ooooohhhh *that* hurt....
///Mike 93 325is Spec E36 #2, 07 335xi, 06 X3, 02 Yukon XL (fer towin')
Thanks to my sponsors: HMS Motorsport -- Landshark Automotive -- Sansossio Auto Body
So I just went out to the garage and did this and it took all of 5 minutes. Spring was right where it is on the picture. Did a 3/16th pilot hole and then a 3/8ths momma, grabbed the spring and voila, no more steering lock.
Is it just as easy on an e46?
02 M3 SMG - prepared class BMW Club racer
08 135i - stock class BMW Club racer
www.TotalMotorOils.us
www.NittoTire.com
photo gallery
FMJ Motorsports
"not everyone is a princess like riley"
[16:04] spg383: my vagina gets cold below 40
So I just drilled the specified hole in my '99 Z3, but I don't see a spring ... I just see another moving, flat plate that appears to be the bottom of the lock pin itself. It moves down, towards the hole, when I turn the key, and then snaps up, away from the hole, when I remove the key. Do I also need to drill through this plate? Or is my car different and I need to drill elsewhere to find the spring?
anybody have a pic anymore. The page is dead and I want to do this.
2011 M3 Coupe - Individual Fire Orange/Black Novillo Extended Leather, 6MT, Mode Carbon, Eisenmann Race, BBS CH-R, BC Coil-overs (Sold)
1995 M3 Coupe - Avus/Hurricane, AEM EMS, Precision Turbo, Boostlogic, H&R, Fikse FM/5, MaxVelocity, Maximum PSI, 20% Tint, etc etc.. (Sold)
2009 M3 Coupe - AW/Fox Red, 6MT, Carbon Roof, Shadow Trim, etc (Sold)
post #4
Marshall, was that for me? I'm pretty sure I'm right where the dot is.
hi josh!
na, for wcm3. i would have guessed the 99 z3 had the same lock. does the key look like an e36 key or a e46 key? maybe a quick check of realoem.com to see if the part # is the same on a z3 as an e36. on mine there was no sliding plate under the red square, just a spring that popped out.
marshall
Looks like my car shares this part with E36s after 6/98.
Damn, that pic couldn't be any better. I just drilled right where the red square is, just like Mike, 3/16" pilot, 3/8" final, and the spring fell out as I withdrew the bit. Voila - no more lock.
#175 CM E46 M3
Former Knee Dragger
Real name= Chris P. Lewis
Occupation= Green House Gas Creator, but I planted a GARDEN last year.
"When you live inside a vacuum, nothing sucks"
http://flickr.com/photos/8150451@N03...7602830737584/
Just did this, took about five minutes. Took the spring out and thats that.
"When tolerance becomes a one way street, it leads to cultural suicide."
silly question, but what is the safety advantage here?
If you need to kill the car with the ignition switch (remember, you need to keep the stock wiring harness for Prepared), you won't accidentally also lock up the steering wheel by turning the key too far.
- Ian
2000 M Coupe, stripped and DE prepped
46mm wheel bearing socket for rent - $30 deposit + $10 fee. PM for details.
Just a note guys: Test that it actually works! Mine does not. It still locks sometimes, even though I've drilled it out (yes, I did drill the right place). I need to do a bit more digging in there to see what's going on, but I have the same issue as Josh in post #32
FMJ Motorsports
I did eventually find the spring. It wasn't in the same location as the other photos. In my car ('99 Z3), it was right smack dab in the middle of the big flat rectangular part.
