- Fault Codes on 97 OBDII
How can I clear the check engine light codes on my 97 M3 OBDII ?
My secondary O2 sensors went. I replaced them and the light is still on.
Any idea on how to remedy this?
Thanks in advance.
If the problem is fixed, it should go away naturally after a few days. However, you can also borrow an OBDII scan tool for free from any AutoZone, which you can use to clear the codes.
That's exactly what I needed to know.
- You may not post replies
- You may not edit your posts
Forum Rules
