Bimmerforums Upgrade Garage The Tire Rack
Thread: PLEASE READ BEFORE POST: The ultimate wheel/tire fitment thread.
  1. #2601
    Mar 2010
    Zeeland Mi US
    1991 535i, 1991 318is
    I have a 91 535i and have been running ASA AR1 17x8JJ. recently picked up a set of Racing Dynamic 8Jx17H2ET15 they do not appear to fit easily over the plastic aligner (74.07 72.6) When I tried to put one on it mashed the aligner. And when I tried to take tire off I had to beat on it to get it off. There is some oxidation build up in the inside of rim where it mounts. Do I just need to clean this up? Do I need a different plastic sleeve? Or will these not fit
    1991 535i 5 speed Stainless Exhaust ASA wheels Pirelli Tires koni sports Eibach springs, Rd sways and strut support
    1991 318is My sons Project car
    1987 325 vert
    1988 M3
    1973 2002
    1988 vert
    1991 325ix
  2. #2602
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The Racing Dynamics wheel may not need the centering ring.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  3. #2603
    Mar 2010
    Zeeland Mi US
    Thats what I wondered cause when I took the ring off the RD fit fairly tight. So you think I can run w/o the ring?
    1987 325 vert
    1988 M3
    1973 2002
    1988 vert
    1991 325ix
  4. #2604
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Yes
  5. #2605
    Brisbane Au
    1991 Bmw 520I
    Quote Originally Posted by Daved View Post
    As everyone can tell, we have many threads asking the same fitment question. I think we can cut down the amount of this kind of reposts if we put together all those questions in the same thread. Then we will be able to search here for an answer before making a new thread.
    I will try to keep the following post updated with the most frequently asked fitment questions. Let's make this work for all of us, please post your fitment question here.
    Thanks for using this thread.
    -David
    E36 , I have been offered some tidy 235/40/18 tyres mounted on wheels off a Holden commodore (chev/pontiac) stamped ET35 on the hub , the tyre shop claims they will fitand the centres are bmw but I wonder about clearance , I am keen due to needing lots more room for the upcoming brake upgrade , what should I looking for as they are 90 minutes drive away
    Tia
    B
  6. #2606
    South FL, USA
    1997 328is / 2008 750Li
    I have a 2007 750Li on stock size rims and tires. I want to get some spacers put just so that the rim of my wheels/tires match up with the car. What size should I go with? 25mm?
  7. #2607
    Aug 2002
    South Bend, Indiana
    BMW 525I
    To have them stick out the same as the rear tires you are going to need a 35 mm spacer. I think they are going to rub and stick out but that is what you would need.
  8. #2608
    Sanborn, NY
    2013 M5, 2000 M5
    Hey guys,
    I think this is the place to ask:
    I have a 2000 M5, I want to get a second set of wheels to use snow tires on. I dont want to use a tire wider than 245, or bigger than 18's. What other stock BMW wheels have the same pattern and same offset as my fronts? (I think the rears are too wide of a rim for the winter) I have found some stock BMW wheels with snow tires on them but they are for 04+ 5 series and some for E46 cars...
    So if you can't provide me with specific models can you tell me what my bolt pattern is and the front offset? 5 120 ET?
  9. #2609
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I am not sure which factory wheels will work but we do have both 17" and 18" wheels that work on the car. The 245 tires all the way around are the way to go. If I can help let me know.
  10. #2610
    Calgary
    01 540i6, 93 318i
    I've got a set of staggered 17'' style 66 rims that I need to get winter tires on. The fronts are 8'' wide and the rears 9'' wide. What size do you recommend for winter tires?
  11. #2611
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Unfortunately I do not have any real good options for the rear staggered. The best thing to do for winter would be to run the 235/45R17 or 245/45R17 all the way around. Both sizes are going to fit both wheels.
  12. #2612
    MA
    E46, F350
    Going to purchase a set of wheels (basically M5 reps). What I have come down to is:
    Front - 18x8 +35
    Rear - 18x9 +38
    245/30 tires all around
    I have a 99 328i on Rokker coilovers. Question is what spacers are going to be needed? Not trying to tuck and will consider rolling the fenders if needed.
    Would appreciate some useful advice!
    And any other tire suggestions, thanks!
  13. #2613
    Nov 2010
    tbilisi
    1995 e36 coupe
    can anybody tell me what wheels ar on these car???
    http://www.autoscout24.de/Details.as...xqpzm&sbs=Home
  14. #2614
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I would think that with that offset you would not need spacers.
  15. #2615
    Nov 2010
    Laredo Texas
    1992 BMW 325i
    hi my question would be would 18x9.5 +12mm offset fit on my 1992 bmw 325i ? and if so what kind of modding would i have to do to accomplish this.
  16. #2616
    Brisbane Au
    1991 Bmw 520I
    Quote Originally Posted by KiNGBiMMER92 View Post
    I run 235x40x18 on 8"rims at 25.mm offest e36 and there is little room on the front with the suspension/springs , I should think it might be a problem at the front and pretty tight with spacers on the rear ?
  17. #2617
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Those wheels are not going to fit on the car without a widebody kit or no fenders.
  18. #2618
    Feb 2004
    St. Louis
    '04-530i
    Ok, so it is time for some new tires. I was looking at tire rack, and it listed a 255 option tire for my 17 inch style 70's. Can this be right? if it is I am going to have to find some pics to check out the look and go that route.
  19. #2619
    Nov 2010
    Laredo Texas
    1992 BMW 325i
    thanks for the answer
  20. #2620
    Aug 2002
    South Bend, Indiana
    BMW 525I
    What size wheels are you running?
  21. #2621
    Nov 2010
    Laredo Texas
    1992 BMW 325i
    another question my car is stock height, so would i still have the clearance issues?
  22. #2622
    Maine
    84,86,87,88,89,90 3'ers
    quick question, will 215's fit 6" wheels?
    Quote Originally Posted by stevie30
    The e30 is the '57 Chevy of the European imports. Quote me on this.
    1986 325eS - cosmosblau, sold
    1990 325i sedan - bronzit, sold
    1984 318i coupe - delphin, sold
    1987 325iS - zinnoberrot, sold
    1988 325iS - zinnoberrot, sold
    1989 325iX sedan - zinnoberrot, current project/daily
  23. #2623
    Aug 2002
    South Bend, Indiana
    BMW 525I
    KiNGBiMMER92,
    At any height that wheel is not going to fit.
  24. #2624
    Aug 2002
    South Bend, Indiana
    BMW 525I
    docleary,
    What is the actual size of the tire?
  25. #2625
    Nov 2010
    Laredo Texas
    1992 BMW 325i
    thanks
Page 105 of 152 FirstFirst ... 555809596979899100101102103104105106107108109110111112113114115130 ... LastLast
