Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 74
Thread: FI Dyno Library
  1. #26
    Apr 2001
    FLA, PA
    98 SCed M3 Conv., 97 528i
    99 E36 M3
    Active Autowerke SC
    8psi
    93 Octane Pump Gas
    Mustang Dyno
    Stock Exhaust
    18" OZ Superleggera
    Weather Conditions: Hot and Humid (I will have to get more accurate info)
    06 MINI Cooper S
    97 E39 528i
    and another British Vehicle
  2. #27
    Oct 2003
    Austin, Tx
    1999 M Roadster
    Boostlogic turbo kit
    T61
    65lb injectors
    E-Manage
    17psi with 50/50 mix of pump gas and vp109
    Turbo '99 M Roadster
    11.49@130.4 and 570whp@16psi on a stock m52 shortblock.
    WTB: Low compression M52 pistons & GT30r or 35r
    FS: PT-67 DBB turbo, freshly rebuilt
    PM me with questions.
  3. #28
    Oct 2003
    COT
    NOP
    1995 M3, 65K miles
    Dinan PowerDyne SC Setup @ 5.5 lbs
    Full SuperSprint Exhaust
    3.73 Quaife Diff
    91 Octane
    UUC LTW FlyWheel
    e34 M5 Clutch
  4. #29
    Sep 2004
    astoria, or
    boosted 323is
    98 323is: aasc w/8lbs. of boost, m50 manifold, m3 cats, cat back exhaust
    2.8l engine swap, aa supercharger, m50 manifold, ///m cats swap, aa catback, fan delete, cdv delete, ///m roadster shifter, 18" wheels, ///m vaders, push button ignition, bilstiens with h&r sports, clear front and back corners,depo's with thinlines and 6k prolumens
  5. #30
    Nov 2003
    Los Angeles, CA
    '04 M3, '95 318, '03 R6, RIP: '99 318TI, '01 M3
    95' 318 IS DASC and some extras ...
    There are so many to count, but I will try my best.
    272 Cams with 10.5 Lift
    Titanium Valve Springs and Seals
    Head Stud Kit (Helps with the 11PSI)
    BMP AFPR (Sucks but does the job for now)
    Head ported and polished including valve guides.
    36.5 Lbs Fuel Injectors
    Custom built CAI, drafts from the brake duct.
    Split Second Mass Air Flow Meter Conversion w/ ARC II
    Custom Software (I don't know if this helps it was built for the original car with just the blower)
    M3 Brakes Complete
    BBS LM 18X8.5 225 40's up front, 235 40's in the rear
    Koni Coil Over Kit
    TC Kline Racing springs and adjusters.
    DASC Pulley Up Grade to 11 PSI (Full Boost 3500 RPMS)
    I.A.A.S. Air/Water Intercooler
    RD Sport Sway Bars
    UUC Short Shift Kit II
    RMS Exhaust
    Custom Oil Cooler
    I am sure there is more, but this all I can think of for now.
    Here is my chart.
  6. #31
    Nov 2003
    Los Angeles, CA
    99' 318 Ti W/ Dasc
    Stock car with the Downing Atlanta Supercharger Kit vs. Stock
  7. #32
    Oct 2002
    San Mateo, CA
    98' M3
    98' M3
    Technique Tuning Stage 2 @ 13psi
    3" Exhaust
    Spec Stage 3 Clutch
    91 Octane
    71 Degrees Fahrenheit
    36% Humidity
  8. #33
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    97' M3
    AA Stage I Gen III @ 7.5psi
    Custom Exhaust
    Spec Stage 3 Clutch
    93 Octane
    90 Degrees Fahrenheit
    37% Humidity
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  9. #34
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    1999 M3
    Vortech SC
    10.2 psi
    Euro HFM
    Technique Tuning software and HFM Harness, injector
    93 Octane
    RMS Aftercooler
    80 degrees
    Head and Blower rebuild
    ___________________
    Paul E
    '11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
    http://s11.photobucket.com/albums/a173/boostm3/
  10. #35
    Feb 2001
    Blue Mounds,Wi
    97 M3/4, 06 M5, 03 X5
    10 PSI with W/A injection, Schrick Cams, AA Tuning, Track Pipe
