Results 1 to 5 of 5
Thread: Output Flanges on 5spd Getrag interchangeable with M3 ZF 5spd?
    cali
    325is / yukon
    Has anyone tried this?
    Apparently the ZF/M3 output flange is a larger diameter bolt pattern than the 325i getrag's pattern.
    Anychance these can just be unbolted and swapped? Dunno if they have the same inside spline and outside diameter for slipping into the output bearing.
    Maybe someone has tried this?
    nyc
    98AMG C55,99M3,412whp 95 AWD Eagle Talon Tsi
    Quote Originally Posted by sandsrfr
    Jason
    Yes therre is actually a thread that confirms that the diff input flangecan be swapped out.If you have a 4 bolt a 6 bolt can be swapped in.
    cali
    325is / yukon
    Quote Originally Posted by coolcarlski
    Yes therre is actually a thread that confirms that the diff inout falanges can be swapped out.If you have a 4 bolt a 6 bolt can be swapped in.
    Ummm.... I was asking about the output flange of the tranny, not differential.
    Thanks tho
    nyc
    Thanks tho
    MY bad!.I will find out for you though!
    cali
    325is / yukon
    NP! Thanks, tho I have a feeling the rear flange on those trannies either have longer/shorter shafts that slip into the rear bearing... But I'm curious what you find out!
