Bimmerforums Upgrade Garage The Tire Rack
Page 11 of 152 FirstFirst ... 234567891011121314151617181920213661111 ... LastLast
Results 251 to 275 of 3780
Thread: PLEASE READ BEFORE POST: The ultimate wheel/tire fitment thread.
  1. #251
    Jan 2003
    Minneapolis, MN
    02 M5
    I am thinking about purchasing an E39 M5 and I wanted to know whether the winter wheels/tires I bought for my E36 M3 would still fit, or should I get rid of those too?
    The winter wheels and tires are AT Italia Type 5's, 7.5x17, 225/45 front and 8.5x17, 245/40 rear. The tires are Blizzak LM-22's. Would the fronts even work anymore or would I need huge spacers?
    Thanks,
    -John
    02 M5 LeMans Blue
  2. #252
    Oct 2005
    Ottawa, Ontario, Canada
    2006 325i
    Whither E36 steel wheels on an e90
    Ceteris paribus will 'standard' steel wheels from a 2002 E36 fit without any spacers on an E90?
  3. #253
    Aug 2001
    NC
    '11 XC90, '06 Jetta 2.0T
    Jim, can you see here please?
    I am wondering about the +22 offset on the HM2's in the rear. Also, can I fit 245/35 on the front wheels with a 32 or a 38 offset? The thread explains the whole situation.
    http://forums.bimmerforums.com/forum...d.php?t=427782
    Thanks.
    -Dave
  4. #254
    Aug 2002
    South Bend, Indiana
    BMW 525I
    First off 3 Series wheels will not fit a 5 Series. I do not have any 16" steel wheels for the E90. My guess would be they do not have enough brake clearance.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  5. #255
    Aug 2002
    South Bend, Indiana
    BMW 525I
    My guess is that a 22mm offset wheel is going to rub and the front wheel offset you mention is going to be tough on the front. Without some fender lip rolling and maybe more negative camber I think it is going to rub.
  6. #256
    Aug 2001
    NC
    Thanks for the response, Jim. You don't think the 19X10 et22 will fit in the rear even though the old owner ran 19X10 et24 with some slight rubbing?
    Also, for the fronts, I would want 19X8.5 et32 LMs with 245/35 but would go 235/35 to fit. Is a 235/275 F/R combo too extreme?
    -Dave
  7. #257
    Aug 2002
    South Bend, Indiana
    BMW 525I
    If the old owners package rubbed then the 22mm offset is goint to rub a little more. You can always roll the fender lip and run more negative camber and make it work.
    If I can help let me know.
  8. #258
    ayton is offline Rabbit in your headlights
    Feb 2002
    Westchester,NY
    325ti, '14 Outback 6spd
    Quote Originally Posted by Bav///Man
    you want to go with a higher offset to make it work...if a 24 rubbed then you want a (maybe) 28mm or 30mm
  9. #259
    Aug 2002
    South Bend, Indiana
    BMW 525I
    That is correct. The only thing is that with a wheel that wide you can't go to high or it will rub on the inside.
  10. #260
    Rancho Cucamonga, CA
    '92 325is
    I have a '92 325is running on 225/45/17's in the front and 245/45/17's in the back instead of 245/40/17's. Will this combination cause any problems?
  11. #261
    Feb 2002
    Westchester,NY
    Quote Originally Posted by johnny325is
    has it?
  12. #262
    '92 325is
    I just put them on yesterday. I have not felt any problems so far. Does anyone else has the same setup?
  13. #263
    Aug 2002
    South Bend, Indiana
    BMW 525I
    It will throw off the anti lock brakes, speedometer, odometer and gear ratio. Other than that you would be fine. I don't think they had traction control on that year car.
    I would say not a good idea.
  14. #264
    Mar 2005
    (Northern) California
    2018 530e iPerformance
    Jim at Tire Rack
    I have a 2002 E39 currently running M5 wheels and tires (245/40x18 front and 275/35x18 rear). I'm looking to replace all four with something that is quiet (no/minimal road or tread induced noise) and perhaps NON-directional as I prefer to "rotate" them. (Obviously not front-to-back but rather side-to-side.)
    I looked at your website and noticed some BFG's G-Force Sports and Kumho ECSTA ASX's. Are these quiet riding tires? Can you name others that might fit my needs. Although price is always a consideration I would also consider a higher priced tire if it serves my needs.
    As I don't push my vehicle anywhere close to the limits, performance oriented tires are NOT necessarily an issue.
    Thanks.
