Results 1 to 12 of 12
Thread: Sluggish low end / Intermittent Misfiring / Everything Sucks E36 M3
    Nov 2024
    California
    E36 M3
    Hello, I'm having some (or a lot) of issues with my e36 and would appreciate anybody's input and/or guidance on how I can sold these issues.
    I'll go over the car, some history and what I've done so far.
    Car
    1997 E36 M3
    Previous owner had the s52 OBD1 converted
    Red Label 413 ECU
    OBD1 harness
    OBD1 knock / cam / crank sensors
    M50 Intake Manifold
    OBD1 Fuel Rail
    OBD1 MAF
    car is also originally an auto, converted to a 6 speed with an e46 transmission.
    Since then I've converted it back to OBD2
    The car ran great before the conversion back.
    Here's what's been replaced / done during the conversion back
    used OBD2 Harness
    Correct ECU with EWS delete from Ecu Saver (they went with VIN so its auto)
    New OBD2 knock sensors
    used obd2 cam / crank sensors
    New post-cat O2 sensors (2)
    New pre-cat o2 sensor for bank 2
    S52 intake manifold
    used obd2 fuel rail & injectors (pink top)
    used obd2 MAF
    installed used SAP component
    new injector seals
    replaced intake manifold gaskets
    new crankcase vent pipe
    new inlet / retour fuel hoses
    new fuel filter
    new fuel pressure regulator
    replaced exhaust mid section with oem w/cats (previously had magnaflow without cats)
    Upon first start everything seemed fine, was getting a code for pre-cat o2 hence the new o2 in bank 2
    Along with a P0600 code (coming from the ecu looking for the auto transmission to my knowledge)
    I did notice a loss of power when i did start driving it, i assumed it was due to swapping out the m50 intake manifold
    On idle everything seemed fine but did notice a rough idle for a second.
    On the highway, i started misfiring (bad) whole car shaking and such
    other than the misfiring at the point, the car seem "okay"
    It threw 14 codes
    P0301 misfire
    P0300 random misfire
    P0305 misfire
    P0302 misfire
    P0303 misfire
    P1519 A camshaft position actuator bank 1
    P1188 fuel control (bank 1 sensor 1)
    P1189 fuel control (bank 2 sensor 1)
    P0170 fuel trim (bank 1)
    P0173 fuel trim (bank 2)
    P0600 serial communication link
    Parked and turned the car off, clear codes and started the car back up
    Car ran the same but without misfires at idle, drove for a bit, seemed fine, then misfiring again.
    Restarting the car seemed to get rid of the misfiring like 3 out of 5 times but itd come back.
    Codes
    P0301
    P0300
    P0302
    P0303
    P1519
    P0600
    not all of them came back
    I unplugged and replugged the camshaft sensor, cleared codes, havent misfired since (or at least got codes thrown for it)
    BUT now the car is running god awful.
    There is a rough idle that comes and goes (feels like i have cams or something), sometimes the idle is smooth, then itll get rough and shake the car a little bit.
    Getting the car to start moving in first gear feels like I'm mid stall out no matter how much gas i give it once clutch is engaged, once im actually moving, its extremely sluggish on the lower end of the RPM.
    Lower end of RPMs in general feel super sluggish, boggy, and theres hiccups on acceleration.
    The hiccups feel like im misfiring but just not nearly as bad as previously, theres a hesitation i can feel during acceleration.
    Sometimes when i get to 3-3.5kish rpm, car starts ripping like a surge of power came out of nowhere, and other times it stays super sluggish throughout past 3k
    These are the codes im currently getting now.
    P0600
    P1519 (A Camshaft Position Actuator Bank 1)
    If anybody has any insight or general direction I should be looking into, it'd be much appreciated/
    If anybody has questions please ask.
    Thank you so much in advance
    Jun 2010
    NY
    1997 328i
    Smoke test for vacuum leaks. Cam sensor MUST be OEM Siemens. MAFS MUST be OEM Bosch or Siemens. You should always replace both pre-cat sensors. Unplug the rubber hose from the SAP pump and see if you can blow through the valve on the exhaust (should not leak). Remove the fuel rail with injectors installed, put cups under each injector and energize the fuel pump and check for leaking injectors. NEVER buy new cheap china injectors they will leak. If the coils are old or original buy a new set, can be had for under 100 on ebay, never buy used.
