is on a E36 325i
  11. #136
    May 2005
    Bay Area
    E36/4
    I just bought some 18x8.5's +41 with 235/40/18's. I saw pics of them mounted on an E36, but can't get them to fit on mine. I have a '97 M3 Sedan, stock springs, and the new Bilsteins. I even tried mounting them w/some make shift spacers just to see if it would fit and it didn't. I spaced them out ~15mm. The problem I'm having is that they are hitting the front strut assembly. How are you guys w/18's on E36's getting them to fit w/out contact?
  12. #137
    Jun 2005
    Indiana
    1997 m3 sedan
    Quote Originally Posted by jt94130
    I'm interested to know too... I also have an M3 sedan in desperate need of new wheels.
    -Jim I'm about 45 minutes from you in valpo, sooooo if ya need a guinea pig let me know....
  13. #138
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I think the problem may be the 235/40R18 size. These are taller than the OE tires by 1/2" and may be causing the rub at the top. If you go with the 225/40R18 you should be fine.
  14. #139
    May 2005
    Bay Area
    E36/4
    At ~$200/tire, I don't know if I wanna spend that much....but do you think a 245/35/18 would work instead of the 225/40/18? I really would like to have a tire that isn't stretched on the wheel. I'm also asking cause I'm afraid if I buy the tires and they don't fit....I'll really be f!cked. Thanks again.
  15. #140
    Jul 2005
    Colorado
    1989 325is
    AutoX wheels for an E30
    I've got an '89 325is I want to AutoX and I want to put the widest wheels I can get away with underneath the car (which will be lowered). I've been looking and it seems that 15x7 is the way to go for an E30. This wheel sounds like the best choice short of dropping a small fortune on SSRs. My question then is this: what's the fattest tire I can put on there? Falken should have a 225/50R15 version of the RT-615 by the end of the year and I was hoping that would fit on a 7in wide wheel. Thanks in advance for any help.
  16. #141
    Jan 2005
    Flushing, NY
    2000 328CI
    Hey Jim. Thanks for all the advice. In this era of 'Buy first, ask questions later,' I went ahead and bought those rims:
    Now, call me neurotic, but these rims came off a 330ci and I have a 2000 328ci. On your website, it says that the 2000 328ci will only fit 225/40/18f and 245/35/18r. But the 2001 330ci that these rims came from will fit 225/40/18f and 255/35/18r.
    Will the 245/35/18 on the rears fit these rims that are supposedly for 255/35/18? Or does it not matter?
    Sorry for asking an amateur question, but before I go ahead and shell out $800-$1k on rubber, I'd just like to have the peace of mind!!
    I'll be contacting you about tires.
  17. #142
    Sep 2004
    va
    no more e36 m3; 98 Altima now
    Jim,
    This is for a buddies 97 740i. Looking at the Breyton Spirit black w/polished lip. Any fitment problems or needing use of spacers if we go with the 19x9, 18 mm offset front with 245/40/19 and 19x9.5, 18 mm offset rear with 275/35/19?
    98 Nissan Altima 14.3@94mph
  18. #143
    Jun 2005
    victoria
    320i
    wut would fit on my 1993 320i
    bolt pattern?
    wut offsett can i have?
  19. #144
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The 19" stagger will fit with the 245/40R19 and 275/35R19. You may need to roll the rear fender lips though.
  20. #145
    Dec 2004
    New Zealand
    88 Facelift E30
    I'm not 100% sure of my offset, as I've been told quite a few but basically the car is a 1988 BMW 320 E30.
    Has 14" Bottlecaps which I measured to have roughly a 35mm offset.
    Now im wondering whether or not the following description of a mag would work on my car.
    17x7 Mag
    4x100 offset (same as e30)
    38mm offset. (can use 3mm spacers can I not)
    they are fantastic looking mags, so would be keen to try and make this work if atall possible.
    Cheers Andy.
    Representing the crew of BMW Enthusiasts from New Zealand.
    www.bmwclub.org.nz
    1988 BMW E30 320 i Facelift Diamondswartz metallic - E30 Spec Series Race Car.
    1999 BMW E46 318 i Touring Hellarott
    Previously
    1989 BMW E30 318 i Facelift Atlantisblau Mtech II
    1995 BMW E38 730 iL Ascot Green
    1996 BMW E36 318 ti Montreal Blau metallic
    1996 BMW E36 318 i Cosmoswartz metallic
    1991 BMW E30 320 iSE Alpine Weiss
    1989 BMW E30 318 i Facelift Zinoberrot
    1988 BMW E30 320 i Facelift Royalblau metallic
    1989 BMW E32 735 i Sterlingsilber Metallic
    1982 BMW E21 323 i Lapizblau
  21. #146
    Aug 2002
    South Bend, Indiana
    BMW 525I
    You would need more than a 3mm spacer. With a 38mm offset you are going to need a 10mm spacer.
  22. #147
    Jun 2004
    Va. Beach
    '03 540i Msport
    e30 tire questions
    I just got some Ronal ls rims and need new tires for them. The car (e30 325is) is a daily driver (no track days) but I like to drive "spirited". good wet/dry traction and decent tread life. Looking at the +/-100$ range thanks for the recomendations.
    Here is a short list of possibilities
    Falken Ziex ZE-512
    BF Goodrich g-Force Sport
    Yokohama AVS ES-100
    Kumho Ecsta 711
    Nitto NT 450 extreme performance
    Toyo Proxes 4
    Anyone with experience with any of these?
    Thanks in advance
  23. #148
    Dec 2004
    New Zealand
    88 Facelift E30
    Toyo Proxi's
    Cheers Andy.
    www.bmwclub.org.nz
    Previously
  24. #149
    Dec 2004
    Gilroy, CA (USA)
    1999 BMW Z3 Roadster 2.3
    Question What OEM wheels are these and will they fit 95 325iC w/Sport Package
    Picked up a 95 325iC and discovered that 2 of the standard 10 spoke (5x2) OEM wheels have flat spots on the outer part of the rim. So I am looking to replace wheels but am funding challenged. So I am keeping my eye on eBay and I found a set of 4 16x7 BMW OEM wheels with the stock 46 mm offsets. Here is the description (I also attached a picture):
    SIZE: 16 X 7 J WITH A 46 OFFSET
    LUG PATTERN: 5 ON 4 3/4
    CONDITION: PLEASE REVIEW PHOTOS
    WHAT THEY WILL FIT: SHOULD FIT ALL BMW 3 SERIES BUT CHECK WITH DEALER
    So first, what are the wheels called, are they maybe from a Z3 and would they fit my E36?. Any help here would be great and thanks in advance!!
    Regards,
    Price Dempler
  25. #150
    Mass
    E30 M3
    E30 M3 - Ireland Engineering stage 3 race springs, -3.5 degrees of camber, and no fender liners.
    what will fit with rolling fenders and custom wheels in either V710s or A3SO5:
    245 40 17
    285 30 18
    265 45 16
    And if one of these will fit what wheel width and offset?
    Craig
