I'm sure its the damn seat belt switch people often refer to, but how can I fix it?
Thanks.
2003 ///M3 SMG
Acura RSX-S
you pull $80 out of your pocket and give it to the nearest dealer. that's about it.
How much is the part though? I can do it my self!Originally Posted by Freeplay
2003 ///M3 SMG
Acura RSX-S
get an srs tool and reset the light
I tried unplugging the batt and didnt work, poped right up again!Originally Posted by elements018
2003 ///M3 SMG
Acura RSX-S
That is correct. The ONLY way to reset it is either with the tool or to pay the stealer to do it for you. Unplug the battery all day long, the light will still pop up. You also might want to look into replacing the part that made it pop up in the first place. I forget which part it is, seatbelt sensor or something. Someone else should chime in as to what exact part it is that caused the sensor to come on in the first place. I lived with the light on my old M3 for 9 months or so before I sold it. It will not make the airbag non functional (it will however make it engage at a lower speed accident as it "assumes" that your seatbelt is not on).Originally Posted by Darkness
Edit: Is that tint on your car photoshopped?
i had my mech run a scan on it...
said the pass side belt harness was faulty, and it was i took it out and the wires were worn completely in half... cost me 77$ for the part...
Yes I wanted to block off my ugly grin so that some of my friends in other forums wouldnt photophop it...Originally Posted by Brent95M3
2003 ///M3 SMG
Acura RSX-S
hey this happened to me last january...took it to the dealer, yea they fixed it....but it cost me $237 bucks!!! it was my passenger seat belt buckle, part number 72-11-8-221-014, price $95.24. With Labor that cost went up to $237.74.
Oh Yeah, you wont believe this....the light turned on again tonight!! i dont believe this! any ideas?
Mine did this 4 times before the stealer put some sort of dilectric goop on the connectors called Stabilant 22. No problems since...
Sig courtesy of ///Maniac
'99 Z3 2.3 '97 740iL '90 735iL
'65 Sunbeam Alpine - Pimpmobile
$1.39Originally Posted by Darkness
1991 e30 318is Slicktop - Gone
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
2014 F-250 CC- Mostly stock
If anyone is interested in the tool, feel free to drop by our site
SRS Tool: http://www.bimmerzone.com/BMW_SRS_Airbag_reset_tool.htm
Check Engine Tool : http://www.bimmerzone.com/resettool.htm
Good luck!
Vince
<center>
<a href="http://www.bimmerzone.com/" target="_blank"><img src="http://i1181.photobucket.com/albums/x430/bimmerzone/Bimmerzonec.jpg" alt="" border="0"></a>
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
