<H4>SOLD.</H4>
<P> I bought this car at the beginning of the year to use as a track car while my E36 was being prepared. Because of my schedule, I only ended up using the car for one event. Now my E36 is ready, so I am selling this car.
<H3>1987 325is for sale.</H3>
Red, 2-door coupe, 5-speed manual transmission.<BR>
Local Raleigh, NC car. No damage or rust on body. Straight chassis.<BR>
Engine rebuilt by Metric Mechanic in December 2002.<BR>
Low mileage. Car has 123,000K miles. Recent tuneup.<BR>
All service records and receipts. Completely clear Carfax available.<BR>
Ready for track- No additional work needed.<BR>
Fully street legal.<BR>
Only three track events since engine rebuild.<BR>
Selling to fund E36 track car.
<P>VIN WBAAA1302H2323823
<P><B>Engine</B>
<UL>
<LI>New Metric Mechanic HiFlow Surface Turbulence (ST) Sport Cylinder Head (installed 12/02)
<UL>
<LI>Metric Mechanic Sport Camshaft
<LI>New valves, valve springs, valve seals, rocker arms, rocker shafts, eccentrics, etc.
<LI>Metric Mechanic blueprinted, ported and polished oil pump
</UL>
</UL>
ECU engine chip<BR>
New motor mounts<BR>
New timing belt and tensioner; new accessory drive belts<BR>
New water pump, thermostat, radiator cap, and hoses<BR>
New cap, rotor, plug wires, spark plugs, oxygen sensor, fuel filter, German fuel lines<BR>
All new gaskets, seals on engine intake and exhaust, oil pan, front crank seal, fuel injector O-rings- no leaks<BR>
<P><B>Suspension</B>
<UL>
<LI>New Turner Motorsports J-Stock suspension
<UL>
<LI>Specially-valved Bilstein shocks
<LI>Turner-branded progressive rate springs
<LI>Front camber plates
</UL>
</UL>
New Suspension Techniques 22mm front/19mm rear sway bars with mounting reinforcements<BR>
New Turner Motorsports rear sway bar reinforcement brackets<BR>
New Racing Dynamics front Strut Tower Brace<BR>
New BMP aluminum rear shock mounts with urethane bushings<BR>
New Urethane BMP offset (M3-style) control arm bushings.<BR>
New lower control arms<BR>
Professional 4-wheel alignment by The Digital Chassis.<BR>
<P><B>Drivetrain/Transmission</B><BR>
UUC Short shifter (adjustable height) with hard Delrin carrier bushings<BR>
New driveshaft guibo/flex disc<BR>
New rear transmission output seal and shifter linkage seal<BR>
New transmission mounts and transmission/engine snubber<BR>
Redline synthetic transmission and differential gear oil<BR>
<P><B>Brakes</B><BR>
Front Brake forced air cooling (Bimmerworld kit- removeable backing plates, hoses, and intake ducts in front spoiler)<BR>
Earle's Stainless Steel brake line kit<BR>
New brake master cylinder<BR>
Turner Motorsports "Cool Willy" front and rear carbon-Kevlar racing pads<BR>
New ATE front slotted rotors and new OEM rear rotors<BR>
<P><B>Safety</B><BR>
Autopower bolt-in rollbar with crossbrace and harness bar<BR>
Simpson Camlock 6-point harness (Sfi dated July '00)<BR>
G-Force Racing Gear Latch & Link 5-point harness (Sfi dated Aug.'02)<BR>
Summit Racing Driver's Race Seat
<P><B>Tires and Wheels</B><BR>
2 sets of stock 14x7 Basketweave alloy wheels
<UL>
<LI>4 Kuhmo Ecsta V700 195/55 R14 Race Tires
<LI>4 Dunlop Sport A5/ Pirelli P6 195/65 R14 Radials
</UL>
<P><B>Other</B><BR>
New Programma Service Indicator circuit board<BR>
<P>$7500.<BR>
<P>4 Toyo RA1 225/50 R14 Race Tires on 14x7 Stock Basketweaves available for additional $400.
<P>Pictures of all at http://home.nc.rr.com/dlamson/
<P>Email or phone with questions.<BR>
davidlamson@yahoo.com<BR>
(919) 667-1839(h)<BR>
(919) 314-4298 (w)
Sam Lamson
Durham, NC
1993 325is- GC/AD suspension; Stoptech BBK; Competition Cages rollcage; Dinan headers/exhaust
1995 325i- daily driver
1997 Ford E-350 w/Triton V10- tow vehicle
Click here to email me
Any chance you'd be willing to sell a set of wheels/tires separately? Specifically, I'd be interested in the set with the Toyo RA1's.
Just got back into town from a funeral. Funny you should ask that...
http://forums.bimmerforums.com/forum...d.php?t=272181
Sam Lamson
Durham, NC
bump.
Sam Lamson
Durham, NC
bump.
Sam Lamson
Durham, NC
bump.
Sam Lamson
Durham, NC
bump.
Sam Lamson
Durham, NC
Free bump, saw the car at VIR this past weekend. Very nice looking E30. (very tempting)
JP
NASA Fanboy
Appreciate the bump and the testimonial.Originally Posted by 155///MPH
The one school I ran with the car was the Tarheel BMW North Course event last July. It was particularly fun going up the North Course cut-through and down Roller Coaster through HogPen.
With the Toyo RA1s on the car, after making the right turn going up the hill, except for a shift to 4th, I could keep it floored all the way up to the top. Brake for the entry into Roller Coaster and then foot to the floor except for a shift to 4th and a quick brake going into HogPen.
With that Turner Motorsports J-stock suspension, the car handles great.
Sam Lamson
Durham, NC
