Results 1 to 2 of 2
Thread: New E46 M3 Street Camber / Caster Plates from Turner Motorsport
    Mar 2001
    Amesbury, Massachusetts
    BMWs and Mini's
    Pricing will be updated early next week on this product. The TMS stock style caster-camber plate is designed with a custom urethane bushing to be used either with the stock or PSS9 front strut/spring assembly. Installation is to simply replace the stock strut bearing with our assembly (reuses stock spring perches and bearings). Every dimension of our camber plate kit is based on the stock strut bearing to ensure a perfect fit. Camber has a wide range of adjustment, from stock to a full race setting. These plates are the result of several months of design and testing. Detailed settings and combinations will depend on each car’s suspension geometry. These plates are also easily interchangeable with our E46M3 Race camber plates. This is a great option if you ever desire to go further to a more solid race suspension, as they utilize some of the same parts. There is NO other camber plate like this on the market.
    <ul>
    <li><span style="mso-list: Ignore; font-size: 9.0pt; font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol; font-weight: normal"></span><span style="font-size:9.0pt;font-weight:normal">Custom
    TMS designed urethane bushing specifically for this kit.</span></li>
    <li><span style="font-size:9.0pt;font-weight:normal">Several choices of
    durometer (hardness) are available for your specific needs.</span></li>
    <li><span style="mso-list: Ignore; font-size: 9.0pt; font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol; font-weight: normal"><span style="font:7.0pt &quot;Times New Roman&quot;">&nbsp;</span></span><span style="font-size:9.0pt;font-weight:normal">Completed
    stress analysis for flow characteristics.</span></li>
    <li><span style="font-size:9.0pt;font-weight:normal">Undergone deflection
    tests.<span style="mso-spacerun:yes">&nbsp; </span>Lower durometer bushings
    are currently going through a million cycle fatigue test at PSS9 shock
    forces. </span></li>
    <li><span style="font-size:9.0pt;font-weight:normal">Bushing is replaceable. </span></li>
    </ul>
    <p><a href="http://www.turnermotorsport.com/image/suspension/e46m3_street_camber_plate_instructions.pdf" target="_blank"><img border="0" src="http://www.turnermotorsport.com/image/logos/pdf_logo.jpg" width="20" height="20">Click
    here for more information and installation instructions.</a></p>
    Turner Motorsport
    / // Parts and Performance for BMWs
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
    info@turnermotorsport.com
    Mar 2001
    BMWs and Mini's
    2nd batch is now in, thanks for all the orders.
    <div align="center">
    <center>
    <table border="0" cellspacing="1">
    <tr>
    <td>
    <p class="MsoNormal"><span style="font-size:9.0pt"><b><u><br>
    General Information</u></b><br>
    Race camber plates (with solid spherical bearings) are great for the
    track, but what if you want to drive your car on the street too?<span style="mso-spacerun:yes">
    </span>That’s what the TMS E46M3 street style caster/camber plates
    are:<span style="mso-spacerun:yes"> </span>A plate you can use on
    the street, still have the available adjustment of a race camber plate,
    and not have to put up with a harsh ride or replace the bearings every
    season.<span style="mso-spacerun:yes"> </span><o:p>
    </o:p>
    <br>
    <br>
    The E46M3 STOCK strut mount only allows about ½ ° camber adjustment
    and no caster adjustment.<span style="mso-spacerun:yes"> </span>For
    most track cars or street cars that occasionally see the track, that is
    not nearly enough.<span style="mso-spacerun:yes"> </span>The stock
    strut mount is also set at an angle that is suited only for that
    position, and puts additional bending load on the strut if it is not in
    its original position. <span style="mso-spacerun:yes"> </span>The
    TMS Caster/Camber Plates allow significant camber adjustment from
    approximately <span style="mso-spacerun:yes"> </span>-1.2°
    to -3.85° and allows for the needed strut angle change. <span style="mso-spacerun:yes"> </span><o:p>
    </o:p>
    <br>
    <br>
    </span><i style="mso-bidi-font-style:normal"><span style="font-size:8.5pt">***Note:
    Each car’s suspension setup/geometry/ride height will be the limiting
    factor on range of movement.<span style="mso-spacerun:yes"> </span><o:p>
    </o:p>
    <br>
    <br>
    </span></i><span style="font-size:9.0pt">Our Plates directly replace the
    stock strut mount, and incorporate a replaceable custom designed
    urethane bushing.<span style="mso-spacerun:yes"> </span>The stock
    spring perch and bearing are retained in the assembly, allowing this
