Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 148
Thread: Interesting Reading about BMW OIL facts long
  1. #51
    Aug 2003
    san diego
    97 BMW M3, 08 VW Rabbit S
    Quote Originally Posted by turrokk
    in Russia we use Castrol RS 10w60.. It's the best choice (and the most expensive). I changed my Mobil to RS and was really surprised by the engine sound change (a lot more.. ummm.. BMW-mish!) and slightly better mileage. RS is definately the best oil for BMW motors!
    in russia after we change out oil we dump it into our neighbors lawn..
  2. #52
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    >>Time to change out my Mobil 1 5w30 syn....no wonder I have to fill up the engine a lil bit here and there ...must be burning a some oil GRRRRRR<<
    Yea... I laid in 2 cases of the Mobil 1 10W-30 to use after my Amsoil 10W-40 is used up.. This amsoil IS ACEA A3 rated, And has a good hi temp sheer rating, but i have only 1 change worth left. Its been costing around $5.25/qt I think, plus shppg. I got the MObil 1 on sale. But after reading this, and realizing I like to change the oil in conjunction with the srvc lights, with a filter change halfway through, I figured id better either stay with the amsoil, OR, find another, less expensive ACEA A3 rated oil. Enter the BMW synthetic 5w-30! I used to buy this stuff for about $3.50, and with a good ACEA and HTHS rating, I think Ill switch to that, after selling my Mobil 1 10W-30.
    So much of the oil info just keeps changing. Not too long ago, when the Group IV base stocks were being promoted heavily, it was also being said that you should Avoid oils with Big viscosity spreads, like 0W-40, 15W-50, etc. It was said that they would degrade faster around the edges, ie, after testing, it was found they no longer tested out with the wide range; for instance, the 15W-50 might test like a 15W-40 or less.
    However, iM now liking what Im hearing in this thread; ie, for longer useage patterns like I use, main things to look for are the ACEA A3 ratings, and, the HTHS rating of 3.4 or higher. The BMW 5W-30 fills the bill nicely, and its priced right.
    ___________________
    Paul E
    '11 AW 135i ; Sold: '99 White M3 81k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold & stock cats); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust, clutch; Fikse FM-10s; Koni Suspension; Stealthboxes
    http://s11.photobucket.com/albums/a173/boostm3/
  3. #53
    Jan 2003
    Irvine, CA
    '03 M3 SMG, '96 M3
    How does amsoil 10w-30 compare to Mobil 1 5w-30 and Factory BMW Synth 5w-30? What is the difference in quality and performance for so-cal weather? Is the difference negligible from 5w to 10w? I 'm a newbie when it comes to oils.
    Would you guys recommend me change to Amsoil 10w-30, or continue using mobil/castrol 5w-30?
    go here if you are interested in cheap cases of Amsoil 10w-30 (XL-7500) synthetic oil
    http://forums.bimmerforums.com/forum...ghlight=amsoil
    '03 E46 M3 SMG Silver Gray
    ///Performance: AFE stage II intake, Magnaflow cat-back ///Interior: Silver CF Royal style paddles ///Suspension: Eibach pro-kit
  4. #54
    May 2003
    Birmingham, AL
    m3
    I just switched from M1 5w-30 to 0w-40 and i have to say the engine seem quieter.
  5. #55
    Mar 2004
    FL
    97 M3
    I saw Mobil 1 0w-40 being advertised as a "european car formula". Im a sucker for marketing.
    But IM SCARED that the 0w-40 is too thin for my 90k 328.
  6. #56
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    The 0W-40 IS a European formlation.. Look at the ACEA A3 rating! Other than the 15W-50, no other MObil 1 has it! Matter of fact, I sold my 10W-30 mobil 1, and loaded up on 0W-40 for this precise reason. It used to be thought that a wide viscosity range, like this 40 points, was an issue.. But with today's engineered synthetics, I dont believe that to be valid any longer. Plus, the rating allows this oil to last longer without breaking down.
    ___________________
    Paul E
  7. #57
    Manila, Philippines
    E36 320i
    Uh, I have Mobil 1 5W-50 with SuperSyn and on the bottle it says:
    "Meets API SL/SJ/CF and ACEA A3/B3/B4.
