The R/S turn signal indicator is not working on the instrument cluster (L/S is fine) i checked/changed the bulb and it is good.All the outside turn markers work fine too,it is just that the indicator doesn't flash (this wouldn't be a big deal if i wasn't so anal retentive about keeping everything in proper working order!LOL) I also changed out the turn signal switch.Would the relay cause this type of problem or is it possiably a problem with the circuit on the cluster?Thanks for any suggestions.
--Johnny--
