Hey Guys,
Total noobie here, even posted this up in the wrong forum! This looks like really cool forums with a lot of knowledge. Just as a bit of background I tend to make big jobs out of small ones, well anyway, my steering wheel squeeks, the guy at the dealership said it just needs some grease on the contact, but I thought that once I had the wheel off, I would pull the cluster and install some white-face guage faces and stainless trim rings. Are there any pitfalls to doing this?, what should I know about going into something like this?
Thanx very much!
ooohh '93 525it 110,000 miles auto trans....
Mostly you must disconnect the battery before removing the airbag / cluster. If you don't disconnect the battery, you'll trip the SRS light and it can only be reset by the dealer.
1986 BMW 735i Turbo, 5-speed
2010 Mazda5
1966 Corvair Sedan
Get a Bentely Manual. Also be very very careful removing the speedo Needles. You can use a fork ( believe it or not BMW has a tool for this). Other than that the Bentely can guide you through the entire process....
theDogger
<img src="http://bigfootdesigns.com/bimmer_forum/main.jpg" width="375" height="167">
| 98 ZF320 5-Speed Tranny | UUC Clutch | UUC Flywheel | UUC EVO 3 | UUC DSSR |
| UUC Tranny Mounts | JC Chip | ECIS CA | Koni Adj. Struts & Shocks | Grunt Bushings |
| Eibach Prokit | AC Schnitzer Sways | AC Schnitzer Type III 18x8.5 | Full AC Schnitzer S5 Body Kit |
| Nitto 555 245/40x18 | Hella Schwatz Euro H1 Headlighs |Hella Smoked Tail Lights|
| Remus Exhaust from Headers | Alpine 7998 | 2-Kicker L712 Sub | Kicker RS 6.5 | Kicker RS 5.25 |
| Kicker RMB 6.75 | Kicker KX 650.4 | Kicker KX 600.1 | Kicker SX 400.2|Kicker KQ 30 EQ |
| Stinger Expert Cap | Stinger Expert Accessories | Clifford G5 | 99 s52 Turbo eta – 02/06 |
~AIM- liquidtiger720 ~ Josh M. ~www.jmscribble.com
sweet, thanx guys!
In My '92 525, I've got no airbag , its no problem removing the instrument cluster without removing the wheel. Just flip it towards you, "lay" it on the steering wheel and turn the steringwheel left till you can get the cluster out
