Bimmerforums Upgrade Garage The Tire Rack
Page 51 of 152 FirstFirst ... 2641424344454647484950515253545556575859606176101151 ... LastLast
Results 1,251 to 1,275 of 3780
Thread: PLEASE READ BEFORE POST: The ultimate wheel/tire fitment thread.
  1. #1251
    Feb 2008
    07601, NJ
    2003 Acura CL-S (SOLD), 08' 335xi Coupe
    Quote Originally Posted by Jim@tirerack View Post
    N54Bimmer,
    What year and model car is it? Give me a shout and I can take a look at options.
    Its an 02' Mercedes E430 RWD. But whats your opinion on using Performance Winter tires all-year long?
  2. #1252
    Ottawa Ontario CANADA
    21 M3 6MT Dravit/KO/ZPP
    Quote Originally Posted by N54Bimmer View Post
    Not sure if you care about my opinion, but I'll throw my 2 cents in anyway. In a recent review I read/saw, they deemed modern winter tires as suitable for all season driving due to advancement in tire manufacturing. The only drawback (again according to them which is a view I share) is that you'll have to change tires more often since winter tires don't last as long esp. in hot climates (due to the compounds used). In addition, with winter tires, as with all seasons, you lose that extra performance edge of the summer performance tires.
    Would like to see what Jim thinks.
    Current Car (delivered 20/10/21): 2021 G80 M3; 6MT; DravitGrau/Kyalami Orange/Black Extended Merino; Permium Pkg (ZPP); 826M bicolor wheels; Black M Compound brakes; Sunroof (yes no CF roof)
    (more pictures here)
    Previous Cars: 2018 F30 340ix 6MT Msport(Dec 2017 - Sep 2021); 2013 F30 335ix 6MT Msport (Nov 2013-17); 2011 e90 328i 6MT ZSP (Aug 10-Nov 13); 07 e90-323i ZSP (May 07 - Aug 10); 97-318ti ZSP (Feb 97 - May 07)
    "Mit der Dummheit kämpfen Götter selbst vergebens", Friedrich von Schiller -- "Life is simple, people make it complicated", Me (About me)
  3. #1253
    Mobile, Al
    1995 325i, 1998 528i
    Hi Jim, I posted before that I am buying some m3 style wheels for my car. They are 18x8 and 18x9. I am putting them on a '95 four door 325 bmw. What size tires should I put? Also couuld you explain to me how tire sizing works please? Thanks, Tyler.
  4. #1254
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The tire size would be 225/40R18 and 245/35R18 on the rear. Anything wider and you can have some rubbing. If I can help with the tires let me know.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  5. #1255
    Mar 2008
    Phoenix, AZ
    95 M3 S50B32 Euro
    Jim,
    I want 18x9 all around for my 97 M3 Sedan, I have a set of 245/40/18. The car is on stock suspension and ride height. What offset will work, 38, 40 or 45?
    Thanks,
    Robert
  6. #1256
    Feb 2008
    San Diego
    Z//Coupe
    I have a z3 2.8 coupe, what offset do i need for front and back, can i fit 9" in the rear. Do i need a specific bolt pattern/spacing spec? It has 5 bolts, are all 5 bolts the same? Car has bilstein sports/HR lowering Spring combo.
    Thanx
  7. #1257
    Nov 2003
    Vancouver, BC
    1999 M3 Coupe
    Quote Originally Posted by yellowbullet View Post
    Trying to confirm if this set-up will fit my car:
    REAR:
    8.5x18 ET30 w/ 245/35/18 Michelin PS2
    -1.5 to -2.0 camber
    Coilovers, dropped a little bit
    Will rolling my fenders or cutting the fender lip off make the rears fit? Appreciate your help!
    I would say you are going to have to do more that that to make the 30mm offset fit. With the car lowered and the wider wheel and tires on the rear I think it is going to rub.
    I'm just curious why the rear set-up wouldn't work, when 10x18 ET40 BBS CHs fit with some work (also sold on your website). Wouldn't those stick out 10.95mm more?
  8. #1258
    Sauga
    97' 328cabby
    Will 18" replica rims off a 540. They are a staggered set up, front 18x8.5 and rear 18x9.5 fit on my car. stock suspension for now. 1997 328i vert. If not how much work would it take to get them to fit? Any tire size recommendations?
    Does this make sense
    2007 e90 323i
    Front 18x8.5 (+40) 225/40/18
    Rear 18x9.5 (+22) 255/35/18
    Any fitment issue that is obvious? I am getting very different and confusing feedback about how the tires are not a good fit for the wheels or how the wheel offsets are not correct for my car. Any help is appreciated.