    You could try putting two bottles of royal purple complete fuel system cleaner and drive the car but you should make sure there are no vacuum leaks and that the Cam sensor and MAFS are correct first.
    Flashing the DME to a manual is not hard with MS41Quickflash, but must be done correctly so you must read read read.
    https://www.bimmertuningtools.com/pr...41-quickflash/
    Jun 2010
    NY
    1997 328i
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Also make sure you are using the obd2 IAT.
    Is the valve cover OBD2?
    Crossed primary O2 connectors?
    Non BMW or Siemens cam sensor?
    Nov 2024
    California
    E36 M3
    Quote Originally Posted by Eric93se View Post
    Cam sensor is OEM Siemens
    MAF is also OEM
    I’ll replace pre cat bank 1 o2 as well
    Injectors came with the fuel rail used they are OEM pink tops
    Thank you for the suggestions I’ll see if I can borrow a smoke machine and get that done and try these other things out as well.
    Much appreciated!
    Nov 2024
    California
    E36 M3
    PO kept obd2 valve cover for obd1 conversion and just cut slots out of the plastic engine cover to route for coils
    Will check to see if I crossed the o2
    Nov 2024
    California
    E36 M3
    Here’s a freeze frame I also got from when it had the misfire codes.
    P0301
    Somethings really wrong with the STFTs, right?
    Note I’m also using a shitty generic code reader, currently trying to borrow a windows laptop to install INPA and get some live readings.
    Jun 2010
    NY
    1997 328i
    yup, your precat o2 sensors could be crossed.
    Oct 2003
    Seattle
    99 M3
    Couple of things
    O2 sensors should be Genuine BMW, Bosch, or NTK (NTK manufactured Bosch brand sensors.)
    Crossed O2 connectors will cause ‘limp’ mode.
    Forward bank O2 sensor connects to aft connector next to fuel rail. Aft bank O2 to forward connector.
    Cam and crank sensors should be Genuine BMW or Semiens.
    As noted temperature sensor needs to be OBDII (threaded OBDII sensor for M50 manifold from BimmerWorld)
    Probably need to have fuel injectors checked for flow/leaks.
    Looks like OBDI S50 used different coils than OBDII M/S5X. Something to look into.
    Used parts and especially electronic components can be problematic.
    Nov 2024
    California
    E36 M3
    Turns out this was the answer. Crossed o2 sensors
    You're a godsend haha
    Thank you so much.
    Nov 2024
    California
    E36 M3
    After swapping o2 plugs, the car has been running 1000 times better.
    A little hesitation in acceleration here and there but nothing crazy
    No more P1519 code though
    Hearing a lot of clicking from injectors now as well.
    Starting is also now a little bit different, takes a bit to get it running but sometimes it’ll start right up.
    I was throwing a P0340 for a run but it’s went away after restart and I only have the P0600 from the auto ecu
    I’ll be replacing spark plugs, coils, injectors and eventually rebuild vanos for maintenance
    Thanks everyone for the input!
    Oct 2003
    Seattle
    99 M3
    OBDI S50 used a different fuel injector than M/S52.
    Fuel Injectors
    M50: 17.5#
    S50: 17.5#
    S52 uses a red top fuel injector BMW p/n 13641703819 Injection valve - BOSCH.
    Fuel Injectors
    M52: 21.5#
    S52: 21.5#
    There is a new generation Bosch injector to replace above.
  1. E36 WTB: low rise ltw wing for my e36 m3 coupe.
    By typer1982 in forum Exterior Lighting & Body Parts
    Last Post: 04-22-2012, 06:42 PM
  2. Rear end noise in my 99 e36 m3....
    By lilwhitepanda in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-11-2007, 04:00 PM
  3. Wtb: Front End Body Parts For 95 E36 M3 Coupe
    By Master Shake in forum BMW Parts Wanted
    Last Post: 10-04-2006, 04:29 PM
  4. Opinions/advice: low impact stereo system in an E36 M3 Coupe
    By HellRotCoupe in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-25-2005, 11:13 PM
  5. low budget audio system in an e36 m3
    By spetulla in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-17-2004, 04:06 AM
