Bimmerforums Upgrade Garage The Tire Rack
Page 26 of 152 FirstFirst ... 1617181920212223242526272829303132333435365176126 ... LastLast
Results 626 to 650 of 3780
Thread: PLEASE READ BEFORE POST: The ultimate wheel/tire fitment thread.
  1. #626
    Killeen TX
    96 e36 cabrio w/hard top
    e36 cabrio 19inch
    i am looking for some new wheels for my e36 328i cabrio with stock sport package, i came across a deal. 19x8.5 with a 38mm offset for the the front and 19x9.5 with a 38mm. have the same option with a 20mm for the front and 30 for the rear. thinking of running a 225/35 in the front and 235/35 but am also into the new stretching of the tieres thing, if i wanted to go with the stretching what size tire shoud i run! also will this set up work on my car with out rubbing? or should i size it down some? really set on 19s.
  2. #627
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The 38mm can work with some modification. You will need to roll the fender lip and or run more negative camber. The tire sizes you mention are the correct sizes.
    If I can help let me know.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  3. #628
    Killeen TX
    Thanks Jim!
    One more question! I am currently deployed in iraq and having my father put the wheels on! what do you think it will cost to get the fenders and camber adjusted? Thanks Again
  4. #629
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The camber is just going to have an alignment done. A good body shop or speed shop can roll the fender lips. I am not sure how much it would cost though. I would just do the alignment first and it may be all you need to do.
  5. #630
    Apr 2003
    New York, NY
    2003 325i, 2013 X1 xD28i
    I've done a search and have found that E36 and E46's can share wheels, but 16" was stock on E46, while 15" was stock on E36
    My questions is - can you fit a 15" E36 wheel on an E46 and clear the brakes, etc?
    I'm asking this question for a snow tire set up- not for a performance upgrade, obviously!
    Thanks!
  6. #631
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Your answer is not the 15" will not fit the E46 and actually does not fit all of the E36 either. As far as that goes even the 16" wheels do not fit all of the E46 cars.
  7. #632
    Jan 2005
    YYZ / ORD
    '02 E39 M5 | '09 335i
    '96 328i
    18" CSL reps @ 18x8.5 all around
    stock sport suspension.
    Recommended tires? What abotu spacers, will they be necessary?
    '09 335i - Alpine white + Coral Red | '02 M5 - Imola Red + Imola Red
    Gone, but never forgotten:
    '04 E55 AMG Brilliant Silver / Anthracite .. '96 318i Alpine White / Black .. '01 330Ci Titanium Silver / Coral Red .. '96 328i Jet Black / Black
  8. #633
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The tire size for either wheel would be 225/40R18. Whether you need a spacer or not depends on the offset of the wheel.
  9. #634
    bakersfield, CA
    '07-335i, '05-325i, '99-328i
    will this fit on my 335:
    FRONT: 20x8.5 offset 25
    REAR: 20x10.5 offset 18
    thanks
  10. #635
    Michigan
    93 maxima, 97 M3
    M3 winter wheel/tire fit question
    I am looking for winter wheel tire combo and came across somebody selling their combo from 5-series (E34)
    Will these tire/wheel set fit my 97 M3? and another important question is this tire size best for snow traction?. I have read 205/ 55/16 is a good choice for M3 in winter. How many miles these usually last?
    Wheels are aluminum Borbet Type C: 16" x7.5", 5 x 120, +20mm offset.
    Tires are Bridgestone Blizzak WS-50: 225/55/16, studless
    Victoria
    Bmw 318is
    my car is slammed with apex springs 19x8.5's with 215/35/19 bfg g-force kow tires. i'm wondering if i could go 19x9's at all ? or even to increase the meat in the back of my tires? 225?
  12. #637
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The 5 Series wheels will not fit the M3. The offset is incorrect.
  13. #638
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The 19X9 can work on the rear but not on the front. You can go with the wider rear tires on the wheels you have now. If I can help let me know.
  14. #639
    Jul 2006
    VA
    325ci
    hey i've been wondering. i wanted to get bridgestone re050a PP but they dont come in 275/35/18. for a e46 m3 whats the next best size i can go
  15. #640
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The only size they would have would be the 255/40R18.
  16. #641
    San Marcos, TX
    11' Mustang 5.0
    Im looking at purchasing black asa ar1's for my whip..... from tirerack of course .....I was planning on buying the 18x8, 18x9 rear... problem is I have koni's paired with eibach pro kit.....which tires would I need for the 18" asa's without modification (fender rolling). Do you think 18x8 all around would be better? Or would 17s be the only solution for no rubbing issues.
    ///Mmmmmmmm
  17. #642
    Jul 2006
    VA
    325ci
    would there be any fitment issues with a 275\40\18? the other size they have is 265\35\18.
  18. #643
    Aug 2002
    South Bend, Indiana
    BMW 525I
    99hellrotM,
    The size I would recommend would be 225/40R18 front and 245/35R18 or 255/35R18 rear. You can also just run the 225/40R18 all the way around. Even though the rear tires are narrower it will reduce the understeer and handle a little better. The wider tires and wheels do look good on the car.
  19. #644
    Birmingham
    E39 540i
    I have a 01 325i will 18x10 fit and ride well on the rear
    if not whats the widest i could go
  20. #645
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Without modification the 18X10 is not going to work. The widest I would say, and it still requires some modification would be the 18X9.5 with a 255/35R18 tire.
  21. #646
    Jun 2006
    High Point, NC / AutoSportNC.com
    1995 Alpine Weiss III M3
    How about 215-55-17 for a 92 325i's set of winter tires on 17" with H&R lowering springs?
  22. #647
    Pittsburgh, PA
    94 325ic
    I have a 94 325 with stock 15'' wheels. I'm looking at buying a set of 16'' Mille Miglia Spiders to use for winter wheels. They already have a set of 205/55 tires mounted. The seller used them on his 99 M3.
    Will these wheels/tires fit properly on my 325 without any modifications or issues when I switch back to the summer wheels?
  23. #648
    Greenville, SC
    2000 528i
    What's the biggest 18" wheels and tires I can fit on my 00 528i without modifying the body?
  24. #649
    Dallas
    Quote Originally Posted by fubak View Post
    Tires 275/35 front, 285/30 rear. Wheels 9.5 front 10.5-11 rear.
    I'm running 275/35-18 on all fours on 9"wheels. Been doing it for years. Can rotate and/or flip for max miles. I keep the best two take-offs when getting new ones for emergencies like cutting a tire. Then I can just whip on the spare from my garage till I get a replacement or just let it wear down with the rest. Lots of options with 4 corners alike and it makes the car handle like a go cart. No understeer, all four will beak and slide laterally together.
    Frank
    540/6
    Race/Street Rubber Z1 Star, 275/35-18 Front & Rear, Eibach Sways Front & Rear, Cut and Formed OEM Sport Springs, Bilstein Sports, Go-Go-Ware, ATE disks w/SS lines & HPS pads, UUC SS, CDV, White/Tan, Bling free and Stealthy.
  25. #650
    Greenville, SC
    2000 528i
    Wow, those are wide wheels/tires!