    1997 BMW M3/4 Cosmos Black Luxury Package 437whp 378 ft/lbs torque Dyno Dynamics Dyno
    10 psi Stage III KO Performance Vortech supercharger,
  11. #36
    Jun 2005
    south
    85 318i
    1985 318i
    1978 2.0 bottom end
    1985 1.8 head
    294 regrind cam
    SS valves double valve springs
    91mm JE pistons
    lightened and polished stock rods
    TO4B, custom turbo header
    3.5 liter throttle body
    Centerforce pressure plate with 3 puck solid hub
    Megasquirt II ECU w/EDIS4
    Dyno runs with 100 octane
    Green 15psi
    Blue 15psi with 40 shot of nitrous
  12. #37
    Mar 2001
    New Jersey
    97 M3 99 Z3M
    1997 M3
    Technique Tuning Stage II
    3" Technique Tuning exhaust
    M50 Manifold
    93 Octane
    Evosport Pullies/Spec Stage III clutch
    115k miles
    8 psi (348whp)
    13 psi (414whp)
    ~78 degree dyno room temps
    1997 M3
    1999 Z3 M Coupe - Turbocharged
  13. #38
    Port Orange, Florida
    '07 AM, '06 X5 4.8is
    1997 M3
    Dinan Powerdyne Kit
    9 PSI tested (10PSI on the road)
    W/A Injection
    LTW Flywheel/Clutch
    Headers
    93 Octane
    Tri-Flow Exhaust
    Plasma Coils
    78k miles
    73 degrees/13% Humidity
  14. #39
    Jun 2003
    Hockessin, Delaware
    99M3, 97NSX, 03S600, 04RX330, 04Dakota, 01 3.2TL
    ICS Build, NickG tuned SC S52. OEM Cams & Cats
    editted, updated.
    1000rwhp J/K. 441, and will provide another run with the boost hooked up
    Engine & Driveline: ICS Stage 4 SC * 8 Rib * 15+psi * xx# injectors * Schrick Cams * Larger HFM * Port & Polished Head * 3 Angle Valve Job * VAC MLS .140 HG * E36TD Fan Setup * Shorty Headers * Track Pipe * UUC UDPs * S54 Oil Cooler * OEM S54 Radiator * S54 Guibo * Stromung Exhaust * ACS Delete * UUC SSK * Rouge WSR * UUC TME
    Chasis Tuning: GC COs * UUC Sways * X-Brace * Rouge RSM * GC RTAB * AA DSB * Z3 Steering Rack * BBS RC 18x8.5 ET38/ 255/35/18s @ all 4* Front Strut Brace * RaceLogic * 3.38 LSD
    Exterior: DEEP BLACK PAINT * Rolled Fenders * Custom Vented Hood * RD Diffuser * Red DDEs * 8,000K HIDs * Smoked Markers
    Coming Soon: Finish ICE * 6-sp Trans * 6 Pot 13.6 Fr, 4 Pot 12.9 Rr BBK
    4 Sale: M3 S52 Cams * M3 Rear Seats * 99 M3 Fan&Clutch, Intake Manifold, Headers * Alum Therm Housing * 42# Injectors * Dresmann Rear Kit * Tilton/ICS Flywheel & Clutch * LED, Smoked & OEM Taillights * & More
    Wheels & Tires: Custom 18x8.5 BBS RCs * 3 17x8 Grey OZ Superleggeras * RD RGS 17x8
  15. #40
    Chicago
    '99 M3
    T4 60-1 HiFi
    M50
    3'' Exhaust
    6 vs 8psi
    TEC-3R, T4 GT40, WISECO, EAGLE, SUPERTECH, O-RING'D "FRANKENSTEIN" STROKER.
  16. #41
    Cali!!!!!
    a
    1998 Z3 AA Stage II turbo, with TD06-20g (which btw, can't seem to hold high boost )
    Custom tuned by NickG@TechniqueTuning
    Porsche TT 3.5 HFM
    ICS 3" custom turbo exhaust
    UUC Stage 2 clutch setup w/ SPEC Stg II clutch
    440 cc injectors
    93 octane pump gas
  17. #42
    Jun 2003
    Hockessin, Delaware
    thought I'd park here what my car does at about 14.5 psi
    478rwhp
  18. #43
    Jan 2006
    Ft.Lauderdale, FL. USA
    Turbo M roadster, z3 1.9l s/c
    1997/z3 1.9l,
    Midnight Autoworks Eaton roots supercharger
    10.5 psi,
    Midnight Autoworks stage 3(42lbs injectors, 3"hfm, water/alc injection, etc..),
    93 octain
    Straight water in the injection tank
  19. #44
    Jul 2002
    Phoenix, AZ
    95 Turbo ///M3
    TT stage2 1995 M3
    Technique Tuning Stage 2 1995 M3
    TT exhaust
    60 degrees F.
