Bavarian Soundwerks
Results 26 to 50 of 54
Thread: Bavarian Soundwerks presents: AMPLIFIER TUNING GUIDE
  1. #26
    A-town, Bitches!
    Escortizzle
    Quote Originally Posted by HK_M3 View Post
    That was great that he took the time to do that write-up!
    A few things to note, distortion will NOT blow your speakers.
    Get test CD that they use in competition (Autosound) and from there you can see if your headunit clips and at what volume. (all settings at flat)
    Through that cd you can also set your amplifiers to max gain with a test tone to insure distortion free music.
    I would not bring the sub past 90hz on the lo-pass side. Anything above 70hz can be localized by the ear.
    For richer mid-bass(male/female) voices up front (depending on the speakers you have) i would bring the high-pass of the fronts down to 60hz.
    -Nate
    Incorrect my friend. Distortion and clipped signals are the 2 main reasons for blowing speakers.
  2. #27
    A-town, Bitches!
    Escortizzle
    Quote Originally Posted by zebrex View Post
    this is one of the first lessons that I learned as professional car stereo installer. underpowering a speaker and sending distortion to it will destroy a speaker faster than poking a screwdriver through it.
    This is very true. People don't seem to ever get this fact either. And yes, it is 'usually' the heat from distorted and clipped signals/output that destroys speakers. The other leading cause is mechanical failure, which can be due to a multitude of issues.
  3. #28
    A-town, Bitches!
    Escortizzle
    Quote Originally Posted by sky11 View Post
    What would cause the radio , when tuned to an am station to 1, have an intermittent whine - increases in pitch as speed increases and 2, sound like an bell curve looks at a steady speed. Doesn't happen all the time, the whine is there much more often than the oscellation..
    My guess would be poor antenna grounding. Our antenna's of today are desgined prmarily for FM reception. Could possibly be the antenna groudning in the HU, as well. For the same reasons. I don't know for fact, but, don't BMW's use diversity antenna's?
  4. #29
    florida usa
    328ic
    Hi everybody Has anyone changed the rear speaker of a 1996 bmw 328ic convertible. And if you did I mean the big speaker the size is maybe 5inc or so I am not sure. Its the standard size that comes with the bmw not harmon Kardon or bose just the regular speaker. I would like to buy a new one but I dont know how to get to it. Thanks for the help in Advance.
  5. #30
    Sep 2003
    USA
    E90, E36, F10, E38, E23,
    can we get the above post removed?
    or put in a new thread?
  6. #31
    Jul 2001
    The Better Bay Area
    1998 4Runner
    Quote Originally Posted by kendogg View Post
    Distortion will not fry your speakers. A clipped signal (and only because of its power spike) will.
    -Nate
    1995 M3 - Gone
    2007 335i Sport - Euro Delivery - Gone
    2009 335i Sport - Gone
    1995 M3 - Gone
    1998 4Runner - Current
  7. #32
    Dublin, Eire
    316i
    Quote Originally Posted by Jos View Post
    Sortof.
    If it is set to 100Hz, that is the point at which the signal is 12dB (for 12dB/octave rolloff) lower than the unfiltered signal.
    Not true, it is (well should be) the -3dB cutoff point. The -12dB point is usually used by some loudspeaker manufacturers to make it appear that their speakers will go lower than others. Ever see ads that say:"This sub can go as low as 20Hz! (At -12dB *cough*) It's not a standard measurement.
  8. #33
    Great Falls, MT
    1999 bmw 540i
    I undertand the clipping ,blah blah but at least if you adjust the amps when the head unit is basically all the way up at lest morons can';t turn it up any farther then it is set at the amps
    1999 BMW 540-MSport Package, 20" American Racing Casino Chrome Wheels, 245/35/20 Sumitomo tires. Full Alpine System IVA-D310, TYPE X MIDS , SUBS AND PDX SERIES AMPS.
