just for cliarification... you have have Z M roadster?Originally Posted by DINANISR3
This kit will not work for you, unfortunately. We'll have to check into whether or not there is a clear LED kit for the Z3 M roadster.
The e46 kit prices are for the non roadster/z3 e46 bodystyle.
ie 2 door coupes - 330ci, 325ci, M3 only. Sorry.
$9.00Originally Posted by yellowbullet
On the carpet, door you want the floor carpet (the very bottom pieces) or the floor mats?Originally Posted by BMWManiac
part # description, MSRP, KO price
82-11-1-470-393
OEM - E36 M3 Convertible Embroidered Floor Mats (set) Black (item D in BMW lifestyles catalogue page 47)
$125.00
$93.50
check my fresh posting for other part numbers on floor mats for all other BMWs.
Can you answer my question please on the LED's????? I have an E46 too in our fleet. It is not my car that I drive so I dont list it as my car. Why would I ask you for a part that wouldnt fit my carOriginally Posted by JPK
You'd be surprised how many inquiries we have on these from people who don't realize they won't work on their vehicle. The worst thing we could ever do would be sell something to someone that can't use it.Originally Posted by DINANISR3
This is a quote JUST for the clear LED taillamps for E46 2 door coupes.
part #, description, MSRP, KO Price
63-21-6-920-699, Clear LED Taillamp Left
$238.00 $173.85
63-21-6-920-700, Clear LED Taillamp Right
$238.00 $173.85
Hopefully that's what you were asking about. Those are just for the two lamps, one for each side, by themselves. They will not work without the other components, but since your car already has the LED lamps only in amber, it should work for you no problem.
the rotors i bought from you guys showed up last week. everything was fast and in great condition, thanks!
i need a couple other requests too:
1. i need the price for the 99 e36 m3, 3 spoke steering wheel airbag. i already have the wheel; i just need the airbag for the wheel.
2. black m3 floor mats. preferably just the two fronts, but i don't know if they come in sets of two or not. also, if there are ones that just say ///M instead of m3 that would be better as well, but not really an issue.
thanks.
...'Cause every hand's a winner and every hand's a loser.
And the best that you can hope for, is to die in your sleep'
sorry to take so long!Originally Posted by immaculate
part #/description/ msrp / KO Price
33-55-1-091-257
OEM - Euro E38 rear sway bar, oem description stablizer
$142.00
$104.70
51-16-2-694-891
OEM - E39 M5 mirror housing (left)
$441.00
$322.80
51-16-2-694-892
OEM - E39 M5 mirror housing (right)
$441.00
$322.80
51-16-2-498-931
OEM - E39 M5 mirror glass (left)
$170.00
$131.18
51-16-7-890-510
OEM - E39 M5 mirror glass (right)
$292.00
$225.36
How much for
32 11 1 094 673
32 11 1 094 674
11 28 1 437 475
shipped to 91748 CA?
BMWManiac,Originally Posted by BMWManiac
Sorry this took so long... here ya go!
part#, description, MSRP, KO price
12-14-1-726-066
OEM - E36 1994 325i crank position sensor, oem description c/shaft pos./r
$96.00
$71.27
61-66-1-380-068
OEM - E36 M3 waterpump for windshield reservoir, oem description 7-wash pump
$36.50
$24.96
72-11-8-167-711
OEM - E36 M3 coupe left (drivers) seat belt retainer, female part that belt clips into that also has the SRS sensor, for vader seat, not luxury seat, oem description lower belt
$98.00
$76.28
72-11-8-167-712
OEM - E36 M3 coupe right (passenger) seat belt retainer, female part that belt clips into that also has the SRS sensor, for vader seat, not luxury seat, oem description lower belt
$98.00
$76.28
65-77-8-367-599
OEM - E36 M3 coupe vader seat passenger (right) seat occupancy sensor, oem description sensor mat
$95.00
$69.94
51-71-8-171-243
OEM - E36 M3 coupe trunk rubber lining, the rubber piece that encircles the opening to the trunk once you pop the trunk open, oem description gasket
$49.50
$33.58
51-71-2-138-957
OEM - E36 M3 coupe left (drivers) side door lining, rubber seal that is half rubber/ half cloth, seal/lining appears to be half rubber, and half cloth?. Similar to material that lines the rear side windows. Oem description front left door
$171.00
$115.62
51-71-2-138-958
OEM - E36 M3 coupe right (passnegers) side door lining, rubber seal that is half rubber/ half cloth, seal/lining appears to be half rubber, and half cloth?. Similar to material that lines the rear side windows. Oem description, front right door
$171.00
$115.62
51-16-1-963-979
OEM - E36 M3 coupe (interior) "filler piece" that goes next to the dimmer switch w/o a hole in it. May be used for autoleveling lights on euro versions? OEM description 8-covering
$1.50
$1.50
Hey, how much for:
M Technik Door Mouldings (4-dr.)
