Results 1 to 3 of 3
Thread: what's the different between the 05/92 and the 06/92 suspension.
    Dec 2004
    toronto
    E36 325
    Hi.
    I want to put a later 92/06 and up suspension.
    on my early 92/05 E36.
    What do I need to convert this set up.
    or is it bolt on?
    Oct 2002
    Charlotte, NC
    E46iT, MK6 TDi, Z31Chump
    the early 92 front suspension resembles that of the E36 M3. Try to do a search for it....I'm not entirely sure what you need. I think you need new strut bearings and upper spring plates, and the complete sway bar assembly (links, bushings and bar), but again try a search....I've seen a couple threads on it.
    Jun 2004
    Lancaster, PA
    '07 328xi 6MT
    I believe its similar to the e36 M3 suspension only in that the sways are tab mounted onto the shock assy. itself ... and i believe that only applies to the EARLY early '92s, as in production dates thru 10/91. Then everything changed from 11/91-5/92, as you realized. Its not a direct bolt on.
    Understeer.com sells a kit with everything you need to get your car up to spec. to run a 6/92 and up suspension. IIRC its about $165. i'm sure you could piece together all the parts yourself, but the kit seems pretty convenient. i'm sure bimmer95 from understeer.com could answer any of your questions.