    Approved against MB 229.3 and VW 505.00
    Porsche Approved"
  8. #58
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    Ok, well thats fine then.. Add that do the mobil 1 0w-40, and 15W-50 with ACEA A3 ratings. I didnt know Mobil 1 came as a 5W-50, because if you go to the following site: http://www.mobil1.com/index.jsp
    It says:
    Exceeding Standards
    Mobil 1 with SuperSyn™ is available in five viscosity grades:
    Mobil 1 with SuperSyn™ 10W-30 – Higher-Mileage Vehicle Formula
    Mobil 1 with SuperSyn™ 5W-30 – Newer Vehicle Formula
    Mobil 1 with SuperSyn™ 15W-50 – Performance Driving Formula
    Mobil 1 with SuperSyn™ 0W-30 – Enhanced Fuel Economy Formula
    Mobil 1 with SuperSyn™ 0W-40 – European Car Formula
    You note that there is no mention of your 5W-50.
    ___________________
    Paul E
  9. #59
    Manila, Philippines
    E36 320i
    Yeah, it's weird.
    In the FAQ section of mobil1.com is the explanation.
    Q:Why do Castrol and others market SAE 5W-50 grade synthetic motor oil while ExxonMobil in North America does not? Does SAE 5W-50 offer advantages?
    A: SAE 5W-50 is not recommended for the vast majority of newer cars sold in North America. They are designed for SAE 0W-30, 0W-40, 5W-30 and 10W-30 grades...and this is what car manufacturers recommend.
    But I'm happy to note that it's the factory fill for the Mercedes-Benz SLR McLaren
    Mobil 1 Named as Factory Fill and Recommended Service Fill Lubricant for New Mercedes-Benz SLR McLaren Sports Car
    Fairfax, Virginia USA (October 20, 2003) -- -- Mobil 1 with SuperSyn(TM) anti-wear technology, the world's leading synthetic motor oil, has been named by Mercedes-Benz as the recommended engine oil for its recently released 626 horsepower Mercedes-Benz SLR McLaren sports car. Each car will leave the factory filled with Mobil 1 5W-50. The announcement was made at the Frankfurt (Germany) AutoShow.
    Purchasers of the SLR McLaren will see the words "Recommend Mobil 1 5W-50 oil" when they examine the Mercedes AMG-developed V8 high-performance engine.
  10. #60
    Sep 2004
    St. Petersburg/Russia
    E36 323i Sedan
    Quote Originally Posted by e36m3_858
    is that a joke? if so, please tell me when to laugh..
  11. #61
    Portland, Oregon
    C63 AMG 507 Edition
    Quote Originally Posted by Buthski
    Just wondering how much oil should be added during an oil change. I've got a 97 M3 and I've heard anywhere from 6.3 quarts to 7.5. I've heard a lot of people saying 7 quarts, but I want to be sure that it's OK. I don't track the car or anything. It's just my daily driver. Thanks for the help.
    7 quarts is fine. Check the dipstick and see, but 7 is what I do. Also check your oil level regularly. If you redline at lights and top out a lot, you can burn a lot of oil quick. I check my oil level twice a week.
  12. #62
    Mar 2002
    Newington, Ct
    '99 Alpine White M3
    >>Yeah, it's weird. In the FAQ section of mobil1.com is the explanation.<<
    There 'explanation' doesnt address the fact that, aside from the 0W-40 and 15W-15, they DO make one more ACEA A3 rated oil, 5W-50, but they DONT list it in their spec sheets and materials.. you have to go to press releases and the like to even know that they make it! I dont recall ever having seen it in the stores.. Do you have any trouble finding it? Are they having as much trouble putting it on the shelves, as we are in finding out anything about it from there materials?
    ___________________
    Paul E
  13. #63
    fake suburban environment
    e30m52 325iT E30 E70X5
    guess ill stop using mobil 1 10-30 and go to the 0-40...
    thx guys
  14. #64
    Quote Originally Posted by paul e
    It says:
    Exceeding Standards
    ive tried the 15-50 in hot summers
    seemed to work good
  15. #65
    Nov 2002
    Silver Spring - Maryland
    94-325i
    It is Castro, not Mobil1.
    Quote Originally Posted by kermit
    Porsche Approved"
  16. #66
    Raleigh, NC
    2003 BMW M3 Steel Grey
    but its like a different language.... so which one do you suggest if you were going to change your oil?
    Unless you have an M3, in the following order:
    1) Mobil 1 0w-40,
    2) Mobil 1 0w-40, and
    3) Mobil 1 0w-40
    Why does this say "unless you have an M3" use mobil 1 0w-40 ??? am i the only one who saw this?