82-11-9-403-144
Clear Front Turnsignal – Left
82-19-9-403-095
Clear Front Turnsignal – Right
82-19-9-403-096
Clear Marker – Left from 09/96
63-13-2-492-179
Clear Marker – Right from 09/96
63-13-2-492-180
12-14-1-726-066Originally Posted by 94-325i
$96.00
$71.27
shipping will probaby be about $7.00 I'm guessing, though, because I haven't seen how big the part is.
last quote on your inquiry .Originally Posted by ibrahim83
61-66-1-380-068
$36.50
$24.46
11-42-1-727-300
OEM - Oil Filter Kit
$6.60
$6.60
11-78-1-247-235
OEM - Oxygen Sensor
$146.00
$97.60
12-12-9-064-619
OEM - NGK Spark Plug
$6.40
$6.40
13-32-1-740-985
OEM - Fuel Filter
$23.00
$14.03
16-11-1-179-637
OEM - Seal for Fuel Tank Sensor (Sender Gasket), oem description fuel tank
$5.30
$5.30
34-21-1-157-046
OEM - Caliper Retaining Clip (Anti-Rattle), oem description 7-clip
$7.60
$7.60
33-52-1-092-362
OEM - E46 Rear Shock Mount, oem description guide support
$23.25
$16.96
25-11-1-469-397
OEM - Shift Tower Bushing, BMW E36 3 series, all (1992-1999), oem description trans sh
$7.60
$7.60
25-11-1-203-682
OEM - Shift Coupler Bushing, BMW E36 3 series, All (1992-1999), oem description bushing *
$1.50
$1.50
25-11-1-220-379
OEM - Shift Rod Circlip, 2 Per Car, BMW E36 3 Series, All (1992-1999), oem description spec. cir
$0.70
$0.70
25-11-1-222-226
OEM - Shift Rod Coupler, BMW E36 3 Series, All (1992-1999), oem description sel.rod J
$13.10
$13.10
25-11-1-222-015
OEM - Shift Lever Plastic Bracket, BMW E36 3 Series, All (1992-1999), oem description suspension
$28.50
$20.80
25-11-1-221-849
OEM - Shift Bushing Clip, BMW E36 3 Series, All (1992-1999), oem description guide pin
$5.92
$5.92
25-11-1-220-832
OEM - Shift Lever Support Bushing, BMW E36 3 Series, All (1992-1999), oem description 6-bush be
$11.50
$11.50
25-11-1-220-439
OEM - Selector Rod Shim, 4 Per Car, BMW E36 3 Series, All (1992-1999), oem description spec. shi
$0.51
$0.51
51-41-1-973-500
OEM - Door panel clips to hold the panel on to the door, oem description 1-clip
$0.30
$0.30
I got this p/n off a web page. What is your price on it?
25-16-2-228-145, 96+ shift arm
Originally Posted by toddman35
Todd Maurer
Past - 5 E36s, 1 E39, 1 MB W210 E320, 1 GMC 6.5 ECLB, B6 A4 3.0 6 Spd Quattro
Present - '05 E320 CDI, '06 VW TDI Jetta 5 Spd, '02 Ford F250 CCSB PSD, '02 Ducati Monster S4
Mods: 92* Thermostat, MB to BMW Wheel Adapters, 18" BMW Style 72 Wheels, Custom Mercedes-Benz Diesel Plate Frame
JPK,
How much for the perfomance package springs from the 330i for a e46 sedan?