  9. #34
    SV, IL
    CRX 328is X5 528iT5sp 19
    cd43
    Does anyone have any experience with tuning the CD43 with amplifiers? I count 48 clicks to max volume but it is difficult to tell when the HU begins sending a clipped or distorted signal to my LOC & amps. I am using AudioControl's LC6 for LOC.
  10. #35
    Parsippany, NJ, USA
    328I, 1999.
    Hello,
    Is this for BMW original amp only or in general. Also, I will appreciate one advice. I have a sony subwoofer (12 inches). I just need an amp to install it in my car. Any recommendations? Is it a good idea to install it? or it will just put in a lot of base and destroy the balance? If yes, then which amp will be reasonable and easy to install?
    Thank you
    umermariner
  11. #36
    Atlanta, GA
    99 M3 96 328iC
    This is for an aftermarket amplifier. The OEM amp is not "tunable" in this fashion.
  12. #37
    Sandersville, GA
    2006 Z4
    Truth is, great sound is in the ear of the listener. I haven't found many people who like as much bass as I do. If you can't feel all the bass notes, it ain't good sound to me. I guess that comes from years of playing bass in several bands and playing all kinds of music. If you don't want a good massage from the bass, don't ride with me.
  13. #38
    ny
    97 540i6/850R Turbo
    HERE IS YOUR ANSWER.
    Distortion is a sign that you are overdriving your speaker.
    When you hear distortion,it means the magnet has no longer the ability to control the coil percisly.
    When that is happening,that means the the coil is also heating up and most likely turning red like your cigarette lighter.
    Sometimes the coil will burn 1 winding and the speaker will die.Sometimes it will play distorted for a long time before it gets hot enought to burn the coil to death
    The more distortion there is,the more heat yuor generating because that is basicly the limit of the speaker.
    You will smell band aids as a warning.Shortly after it will die.
    Distortion per say,dont cause the speaker to overheat.
    The actual Killer is the power that is being pushed into that it can not control or dicipate.
    Its not like distortion will make the coil bounce side to side and hit the windings.
    One more thing I would like to add is about amplifier gain/sensitivity
    If you have adjusted your amps as stated above,then you prly experienced some blown amps after time.Although I have done it that way for 20+years,its not the smartest thing to do.
    The best way to adjust your gain is to measure your output of the Rca in your headunit
    Then adjust your input sensitivity accordingly,because thats what it is.
    An input gain or sensitivity Switch is
    Made to boost low signals
    And
    And regulate high ones.
    WHat about line drivers and epi centers you ask? They boost Db and Hz not Mv/milivolts
    or V/Voltage
    The best step by step instructions would be to google
    JL audio 1000/1 intstall manual.
    It has pics and step by step instructions.
    In closing
    If you eat fries and you dont feel them inside you travel from the top of your throat to the point where they drop into your stomach,then you havent experinced bass. I miss that!
    1997 540i/6
    Glacier Green
  14. #39
    Parsippany, NJ, USA
    328I, 1999.
    Quote Originally Posted by Jason@BavSound View Post
    Let’s Add Some Low End
    Now is the time, if you are adding multiple amplifiers, to tune your subwoofer amplifier. Remember to roughly set your low pass crossover around 90-150hz. For example, if you set your low pass crossover to 100hz, that means that all frequencies above 100hz will not be sent to that particular output channel (speaker).
    If you also amplified your interior speakers, it is important to overlap your crossover points to ensure that there no significant gaps in the frequency response of your audio system. For example, if you set your high pass crossover for your interior speakers at 110hz, you need to set your low pass filter for your subwoofer at a minimum of 110hz, but not more than 120hz to keep an overall tonal balance in your BMW.
    Again, with your gain(s) turned all the way down, begin to turn the volume of your source unit up until you reach the point where the interior speakers are distorting ever so slightly.
