- Waterpump + Fuelfilter
It looks like I am going to be doing some hard pumping today LOL. I am changing out the plastic pump to the metal pump (water) and putting in a new fuel filter. I am also changing the t-stat and the plastic t-stat housing to aluminum, what are some of the tools needed for all these jobs. I am not using the special tool for the fan removal. Also. I bought bmw anti-freeze and water wetter. What is the mix you guys use?
Re: Waterpump + Fuelfilter
Other than the optional fan removal tool, it's all standard handtools. The fan tool is not necessary either, just convenience. I used two bottles of water wetter, and roughly a 60/40 water/coolant ratio. Remember to purge the coolant sywtem.
- You may not post replies
- You may not edit your posts
Forum Rules