JP:
Just trying to check my order which I placed about 10 days ago. I think you guys are a victim of your own success.
I needed to add to my order but wanted to see what my status is.
I have called twice and PM'ed you guys twice.
Some help appreciated.
email that I placed the order with is:
brad.purvis@eglin.af.mil
Hey bimmerforums,
Please email me instead of PMs... We are so swamped it's hard to get the time to go to PMs on the board, as it takes a lot longer to access than regular email. We want to do everything we can to get back to you with your quotes ASAP, and PMs slow us down considerably.
Part #, description, MSRP, KO Price
82-19-9-403-097
OEM - E36 2 door white directional indicator tail light (rear left) - vehicles with check control
$142.00
$103.63
82-19-9-403-098
OEM - E36 2 door white directional indicator tail light (rear right) - vehicles with check control
$142.00
$103.63
82-19-9-405-442
OEM - E36 2 door white directional indicator tail light (rear left) - vehicles with out check control
$142.00
$103.63
82-19-9-405-442
$142.00
$103.63
63-21-9-403-99
OEM - E36 4dr white directional indicator tail light (rear left) - vehicles with check control
$142.00
$103.63
63-21-9-403-101
OEM - E36 4dr white directional indicator tail light (rear right) - vehicles with check control
$142.00
$103.63
82-19-9-405-444
OEM - E36 4dr white directional indicator tail light (rear left) - vehicles w/o check control
$142.00
$103.63
82-19-9-405-445
OEM - E36 4dr white directional indicator tail light (rear right) - vehicles w/o check control
$142.00
$103.63
82-19-9-404-391
OEM - 3 series E36 up to 9/96 auxiliary side indicator lights (left)
$18.50
$13.55
82-19-9-404-392
OEM - 3 series E36 up to 9/96 auxiliary side indicator lights (right)
$18.50
$13.55
63-13-2-492-179 OEM - 3 series E36 from 9/96 auxiliary side indicator lights (left)
$18.50
$13.55
63-13-2-492-180 OEM - 3 series E36 from 9/96 auxiliary side indicator lights (right)
$18.50
$13.55
Hey Brad,Originally Posted by fun2drive
Shipped out the other day. Sorry about the delay again in getting back to you. Swamped! Let us know how the parts work out for you.
-JPK
63-13-2-492-179Originally Posted by JMcMasterJ
$18.50
$13.55
63-13-2-492-180
$18.50
$13.55
82-19-9-403-095 OEM - 3 series E36 4dr and ti front clear/white turn signal (left)
$39.25
$28.61
82-19-9-403-096 OEM - 3 series E36 4dr and ti front clear/white turn signal (right)
$39.25
$28.61
82-11-9-403-144
OEM - M Technik Door Mouldings (4-dr), fits E36 3 Series 328, and other 3 series
$279.50
$228.08
82-19-9-403-093
OEM - 3 series E36 2dr and convertible front clear/white turn signal (left)
$39.25
$28.61
82-19-9-403-094
OEM - 3 series E36 2dr and convertible front clear/white turn signal (right)
$39.25
$28.61
here ya go!Originally Posted by toddman35
63-17-8-357-389
OEM - E36 Fog Light* (left)
$99.00
$72.40
63-17-8-357-390
OEM - E36 Fog Light* (right)
$99.00
$72.40
63-17-8-357-397
OEM - E36 Fog light lens (left)
$70.75
$51.79
63-17-8-357-398
OEM - E36 Fog Light Lens (right)
$70.75
$51.79
Hey Bro,Originally Posted by turbof128
We'll need your VIN # to quote this to you, as there are different options that you may have on your car that can make a difference.
You can email us the VIN with your request for quote and we'll get back to you as fast as we can.
JP;
Got the parts today and they are great.
Hopefully you will be able to keep up with those of us that have been swamping you.
Brad
