Bimmerforums Upgrade Garage The Tire Rack
Page 27 of 152 FirstFirst ... 21718192021222324252627282930313233343536375277127 ... LastLast
Results 651 to 675 of 3780
Thread: PLEASE READ BEFORE POST: The ultimate wheel/tire fitment thread.
  1. #651
    Aug 2002
    South Bend, Indiana
    BMW 525I
    lyghtfunky1, Those tires would be way too tall for the car even if it is not lowered. You would need something like 205/50R17 or 225/45R17 to fit correctly.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  2. #652
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Enrique, Those wheels and tires will fit fine.
  3. #653
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I can tell you that I have seen 275/35R18 rub on the rear of a 5 Series with 17X9.5 wheels. A fender lip roll or more negative camber normally makes it work.
  4. #654
    Pittsburgh, PA
    94 325ic
    Quote Originally Posted by Jim@tirerack View Post
    Great, thanks.
  5. #655
    Victoria
    Bmw 318is
  6. #656
    Dallas
    18" tires on 17" wheels?
    Frank
    540/6
    Race/Street Rubber Z1 Star, 275/35-18 Front & Rear, Eibach Sways Front & Rear, Cut and Formed OEM Sport Springs, Bilstein Sports, Go-Go-Ware, ATE disks w/SS lines & HPS pads, UUC SS, CDV, White/Tan, Bling free and Stealthy.
  7. #657
    Apr 2006
    Chicago
    1993 325i
    if i run 245/35 on 18" wheels on my E36 325i, will i need spacers anywhere?
    Jim Conforti Chip, RE SSK, intake
  8. #658
    Apr 2003
    New York, NY
    2003 325i, 2013 X1 xD28i
    Winter Tires for '04 330i ZHP
    Hey Jim-
    I'm looking for winter tires for an '04 330i ZHP. The Tire Rack website says 205/55-16 will fit - I assume that means the 16" wheel is OK on this car?
    On a related note, I have a set of 17x8 BBS RK's from my E36 - will these fit the ZHP?
    Thanks for your help.
  9. #659
    Pooch is offline Member Secret Santa Deadbeat
    Oct 2005
    meow
    16cylinders
    Would 17x8 225/45 for front and 17x9 245/40 for the rear fit on my stock 96 328i w/o rubbing? I currently have stock 15x7 205/60 on my car.
    -Tyson
    BF.c OT Motorcycle Club Member #2
    04' BMW R1100S (Commuter) and 88' Honda Hawk (Track Bike)
  10. #660
    Aug 2002
    South Bend, Indiana
    BMW 525I
    It would depend on the offset of the wheel and the alignment setting on your car. Normally this set up will work.
    If I can help let me know.
  11. #661
    Oct 2005
    meow
    16cylinders
    The wheel offset is +40mm in the front and +45mm in the rear.
    Front> 17x8 225/45 Rear> 17x9 145/40
    The rest of my cars suspension is stock...here are the specs my mech set my car to.
    Front Axle>> Left Right
    Caster 3.2* 3.2*
    Camber -.3* -.3*
    Toe .15* .15*
    Rear Axle>>
    Camber -1.6* -1.6*
    Toe .25* .25*
    Thrust Angle 0.0*
    If this setup fits w/o rubbing will there be any extra or abnormal wear to the suspension?
    Thank you.
    -Tyson
  12. #662
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I would say you should be fine with the set up you mention.
  13. #663
    Wetlands, WA
    '01 740iL, '95 840Ci
    2001 740iL
    Looking at possibly purchasing some wheels. Dimensions are:
    "staggered"
    8.5"x20" front, 9.5"x20" rear.
    Looking for some low profile tires. Suggestions? Thanks!
  14. #664
    Dallas
    What type? All season, winter, summer only, super sticky, high mileage type, all show, etc?
    Frank
    540/6
  15. #665
    Wetlands, WA
    Smile
    Either all season or summer only. Still debating. I have a new set of tires on their now (proxies, 18") with the stock sport wheels, but I need to get MY look on the car
  16. #666
    Dallas
    Quote Originally Posted by Jayccel View Post
    So show is your thing then? Check out the looks of the Falken 452.
    www.FK452.com They are a top value tire. I had a set. Very good stick wet and dry, good looks and a very reasonable price.
    Frank
    540/6
  17. #667
    Wetlands, WA
    Thanks! I'll check them out
  18. #668
    Aug 2002
    South Bend, Indiana
    BMW 525I
    How aggresive do you drive the car? What sizes are you planning on running on the car? Let me know and I can make a better recommendation.
  19. #669
    Wetlands, WA
    Well I'm not Jeff Gordon, but I drive it semi-hard, aggressive I'm planning on purchasing some 20" wheels ("staggered" 8.5"x20" front, 9.5"x20" rear)
  20. #670
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The problem would be the rear clearance. How wide a tire are you thinking?
  21. #671
    Wetlands, WA
    You tell me Jim. I'm here to collect as much advice as I can! Would you suggest me going down to a size 18?
  22. #672
    Wetlands, WA
    Quote Originally Posted by franka View Post
    I really like those! Couldn't find any prices on their website, but I'm sure that wouldn't be hard to find out.
  23. #673
    Dallas
    Two good places for price are....
    www.edgeracing.com and www.vulcantire.com
    Forget Discount Tire. They are high.
    Frank
    540/6
  24. #674
    Jul 2005
    Charlotte, NC
    2004 ZHP, 2002 330i
    Jim@tirerack,
    I drive a 2002 330i
    I have 2 questions for you....
    One...
    My tire blew up today, and turns out I have a bent rim.
    IF am wanting to replace both my rear tires, what is that widest rim I can do on my stock wheels without having to roll fenders. My car has the sports package so I have the factory 17" ///M wheels on my car. The factory setup is 225/45/17 for the front and 245/40/17 for the rear.
    2nd question.
    Because the wheel is bent, I might just replace all my rims with some CSL 18*8.5" wheels. Again same question, if I decide to go with that setup, what's the widest I can go with both for the front and the rear?
    My guess would be on either setup = 235/45/ 17 or 18 and 255/40/ 17 or 18...
    But then again... that's just my guess.
    Quote Originally Posted by Gregg
    Umnitza now provides a mechanic to install all parts ordered right in the box! It's their new "Total customer service program" that will eliminate all the haters and keep incompetents from breaking **** and blaming the vendor! When you are all set simply call INS and they will pick him up free of charge.
    VIEW MOD LIST & PICS
  25. #675
    Jun 2004
    Jersey
    '90 318is
    im sure this has been asnwered here. But i dont have time to go through 27 pages of mostly questions.
    I have a 95 325is coupe. i think my fenders have been slightly rolled in teh past. im running DSI's for now. non staggered.
    For my next set up id like either 17" or 18" with 8.5 wide upfront and 9.5 out back, or 8.5 all around. what offset would i need to clear everything.
    How does offsetting work, the bigger the number the more inward the wheel goes? so for example if 38mm sticks out past fender, than like 40somethign will be more tucked in?