  17. #67
    Jan 2003
    San Luis Obispo, CA
    18 M3, 15 x5, 67Mustang
    I've always ran Mobil 1 15-50 in both my M3s. I never have lifter tick and they have both ran awesome with zero problems of burning oil at all. It never gets below 35 degrees here so I have no worries about low temps. If I were only driving in warmer temps I wouldn't run anything but the 15-50. It has served me very well. When I did cams on my white car my mechanic commented on how good my cam blocks looked when he took the cams out. He said he usually sees some scoring, he attributed it to short oil change intervals usually around 2-3k miles sometimes less and good oil.
  18. #68
    Media,Pa
    660 Raptor
    Porsche Approved"
    Castrol 5w-50 syntec says that and BMW approved, must be the sponsership
  19. #69
    Nov 2002
    94-325i
    Yes it is. BMW 5w-30 makes by Castrol. Castrol also has 10w-40 which support A3/B3.
    Quote Originally Posted by M3fun43
  20. #70
    Sacramento,CA
    E46 M3/F25 X3/XKE/356/VW
    In Soviet Russia, the oil changes you!
    --Thom
  21. #71
    Aug 2002
    LA
    e36 M3, e36 325i
    The guy who bought Mobil 5W50 lives outside of US. Mobil 1 5W50 does exist and it is factory fill on McLaren SLR. Castrol 5W50 here is only a group 3 oil, not group 4 like all mobil 1. There are so much more choices on oil outside of US such as Agip, HKS...... We get the crappiest stuff here where they even call hydrocracked dino oil "synthetic".
    <font size="1">97 M3 coupe dakar yellow/ alcantara
    UUC TME, UUC Comp Evo SSK w/ delrin carrier bushing & cartridge bearing, BBS RX 18", H&R coilover, euro clears, AC roof spoiler, RD sway bars, RD strut bar, X-brace, Ground control street stability kit (rear trailing arm bushing enforcer), e46 M3 RSM, Z3 reinforcement plate, Hamann kidney grille cover, OEM trunk spoiler, Schrick intake manifold, fan delete mod, underdrive crank pulley, debaffled & euro snorkel and K&N drop-in, UUC system-U DTM exhaust, glove box motorsport carbon fiber trim, AC pedals and knob, 35% tint, Zimmermann cross-drilled, EBC Greens.
    92 325i estoril blue M3 look
    Motorsport International badge M3 door mouldings, 97+ kidney grill, AA chip, fan delete mod, debaflled & euro snorkel and K&N drop-in, RD exhaust, RD trunkspoiler, AC roof spoiler, Euro M-Technic steering wheel, Rob magnum knob, strut bar, Eibach pro-kit, fr Bilstein sport, rr Koni SA, sport pack sway bar, X-brace, 97 M3 spec front control arm bushing & RTAB, updated front strut bearings and mount to newer style, short shift and UUC delrin carrier bushings, UUC pedals, UUC clutch arm bushing, Stillen slotted rotors, KVR brake pads, M Doublespoke II, euro clears, AC aluminum pin strip decal, 35% tint.</font>
  22. #72
    Massachusetts
    2000 Z3 M Roadster
    What about Shell Rotella 5W40? I saw other tests that said it was very good oil. No ACEA ratings at all. just CH-4/SL. I've used it for 2-3 yrs in all my cars and cycles with good results. I'm guessing it is group 3.
    MikeG
  23. #73
    Dec 2002
    Offshore GOM
    E36 M3's
    ANY Mobil 1 oil I've tried burns oil in my 95 M3. I've been using Castrol Syn-blend for a couple years now and hardly burn any oil at all. I'm curious how much Synthetic is actually in the Syn blend though. It's probably like a fruit juice -- sais "contains real fruit juice" on the label, then on ingredients sais less than 1% real juice!
    Dakar 95 M3 (4/95 manufacture)
    Techno Violet 97 M3 (12/96 manufacture)
    Alpine White 16 535i M-Sport (10/15 manufacture)
    _________________________________
    "I have no idols. I admire work, dedication and competence." -- A. Senna
    Illegitimus Non Tatum Carborundum
  24. #74
    Aug 2001
    Sacramento
    Too many.
    Quote Originally Posted by thomn8r
    I'll take "Family Guy" references for $300, Alex.
    (A variation on the talking car from the "There's Something About Paulie" episode)
  25. #75
    May 2001
    No Car
    hey guys, what about the mobile 1 0w-50 synthetic race oil? i saw some at autozone the other day. and it seems like a good idea actually, zero weight for good protection when cold and etc, and 50 for good protection and reduction of taps/ticks/knocks that are engines make. the recommended oil for our cars by dealership is 20w-50 anyways. what yall think?