    91 Craptane
    13.5 psi
    408RWHP/359LBFT Torque
    Lotus Elise: A pure sport car. A true enthusiasts car. It's no muscle car nor grand tourer. Purely a featherweight with no unnecessary driver aids that take away from the driving experience. No dynamic stability management. No active yaw control. No magnetic self adjusting dampers. No electronic brake distribution. No traction control. No throttle by wire. No all wheel drive. No sequential paddle shifters. No power steering. No power mirrors. No heated 8-way power seats. No sound deadening materials. No cruise control. No cup holders. Sure, it's small, loud and impractical. If you want quiet, buy a Lexus. If you need to haul a lot of stuff, get a minivan. If you need to stretch out, rent a limo. But if you want to go fast, seriously fast, sit down, strap in, shut up and hang on.
    1995 Technique Tuned Turbo M3
    2005 Lotus Elise
  20. #45
    Sep 2001
    NJ
    99 M coupe
    Technique Tuning Stage 3: up to 20psi
    The highlights of the build include:
    CP Forged Pistons (8.5:1 CR)
    Arrow Connecting Rods
    M50 intake manifold
    Garrett GT35R (T04E 0.60 A/R Compressor Housing / 0.82 A/R Turbine Housing)
    Plus other assorted goodies…
    The result: 514rwhp/500rwtq on 93 pump gas
  21. #46
    Nov 2002
    FL
    bmw 325i turbo
    up date
    Quote Originally Posted by turbojunky
    Bmw 325I
    1994
    A&A turbo Stg 2 +
    10 psi
    fuel 93 oct..
    new Info
    A&A turbo STg 2+
    14 psi
    93 oct
    Master Power super 70
    428.81 whp , 407.46 rwt
    10 psi 346.69 whp, 348.64 rwt
    stock motor 3.2 l
  22. #47
    Mar 2004
    San Jose, CA
    2000 M-Roadster
    1st run: SAE HP 286.4, Torque234.1 ft/lb
    2nd run: SAE HP 281.4, Torque 230.6 ft/lb
    3rd run: SAE HP 276.6, Torque 234.4 ft/lb
    4th run: SAE HP 284.2, Torque 243.7 ft/lb
    Average peak HP (6900rpm): 282.2 RWHP
    Average peak Torque (4750rpm): 235.7 ft/lb
    AFR
    15.0 @ 3000rpm
    14.0 @ 5000rpm
    13.0 @ 6000rpm
    12.0 @ 6900rpm
    Temp: 63.7 °F
    Dew Point: 49.6 °F
    Humidity: 60%
    Preasure: 29.93 in / 1013.4 hPa
    Make: (BMW.......Duh! )
    Year/Model: 2000 Z3 M-Roadster
    FI setup: Dinan Supercharger (100% Dinan setup and installed by Dinan)
    boost level: (I believe between 5 and 6psi)
    extra mods: None
    fuel type/octane: 91
    Dyno: Dynojet 248H high inertia chassis dynamometer
    Dyno test performed using 3rd gear
    Dynospot Racing (DSR)
    1798 Angela Street
    San Jose, CA 95125
  23. #48
    Jun 2005
    south
    85 318i
    85 318i
    M10
    Custom Turbo
    26.9 psi w/75 shot
    50/50 mix of 93 & 110
    My manifolds powering 8sec and over 1000rwp cars
    Home of the highest HP stock M30 in the world 550rwhp/622rwtq
    1/4 mile---> 9.81 @138 C4 Auto
    10.08 in car vid --->https://youtu.be/OiinFhUomjg
    Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
  24. #49
    Jun 2006
    winchester va
    couple boosted bmws
    Year/Model: 1994 325i
    FI setup: Dinan Supercharger rms software
    boost level: 6-9psi
    extra mods: no cats-m3 muffler
    fuel type/octane: 93
    Dyno: Dynojet
    Horsepower:rwhp 244.04
    Torque:rwtq 210.46
    To get my dyno sheets click below my post count on zoints and there in my photo album.
    Man there are some bad cars on here!!! Great job to everyone of you!!
  25. #50
    St Louis area
    98 540i6 supercharged
    468 hp 540i
    1998 BMW E39 540i with a 1999 E38 740i VF supercharger.
    407 rwhp
    custom exh w/X pipe.
    Mods Supercharger, 4XX rwhp
