Results 1 to 1 of 1
Thread: Trans failsafe only when starting from cold
    Mar 2025
    Maidstone
    2003 330ci
    Hope someone can shed some light, ive had some problems with the trans failsafe light apearing as soon as i turn on ignition in the mornings. I dont see why it only happens from cold, ive scanned the codes and im getting P0709 suggesting neutral safety switch. Something to note is when the cog of death appears if i cycle the ignition a few times i manage to get P back again. Regardless of whether i have P or the cog it will still start without problems. Ive gone over the forums so much trying to find my exact problem without much luck, some have suggested poor battery (must admit it doesn't get used much and wouldn't say it has the greatest wollop when starting but never refuses to start) and also faulty ignition switch.
    Something else which may be of relevance is i have just had the yellow traction light, yellow handbrake, and abs light come on.
    Any advice greatly welcomed
  1. Is "Trans. failsafe program" MORE common when cold ?
    By kennethlund in forum 1996 - 2003 (E39)
    Last Post: 10-11-2024, 11:50 PM
  2. I guess solves my cold start Trans Failsafe!
    By shanecarmaster1 in forum 1995 - 2001 (E38)
    Last Post: 04-29-2014, 09:13 PM
  3. No Start + Trans FailSafe Prog
    By Aindriu in forum 1995 - 2001 (E38)
    Last Post: 08-11-2009, 01:07 PM
  4. Engine and Trans Failsafe mode, will not start.
    By njdjh2o in forum 1995 - 2001 (E38)
    Last Post: 07-27-2009, 03:37 PM
  5. Trans Failsafe Prog - Wont Start!! HELP
    By D540i in forum 1996 - 2003 (E39)
    Last Post: 12-09-2008, 02:21 PM