  10. #1260
    Nov 2005
    Madison, Wi
    F1FIDDY, Corvette
    will a 245 40 17 fit on a 8in wheel?
    hrmmm
  11. #1261
    Quote Originally Posted by mryakan View Post
    2007 e90 323i
    How about 245/40/18 all around with 18x8.5 (Front et40, Rear et22)? Will the rolling circumference be much different than my stock 225/50/16 affecting my speedo/odo readings? Any chances it will rub? I really want to install without needing to do any fender or alignment adjustments.
  12. #1262
    Hyannis MA
    1988 E30 M3
    88 E30 M3
    Jim I have 18 in M Parallel wheels on my 88 M3. They are reproductions with what think is an offset of 20. The person who sold them to me said they were purchased with tires as a package from you guys about 3 years ago. Well I have the need for a replacement wheel can you offer any help? Thanks
  13. #1263
    2007 e90 323i
    Jim, any comments on this?
  14. #1264
    Nov 2007
    Puyallup, WA
    550i S, Hemi 5.7, Mazda
    SIZE - 19x8.5 FRONT 19x9.5
    BOLT PATTERN - 5x120
    OFFSET - 15MM FRONT 15MM REAR
    Would that fitment be right for a 1998 528i, or should I try to get et 20-25?
    2007 550i Sport - Jet Black - Muffler Gone ^^ (3.5" SS pipes>2x 3" tips), Smoked LED side markers, ECU Tune
  15. #1265
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The rear will probably need some help to fit and you will probably need to roll the fender lip. Just stay on the narrow side for the tires. If I can help let me know.
  16. #1266
    Nov 2007
    Puyallup, WA
    Would it be better with 18's? I'm just trying to get some wheels that I can put on without modification, I had thought et20 was the right fit for e39s but I keep seeing et15....what would you recommend for a wheel and tire size that could be put on without rolling the fender or using spacers?
  17. #1267
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The problem is really with the wider rear wheels. If you stay narrow on the tires with the 20mm you should be fine. I would say stay with a 255 or 265 on the width.
  18. #1268
    Mar 2006
    Las Vegas, NV
    TURBO M52
    Jim, just purchased a set of 18x8.5 offset 38
    am i good to go with 225/40/R18 all around even if i'm dropped using eibach sportlines?
    thanks!
    97 Euro M3 S50B32
  19. #1269
    WA
    whip got jacked
    Hey!
    Car: 1996 328is
    wondering what backspacing i would need on a 16x10 rear and 16x8 up front. I will be rolling the fenders and my car is lowered quite a bit. I will obviously be running some - camber. Just want to know because i dont want the rears to rub the strut housing.
    Thanks!
  20. #1270
    Mar 2008
    Minnesota
    94 525i
    I'm wondering if OEM m-pars from an e38 will fit on my e34?
  21. #1271
    Mar 2008
    Fairfield, CT
    2003 325xi
    ZHPs for my 325xi
    i have an 03 325xi. i want to put 18' ZHPs on it. i found this set on ebay. will they fit my car??? should i get different ZHPs??? please help
    http://cgi.ebay.com/ebaymotors/18-Bmw-3-series-M3-318-320-323-325-328-330-wheels-rims_W0QQitemZ290218577704QQihZ019QQcategoryZ43958 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  22. #1272
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I can't get into the site because I am blocked at work. If you can get me the size and offset I can tell you if they will work.
  23. #1273
    Jan 2005
    SoCaL
    tree-ate-een-tee-eye
    I recently got Hartge Classics in 18x8.5 ET 40...
    I was thinking about running 225/40/18 all around
    but...
    when I was looking at different sizes and was messing with a tire calculator,
    I saw that 215/40/18 was the closest to the stock diameter.
    Would it be safe to run 215/40 all around?
    or would you rather recommend 225/40?
    Thanks alot!!
    -Randy
    Straights are for fast cars, turns are for fast drivers. -97 Schwarz II Black 318ti Sport- Goodtimes 318ti -99 TiAg Dinan 323is -13 Scion FRS 10 Series
    Now Featuring: Hartge Exhaust, 325is Vented brakes with Goodridge SS lines, clear fronts/sidemarkers (1/2 mod), Blacked out kidney grilles, Bilstein Sports with H&R Sports, E46 RSMs w/ Z3 reinforcement plates, OEM E46 M68 17" rims, 18x8.5 Hartge Classics,Gen IV DEPOs w/ 4500k HIDs and city lights
    Coming soon:IF YOU HAVE A 318TI SPORT FS IN SOCAL, TELL ME!...DASCed 2.1 maybe?...or the new car mod...ALL IN ONE CAR!
  24. #1274
    Mar 2008
    Fairfield, CT
    2003 325xi
    18 x 8" - 35mm - 5 on 120mm
  25. #1275
    Mobile, Al
