Results 1 to 4 of 4
Thread: E30 Warm Start Issue: Long Crank Before Firing Up
    Jan 2025
    France
    BMW Z1 E30
    Hey guys, I’ve been having an issue with my E30 lately and wanted to see if anyone else has dealt with this.
    The car sometimes cranks for a while before starting, especially when it’s warm.
    Cold starts are fine, but after driving for a bit and turning it off, it struggles to fire up again.
    Once it starts, it runs perfectly. Could this be the crank position sensor or maybe a fuel pressure issue? Any thoughts?
    Regina, Sask, Canada
    82 320i 89 325i
    common causes are leaking injectors, failing fuel pumps, bad cps, failing fpr, clogged filter and a couple others. more or less in order.
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    Mine may do this at about 55 degrees. I've replaced the temperature sensor with no improvement. Doesn't do it very often so I just live with it. I have found if I push accelerator pedal to floor helps.
    Sep 2016
    Belgrade
    What engine in that e30 ?
  1. Long crank before starting
    By tomloans in forum 1995 - 2001 (E38)
    Last Post: 04-03-2016, 10:53 AM
  2. long cranking before start/on euro 735i
    By jimsperf in forum 1978 - 1987 (E23)
    Last Post: 06-24-2015, 12:02 PM
  3. Extra long crank before starting 2004 X3 3.0
    By apexdvr383 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 07-18-2013, 02:50 PM
  4. Long Cranking before Engine Starts
    By Perrier in forum 2004-2010 (E60,E61)
    Last Post: 07-10-2010, 11:19 AM
  5. All of a sudden, long cranking before start...
    By 99E36M in forum 1992 - 1999 M3 (E36)
    Last Post: 05-26-2006, 12:48 PM