    part to be used with stock or aftermarket struts, such as a Bilstein
    PSS9 kit.<span style="mso-spacerun:yes"> </span>Basically,
    this is a must for any one who will be auto-crossing, going to track
    days, or doing any performance driving, and still needs their car as a
    daily driver.<br>
    <br>
    </span></p>
    <div align="left">
    <table border="0" cellspacing="1" width="600">
    <tr>
    <td>
    <p class="MsoNormal"><span style="font-size:9.0pt"><o:p>
    </o:p>
    </span></o:p>
    <img border="0" src="http://www.turnermotorsport.com/image/suspension/susp_e46m3_camber_side_view.jpg" width="300" height="239"></td>
    <td>
    <p class="MsoNormal"><span style="font-size:9.0pt"><b><u>Manufacturing</u><br>
    </b>Each part of the TMS caster/camber plates is CNC machined
    from aircraft grade aluminum billet.<span style="mso-spacerun:yes">
    </span>All aluminum pieces were then coated to MIL-A-8625F Type
    III spec hardcoat anodizing.<span style="mso-spacerun:yes">
    </span>Each steel part was either powdercoated or nickel plated
    to QQ-N-290A Grade F specifications.<span style="mso-spacerun:yes">
    </span>High grade hardware is used and main internal threads are
    helicoiled to add strength and life.<span style="mso-spacerun:yes">
    </span><o:p>
    </o:p>
    </span></p>
    </o:p>
    The urethane bushing has been custom designed and manufactured
    specifically for this part and its required characteristics.<span style="mso-spacerun:yes">
    </span>It is now undergoing lifetime cycle fatigue testing.<span style="mso-spacerun:yes">
    </span>Real world testing was done using the TMS Red M3, and
    they are still being used.</span></td>
    </tr>
    </table>
    </div>
    <p class="MsoNormal"><span style="font-size:9.0pt"><b><u>Design </u></b><br>
    This product has been fully engineered and designed by Turner Motorsport
    R&D in–house.<span style="mso-spacerun:yes"> </span>The
    assembly is designed to directly replace the stock upper strut mount.<span style="mso-spacerun:yes">
    </span>Each piece has gone through stress analysis, and all movements
    were pre-simulated in CAD to eliminate any potential interference is<st1:PersonName w:st="on">
    sue</st1:PersonName>
    s.<span style="mso-spacerun:yes"> </span>The main goals for this
    product are:<br>
    </span></p>
    <ul>
    <li>
    <p class="MsoNormal"><span style="font-size:9.0pt">Large range of
    adjustment while still allowing caster and camber to be adjusted
    from the top without cutting the strut tower.<span style="mso-spacerun:yes">
    </span>Cutting of strut towers significantly reduce their strength. </span></li>
    <li>
    <p class="MsoNormal"><span style="font-size:9.0pt">Maintain proper
    strut angle at any position by not pre-setting the angle.</span></li>
    <li>
    <p class="MsoNormal"><span style="font-size:9.0pt">Provide proper
    orientation with a replaceable urethane bushing </span></li>
    <li>
    <p class="MsoNormal"><span style="font-style: normal; font-variant: normal; font-weight: normal; font-size: 7.0pt; font-family: Times New Roman; mso-list: Ignore; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol"> </span><span style="font-size:9.0pt">Minimize
    any noise associated with the urethane bushing</span></li>
    </ul>
    <p class="MsoNormal"><span style="font-size:9.0pt">The surrounding
    casing and bushing (internal and external) have been designed to work
    together to allow the proper strut angle to be maintained during
    adjustment, reducing the bending force on the strut itself, while
    offering longer life, and proper dampening.<span style="mso-spacerun:yes">
    </span>This was done through Finite Element Analysis to predict flow
    characteristics in different situations.<span style="mso-spacerun:yes">
    </span><o:p>
    </o:p>
    <br>
    <br>
    A scale for camber and caster has been laser engraved on the upper plate
    which will always be visible for adjustment, and the upper plate is a
    full round circle to better distribute the force on the strut tower so
    it is not compromised.<span style="mso-spacerun:yes"> </span>This
    has shown to be a problem on several BMW chassis’, including the E46.<span style="mso-spacerun:yes">
    </span>This TMS part will not accelerate strut tower deformation.<span style="mso-spacerun:yes">
    </span><o:p>
    </o:p>
    </span></p>
    <p> </td>
    <td valign="top"><br>
    <img border="0" src="http://www.turnermotorsport.com/image/suspension/susp_e46m3_camber_overall_view.jpg" width="202" height="400"></td>
    </tr>
    </table>
    </center>
    </div>
    Turner Motorsport
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