    Now, back down the volume until the distortion disappears and stop there. Head back to the trunk and slowly begin adjusting the gain(s) of the amplifier until you are content with the amount of bass being produced by the subwoofer without any audible distortion of the woofer. Also, make sure the clipping light on the amplifier is not illuminating. If it is, back the gain(s) down until the light ceases to flash. Now, as you adjust the volume of the head unit, the bass will adjust proportionately with the rest of your music.
    What about the bass and treeble at the head unit when checking for distortion at the interior speakers? Also, what about the bass boost at the amp while adjusting gain and checking distortion at the woofers? Should we do the gain first of the bass boost?
    I just added a mono channel amp and using the stock amp for the speakers. I have no idea what is the corss over of the stock amp is for all the original speakers, tweeters and midbass. Can I or should I modify it too? Where should i keep the corss over of the new amp for the woofers?
    umermariner
  15. #40
    Nov 2008
    Idaho/Cambodia
    e36 2 door coupe 1997
    Quote Originally Posted by umermariner View Post
    I added a Rockford fozgate mono amp to my stock system also with 2 600w 10" subs . And I have a Kenwood head unit with the sub output running my added sub. I'm totally lost on adjusting this??
    Also I have a stock amp and the Harmon Karmen amp what one is better?
    does one have more channels then the other? the stock show 10/35W 10 channels? the karmon shows nothing
    Brian Idaho /Cambodia
  16. #41
    Jun 2006
    The Eagle's Nest
    bf.c e34 contour
    let's toss this one in the bin...
    or the first post should include the following
    1:
    2: http://www.bcae1.com/
    3: Google search DMM gain setting.
    and distortion does not kill speakers... otherwise most modern music would cause speakers to spontaneously combust.
    this thread is neither fish nor fowl... why is it even stickied?
    serves no use for experienced people and is over the heads of rookies.
    if he feels it is a great writeup he can put it on his website and/or we'll include a link in the useful links sticky to it here... it does not need to be stickied in this forum... especially as poorly written and technically inaccurate as it is.
  17. #42
    Apr 2009
    Buena Park
    2002 325i
    fix your wiring bro to sky11
  18. #43
    ITALY-NAPOLI
    bmw E30 cabrio
  19. #44
    Mar 2010
    中国
    CRV
    Replay
    Do you have encountered such situations:Have many of DVDs,especially some favorite,however you don't know how to enjoy them on your portable devices or other hard disc.Such as on iPhone, iPhone 3G, Sony PSP, PS3, YouTube (web), iRiver PMP, Archos and PMPs;And also don't know how to share them on the Youtube,myspace etc.
    Well before I also met these issues,through my friends recommended,I knew the powerful DVD Ripper for Mac.This kind of conversion software can help you solve above problems.In addition
    to this,It provides you a series of powerful and easy to use movie edit functions such as triming,cropping frame size,merging,adjustin effect,choosing subtitle,etc.
    So if you have the same trouble,I really hope my recommendation can help you.
  20. #45
    2006 330i Mystic blu
    The nasty noise created by amp clipping will fry a speaker in a second. MO' POWA' PLEASE!!
  21. #46
    Jun 2006
    The Eagle's Nest
    bf.c e34 contour
    Quote Originally Posted by attack eagle View Post
    1:
    I again request a thread lock on this poor aborted fetus.
  22. #47
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    I have an adjustable line output converter, amp, and my sub. How do i know what to set the line output converter to?
  23. #48
    Apr 2012
    dallas, texas
    1998 bmw m3 coupe
    thanks for the writeup, it really came in handy
  24. #49
    Jun 2012
    Fresno,ca
    1989 BMW 735i
    Nice
    Post
  25. #50
    Jan 2013
    jaipur
    alto
    AC Compressor
    According to expert, repairing just about anything on an automobile can appear a discouraging job best left to the professionals. However, with having some knowledge, a few simple tools, and a willing power to get your hands dirty, the savvy car holder can make preservation, save money. In this way, you will get knowledge and some satisfaction at working with your hands. It is really not an easy task to change AC Compressor easily, but it can make easier with some tools and previous knowledge and work experience
