Bimmerforums Upgrade Garage The Tire Rack
Page 28 of 152 FirstFirst ... 31819202122232425262728293031323334353637385378128 ... LastLast
Results 676 to 700 of 3780
Thread: PLEASE READ BEFORE POST: The ultimate wheel/tire fitment thread.
  1. #676
    Dallas
    Tire Rack has a diagram to show you what offset is. Go to TR and search offset.
    Frank
    540/6
    Race/Street Rubber Z1 Star, 275/35-18 Front & Rear, Eibach Sways Front & Rear, Cut and Formed OEM Sport Springs, Bilstein Sports, Go-Go-Ware, ATE disks w/SS lines & HPS pads, UUC SS, CDV, White/Tan, Bling free and Stealthy.
  2. #677
    Vancouver, BC
    1992 325i Sedan
    1992 325 Sedan.
    Looking at The Beyern Mesh Wheel.
    Can I pull of a staggered fitment. 18x8.5 front/18x9.5 in the rear? Maybe run a bit narrower tire in the rear than normal on a 9.5 rim? Stretch it a bit? I plan on rolling the fenders but are there any major mods that would have to be done?
  3. #678
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Rooz,
    You can go with a 255/40R17 on the factory wheel. If you go to 18" the tire size would depend on the size of the wheel and the offset of the wheel. The biggest I would recommend would be 225/40R18 and 255/35R18.
    If I can help let me know.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  4. #679
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Tim, If you stay on the narrow side on the tires it would work with the fender lip roll and or more negative camber. Try a 245/35R18 and you should be ok.
  5. #680
    Nov 2003
    Vancouver, BC
    1999 M3 Coupe
    I've been looking for a set of wheels for my car for a few months now, and I have decided on which set to get but I have no clue about the sizes. FYI, my car is a 1999 M3 coupe, on GC track/school coilovers (440lb/550lb if it makes any difference).
    I know that I want to run 8.0x18 fronts and 9.0x18 or 9.5x18 rears. I'm down with rolling my fenders, and maybe even cutting the underside lip off, but I don't want to pull the fenders (major body work). I will most likely run Michelin PS2s, 225/40/18 fronts and 255/35/18 rears, unless a better tire comes out. I will be going with -2 degree camber in the front, and -1 degree in the back (unless I need to go even less). The only thing that's holding me back is the offsets, because I am trying to get the most lip out of the wheel (BBS GT2 magnesium). Here's what I need to know:
    1) What offset for the 8" fronts will make it flush with the fender?
    2) What is the lowest offset I can run on 9" wheels in the rear?
    3) What is the lowest offset I can run on 9.5" wheels in the rear?
    I know it's kind of hard to give exact numbers, because there's variables like how much lip I can cut, or how aggressive I will roll my fenders. Hopefully this thread can point me in the right direction. Thanks in advance.
  6. #681
    Jul 2005
    Charlotte, NC
    2004 ZHP, 2002 330i
    Unhappy
    Quote Originally Posted by Jim@tirerack View Post
    Rooz,
    Thanks for the answer Jim, however, I am not sure I understand your recommendation for the 18" size...
    Let me tell you why... (ANd please tell me if I'm wrong)
    Let's figure out the diameter of the factory setup...
    Considering that 1 inch = 25.4 mm
    Front: 225/25.4 = 8.8.....
    8.8.... * .45 (45% of width is tire profile) = 3.9....
    3.9... * 2 (top + bottom) + 17 (wheel size) = 24.97...
    So the factory front setup is 24.97 inches tall
    I'll spare you the explanations for the rear..
    Rear 245/40/17 = 24.71 inches tall
    Now, again.. I don't know too, too much if I'm correct but my guess is I need to come as close to those numbers as possible, right?
    SO..... from what I calculated here's the closest setup I could think of on an 18" wheel....
    Front: 235/40/18 = 25.4 inches tall
    Rear: 255/35/18 = 25.02 inches tall
    BUT... A 225/40/18 = 25.08 inches tall...HOWEVER being that the wheel is 8.5" wide (inside proportions so I am ASSUMING outside proportion is probably close to 9")
    9" = 228.6 mm Meaning a 225mm tire would be too narrow for this wheel? AM I correct? And IF the wheel's INNER width is 8.5" then the 235/40/18 would be the proper setup, but if 8.5" is the outside width then 8.5" = 215.9mm, then the 225/40/18 would be perfect?
    Quote Originally Posted by Gregg
    Umnitza now provides a mechanic to install all parts ordered right in the box! It's their new "Total customer service program" that will eliminate all the haters and keep incompetents from breaking **** and blaming the vendor! When you are all set simply call INS and they will pick him up free of charge.
    VIEW MOD LIST & PICS
  7. #682
    Wetlands, WA
    '01 740iL, '95 840Ci
    The problem would be the rear clearance. How wide a tire are you thinking?
    You left me hanging, bud
  8. #683
    Central Florida
    '01 325 Ci
    Jim,
    I am sure this question has been asked, but need to know about tire fitment. I want to buy one of two OEM M3 replica rims, 17"x8" 42mm offset, and looking to put 245/40/17 tires on all 4 corners. Will they rub, or will I need a spacer for the front. (have a great deal on almost free new tires)
    My car is a 01 325Ci with sports pkg.
