I am buying a used set, and the tires on the rims are 215-40-17 instead of the oem 235/245-40-17. So what is the difference, other than the width. Will this make it handle worse, wear faster, not be as safe, slip off the rims...?
And why would someone do this? IS it to save money on the rims? To prevent rubbing?
What width were the rims? If they're 17x7, that may be the correct size. If they're 17x7.5 or 17x8.5's they wanted the flexed out euro look; basically they wanted the tire contact patch to be smaller than the rim so the sidewall looks like this \_/ instead of |_|. It will handle worse and you may slip them off in a skid or accident.
actually, I have no idea. I'm buying these used and the seller says they came standard on his car, 95 m3. I do not think they are 7", becasue all of the oem m3 rims came in 7.5 and 8.5, and his set are not staggard.
I do not drive in a crazy fashion but take some good turns on a daily basis, do I need to worry about the tires slipping off the rims.
Stock 95 M3 size is 235/40/17 on 17x7.5 wheels.
The seller's size will be fine for speedo, abs, etc, but you won't have as large of a contact patch which will lower your ultimate handling limits. You'll also be more susceptible to curb rash since the lips will be exposed because of the narrow contact patch. I'd go with 235/40/17's on that wheel size.
Originally Posted by Blazin95Red325i
Doesn't the car handle best when it has as wide wheels as possible (not talking about anything stretching a normal tire to a huge wheel). For example it's better to have a 255 tire on a 9.5" wide wheel than on a 8.5".Originally Posted by hal9000
Have you sometimes experienced a tire slipping off a rim? I don't believe you at all. What are you talking about??
Blazin95Red325i, if the deal is great, buy those. If there's a 215 wide tire on a 8.5" wheel the biggest disadvantage is mainly the look. And of course it doesn't handle as good on a dry surface because you've got thinner tires. You can still do some track driving or drifting etc. safely. And I suggest you do, because then the tires are going to wear out faster and you can buy those nice 235's
aren't skinny tires better in the snow and ice? i could be totally off, but i have def heard that
need any photoshop work done? send me an email
Thanks for the informative replies, albeit the deal is not that great the price is rignt in my budget for now. They are not staggared but the oem 7.5's with 215's. But I plan on purchasing these because I cannot find anyone else with decent thread and condition wheels in my budget, well not as close for pick up. I will definetely pick up some 235 later when they wear out. can't wait, 205-215-235 huge difference.
Originally Posted by Kaizu
This is what is meant by the euro style stretched tireOriginally Posted by Kaizu
Notice how the sidewall is not perpendicular to the tread/road and is bulged out at the bead by a good 1/2"? That will affect handling and if you hit it wrong, it will pop tires more easily than if they were properly sized.
That looks stupid, what's the point of even putting tire shine on them, you can't see the sidewall. ANd I guess that is not dangerous if that is the way they mount their tires?
Thanks for the pic
The euro-tuning tires look really stupid imho. Especially in germany ppl are nuts for those atm, all their car mags full of pics with tires like that. I guess it does save some money since you can buy a higher profile and thinner tire and fit it in so it looks like a low profile tire.
It's one of those things usually only the one doing it appreciates.. like huge aluminium wings in civics, underlights and woowoo pipes in station wagons, articles in playboy.. oops i got carried away here Anyways if I haf to buy those tires I'd definetly burn them as fast as possible.
Oh yeah, they are possibly much easier to drift.