    You ain't no daisy!!
  15. #265
    Aug 2003
    Cincinnati
    318is,Impreza,Rabbit
    I have stock bottlecaps (15x7) for an e36. I have read conflicting reports in this thread on what tire to get. I would like to run 225/50x15, will this work for sure or will I have to run 205/60x15. Also will the shortened height of the 225/50's mess with my speedo a lot?
    Thanks!!
    Dignity, Charm, and Contentment... The joys of happy pipe smoking
    Car List:
    1995 318is- daily #1
    1995 Impreza- daily #2
    2010 Prius- Wifes daily and road tripper
    1984 Rabbit- autocross weapon
    2008 IS350- sold
    1995 Grand Prix- sold
    1988 Integra- dead
  16. #266
    Aug 2003
    Cincinnati
    A little help here Jim.
    Thanks a lot
    Karl
    Car List:
    2008 IS350- sold
    1988 Integra- dead
  17. #267
    Feb 2002
    Westchester,NY
    Quote Originally Posted by captainkarl
    Thanks a lot
    Karl
    I wouldn't run a 225 on a 7 inch rim it will look buldged...215 max 50 series is fine and a 45 for a better look
  18. #268
    Aug 2003
    Cincinnati
    Won't 45's be quite a bit shorter than stock? Will this through off speedo a lot?
    Thanks for the help.
    Car List:
    2008 IS350- sold
    1988 Integra- dead
  19. #269
    Oct 2005
    kuwait
    BMW 328i 96,325i 93
    Hi Jim,
    would the 265/30-18 tire on rear, fit in my car bmw E36 325i coupe automatic 1993. without any rubbing issue, if so how i solve this problem.
    the wheel is E46 M3 CSL type replica 9.5jX18 offset +40 on rear wheels.
    Also for the front 245/35-18 tire would it fit in the front axle, the wheel E46 M3 CSL type replica wheels 8.5jX18 offset +40.
    thx...a lot
  20. #270
    Feb 2002
    Westchester,NY
    Not much shorter 50's to 45's isnt all that much and I really dont "think" in my mind that you will ever be able to tell the difference. I went from 15 inch stockers on my car to 18's and didnt bat an eyelash...the only thing I actually noticed was tramlining in the very beginning (1st 50 miles or so) after that it was (felt like) I hadn't changed a thing on the car. I'm speaking from experience...I know what the books say, but real world is sometimes different.
  21. #271
    Aug 2002
    South Bend, Indiana
    BMW 525I
    lion328 the 265/30R18 would rub on the rear and they are shorter than stock.
  22. #272
    Nov 2005
    Beautiful Downtown Burbank
    1969 1602, 1998 M3 Sedan
    I run 205/50/15's on my auto-x car.
    I test fitted my firend's 225/45/15 hoosiers on my car and they fit.
    One question....
    What is the diffence between those 2 sizes in overall diameter. I didn't hav a chance to put both tires side by side.....
    69' BMW 1602 Vintage Racecar BS-L Racing w/ VARA in Cali (@1602racer on IG)
    10' Toyota FJ Pre-Runner (LS3 big suspension - @trophyFJ on IG)
    17' F250 6.7l Tow Rig and shop truck
    '12 X5d Wifeymobile
    89' M3 *Sold / 88' M3 *Sold / 98' M3 Sedan Sold / 06' M3 Comp.Pkg.SMG *Sold
    My 1602 race car build thread.
  23. #273
    Dec 2003
    Philadelphia, PA
    87 325is, 00 323iT
    will a 16" tire off my 16x7.5" wheels fit on a 16x7" wheel? I cant find any 16x7.5 wheels that are new that dont cost a fortune. I have some old Borbet Design T's but they have taken a few hits on the rough PA roads and well they arent even close to round anymore. MY tires are still good and even though i wish to go to 15" wheels i cant justify throwing away good tires for no reason. If any one know where i can find a lightwieght 16x7.5" wheel please let me know. Or if someone is interested in a set of Bridgestone Potenza RE750's that are about 70% little camber wear thats all.
  24. #274
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Yes the tires will fit either the 16X7 or 7.5.
  25. #275
    Nov 2005
    Memphis, TN
    2006 BMW 325i Sport 6spd, 1991 VW GTi 16V
    Is it possible to get a set of ASA AR1 18" with staggered widths for an e90 325i?
    2006 325i Sport 6spd - Jet Black/Terra
    1991 VW GTi 16V - Tornado Red/Factory Recaros