    Thanks in advanced.
  9. #684
    Aug 2002
    South Bend, Indiana
    BMW 525I
    jb61,
    The 245/40R17 with the E36 M3 wheel should fit without a problem. The front may take a little work but it has been done many times. Sometimes just a small 3 to 5mm spacer is needed.
    If I can help with anything just let me know.
  10. #685
    Oct 2005
    Portland, OR
    93 325i Saloon !
    Jim,
    I needed some help on getting new tires. The wheels are 18x8.5, 35mm offset, approx 23-25lb wheel weight, 72.6mm centerbore.
    Whats the widest tire I can fit on a 93 325i, its not lowered or anything, stock?
    What are my options on all 4 tires? As well as a staggered look?
    TIA
    1993 BMW 325i Mod list:Replica M-Mirrors|Um-nitza Predator Chromium|M3 Replica Bumper|Clears All Around|Spoiler|Wide Euro Kidney Grille|Bf.c Decal |Clear Fogs|Velocity Splitters|M3 Sport Side Skirts|M-Tec Side Moldings|LTW Flag (hood)|Rieger Infinity 1 Rear Bumper|OCW ACS type III Repo
  11. #686
    Central Florida
    '01 325 Ci
    jb61,
    Thanks Jim, but my car is an e46 (01 325Ci), if that makes a difference on the m3 replica wheels. And second, where can I get the 3-5mm spacers ?? Or would it be better if I find some wheels with a smaller offset for the front ??
    TIA
  12. #687
    Aug 2002
    South Bend, Indiana
    BMW 525I
    abbott555,
    For the offset I would not go bigger than the 225/40R18. You might still have to roll the fender lip depending on the specific tire you choose.
  13. #688
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The 245/40R17 is just a little tight sometimes on the front.
  14. #689
    Long Beach, CA
    07 M6 cab, 04 VW Beetle Cab, 01 VW Beetle coupe
    2007 M6 Cabby Wheel Question
    Hi guys,
    The dealership says my 2007 M6 Cabby should be here in a few weeks, so I just ordered the new wheels/tires for it. I wanted to get some input as to if these wheels might stick out further than the OEM would have, which I don't think I would like.
    I am not sure what the offset of the new wheels is (or if I really know what "offset" actually means) but here is what the wheel company told me to order:
    DCR INFINEONS
    Front: 9.5"
    Rear: 11"
    MICHELIN PS 2
    Front: 255/30/20
    Rear: 295/25/20
    Thanks for any input
    Frank- Co-Founder of KOTR.
    www.knightsoftheroundel.com
    See my Custom Beetles at:
    www.bhrific.com www.bearjam.com
    Check out my Children's Hospital Toy Drive here:
    www.toyjam.org
  15. #690
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I would need the offset of the wheels to be sure. When I looked at the M6 stock they already were at the fender so I can't see them sticking out much more.
  16. #691
    Long Beach, CA
    OK, forgive me for sounding like an idiot, but if the stock wheels are 10" in the rear and 8.5" in the front, and the new wheels are an inch wider...where does that extra inch go?
    I know I hate it when I see a car with wheels that stick out like a matchbox car. Does the "extra" wheel go in towards the middle of the car?
    I will try to get the offset of the new wheels today as soon as they open.
    THANKS!!!!
    www.toyjam.org
  17. #692
    Aug 2002
    South Bend, Indiana
    BMW 525I
    That is what the offset will tell you.
  18. #693
    Long Beach, CA
    OK, thank you
    www.toyjam.org
  19. #694
    Jan 2005
    Cincinnati, Ohio
    1987 325is
    I am interested in getting some 16x7.5 wheels for my 1987 325is. I believe the offset is 20 or 25. Would i need spacers with this setup?
  20. #695
    Canada
    Couple of them..
    I'm looking into getting some Beyern mesh wheels in 18x8.5 but am unsure of two things,
    1. what offset, 40 or 15
    2. what size tire do I run without rubbing or bottoming out? (i'm on stock suspension ATM)
    All help is greatly appreciated, thanks...
  21. #696
    Wetlands, WA
    Guess I'm on my own (unless I somehow missed a reply)
  22. #697
    Oct 2005
    Portland, OR
    93 325i Saloon !
    abbott555,
    Order place thru bf.c, Thanks again Jim
  23. #698
    Michigan
    93 maxima, 97 M3
    2004 330 coupe rims will it fit 97 M3?
    I am badly in need of winter wheel & tire. Came across 2004 BMW 330 couple after market rims/tires. These were bought from tire rack. Tire size is 205/55QR-16
    I want to know whether these will fit my 97 M3. I think it will clear M3 brakes.
    If the wheel offset is different what effects will it have ?
    I am really looking for some time now. I belive my options are limited with regards to wheels for my M3 becos
    1. big M3 brakes
    2. Bolt pattern 5x120
    3. 16" or 17" wheel size
    Am I missing anything here ?
  24. #699
    Dallas
    Quote Originally Posted by Jayccel View Post
    Jim asked you how wide were you thinking.....above on this page.
    Look ^^^ up.
    Frank
    540/6
  25. #700
    Wetlands, WA
    Quote Originally Posted by franka View Post
    Look ^^^ up.
    Oh, I didn't know that was for me. Sorry about that Jim!
