Page 5 of 7 FirstFirst 1234567 LastLast
Results 101 to 125 of 158
Thread: How to disable steering wheel lock?
  1. #101
    Morgan Utah
    1995 M3
    After the most intense week in the last 12 years in my business including the weekend I had a few great microbrews then saw this thread, 2 minutes later I was back in the house popping another brew, really!
    It worked like buttered magic
    Thanks!
    Rick
  2. #102
    Chicago, IL, USA
    1997 BMW 540i
    Video
    [ame]http://www.youtube.com/watch?v=sJ0FFl_POHM[/ame]
  3. #103
    Aug 2011
    Portland
    97 328is 07 X3
    Hi all! My lock was stuck in the "up" position and so my steering was stuck in a bad way. After dismantling the entire steering lock and ignition switch, I was able to remove the locking block. The problem was that the "elevator" had broken the tabs off the front and back and it was floating randomly in the slot. I removed it and voila! I put my Old Girl back together and all is well!
  4. #104
    las vegas nv
    95 M3 coupe/e90 325i
    Awesome just got wheel lock this A.M.!!!! , found this thread and drilled right in the middle and pulled out spring w/ needle nose pliers and NO more wheel lock!!!!! Thanks to all whose posted tips and pics
  5. #105
    Mar 2011
    Connecticut
    96 M3
    I'd like to do this, but does anyone have any idea if this could result in any floating parts (prev. loaded by the spring) that could move under track conditions and actually *cause* an unwanted locking?
  6. #106
    Tucson AZ
    1995 325IS 2dr
    Steering wheel started locking up today on our 95 325is. Could move the AT shifter back and forth and it would unlock till the next time you turn off the ignition.
    I performed the drilling and spring pulling and its seems good to go. Wheel turns just fine. Inexpensive fix. Some advise though, use good sharp drill bits.
    Thanks folks for the information
  7. #107
    Apr 2009
    anaheim
    97 M3 coupe
    Just did this right now took like 3 minutes drilled where the red square was came right out thanks
  8. #108
    Salem MA
    1997 BMW 328i
    Quote Originally Posted by eurokid9 View Post
    I've seen all the other photos, but the one with the 'red square' doesn't show for me.
  9. #109
    Pittsburgh, PA
    99 M3, 98 323is
    Quote Originally Posted by Chapel View Post
    it was posted again in #9...
    http://forums.bimmerforums.com/forum...66&postcount=9
    [Ethan "if it weren't for that cone" Connor|323is #89DSP]
  10. #110
    Salem MA
    1997 BMW 328i
    Quote Originally Posted by nondescript View Post
    bugger. Ok, how'd I miss that?
    luckily, these other pictures explain it better than that one.
    wow, that must have sucked for that guy drilling the shit out of that part
    whoops
  11. #111
    Sep 2011
    ATL
    1995 M3
    Quote Originally Posted by e36bill View Post
    This is my concern as well witha track only car????
  12. #112
    Jul 2001
    F150, Suburban, M3
    Quote Originally Posted by MCMM3 View Post
    This thread is 8 years old, guessing if anyone had issue it would have come up by now?
    "It's not the people who vote that count, it's the people who count the votes."
    -DNC
  13. #113
    Pittsburgh, PA
    99 M3, 98 323is
    Quote Originally Posted by badmonkey View Post
    Why would you apply logic, reason or fact here? This is the internet!
  14. #114
    Sunnyvale, CA
    E46 M/332i x 2; F87 M2C
    Posted a DIY on an easy way to disable the E46 steering lock:
    http://forums.bimmerforums.com/forum....php?t=1936568
    -Kalim
    (klx photo studio)
    M3 drive train conversion (S54 Swap, LSD, 6MT, suspension linkage) | UUC Stg 2 Organic Clutch | OEM M-Tech II Kit
    KW V2 | BBS GT4 RE | Falken FK452 | Alcon 6-pot 365mm BBK | M3 steering wheel | Powerflex bushings
  15. #115
    Pittsburgh, PA
    99 M3, 98 323is
    Quote Originally Posted by cyberkaa View Post
    ^^ that is much easier.
  16. #116
    Jul 2002
    NC
    not an e30
    Just removed the spring in my e36, dead center and I didn't even have to take the trim off! Thank you for posting this!
  17. #117
    Jan 2013
    good old NJ
    1994 BMW 325is
    It worked perfectly
    I drilled exactly where the photo's in post 9 & 52 showed and spring poped out , took about 5 min. Thanks for posting
  18. #118
    Apr 2002
    Maryville, TN
    '98 M3, '98 M3/4, '11 1M
    Quote Originally Posted by Mike Wied View Post
    Same here. Worked like a champ.
    Cars: '98 M3 Coupe - Daily Driver
    '98 M3 sedan - Track car:
  19. #119
    Sep 2012
    Anaheim
    1995 Bmw 325is
    by any chance do i have to unplug the negative terminal from the battery or can i just go in for the drill kill? haha
  20. #120
    Apr 2002
    Maryville, TN
    Quote Originally Posted by Briiian View Post
    I didn't.
  21. #121
    May 2013
    Canberra, Australia
    1997 BMW 323i Sedan
    Did anyone remove or disable the steering wheel airbag before doing this mod?
  22. #122
    Jul 2002
    NC
    not an e30
    Quote Originally Posted by cyborgzr View Post
    I didn't.
  23. #123
    Sep 2012
    Rhode Island
    1995 M3
    I just did this, with the flu, in my slippers. Took 5 minutes just like everyone else. I didnt take anything off the car, no moludings or anything, just drilled right in the center. The spring was offset of the hole but I could see it, I used a cotter pin to move it over a bit, then some needle noses to pull it out.
    Tip:
    Pack the drill bit with some heavy grease. This will catch most of the shavings, and prevent them from getting all over your car.
  24. #124
    Oct 2008
    UK
    Mazda RX-7 (FC3s)
    The spring has been removed on my car, I can still push the flap up and down to engage the steering lock.
    I hit a bump and my steering locked up and sent me into a bush earlier today
  25. #125
    Sep 2013
    Luton, England, Uk
    2004 Bmw M3 Convertible
    Hi there guys. New to this....
    Recently lost the keys to my dads 1998 (s) 520i.... Stuck in a little hole, needed the car moved into the garage while I get the keys made.... Now I managed to sort the gearbox situation which was it was stuck in park, now the car can be pushed!!!
    probelm is e car is at a slight angle and the steering is locked. I have read this forum and attempted the drilling but with no luck!!! Can I get some guidance on where exactly to drill!!
    Will this work on this model of bmw??
    Help would greatly be appreciated and thank you all in advance
