Trying to install new suspension and i could not remove the nut that holds the upper mount to the top of the front strut. i guess these things are loctited on from the factory, and mine wont budge.
i dont have any air tools. i took a socket that fits the nut, and ground the sides flat so i could put a big wrench on it, then i slid a 6mm allen wrench thru the socket to hold the strut tube still. when i turn the big wrench on the socket, the allen wrech shaft just twists.
anybody have this problem before? how did you get the nut off? it is on there good. i even used a spring compressor to take the thrust load off it.
please help.
thanks
scott
impact is the only way. drive it to a shop and have them crack it loose then hand tighten for the trip home.
Alan
2006 325i
2015 M3
While an air impact is definitely the way to go, you can get it started with a hand impact driver. Once you get it loose, then you can use your 22mm socket with the flats to finish the job.
Good luck!
Bernman
