Results 1 to 25 of 28
Thread: My turn at the infamous airbag light
    Feb 2024
    NW Indiana
    1998 Z3 M52 Arctic Slvr
    I have a 98 2.8 Z3 (built 10/1997) at 83,000 miles and while sitting at a gas station, car running and then leaving, somewhere in that time, the air bag light came on. I want to say it was going to be when my wife got back into the car and it came on while she was seating herself and buckling up but I dont have that evidence. It was just a short moment after, when I glanced down and saw the red light.
    So, I have searched and skimmed through the various threads but that took me into a time warp and back, so are my only options to
    a) ignore it (which I cant do)
    b) try my OBD II bluetooth to get a code (which returns nothing as it seems to only bring back CEL codes)
    c) get a tool like B800 SRS scan (or B8300??) and get the code, address, then reset and fingers crossed
    d) invest in the time/effort of INPA to get code, address it, then reset and fingers crossed
    What is the best option here?
    Also, I realize that there is no 1 size fits all, but what is common in this situation? Is it that some of the connectors under seat need DeOxIt cleaning and reconnecting, reset and should be good to go?
    What is the WORST scenario? (air bag is not deployable in the event it needs to be deployable)?
    BMW Z3 - 1998 - 2.8 Arctic Silver (M52)
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Best option is set up a laptop with INPA from the z3 diagnostic thread. It’s free other than the cables you need. BMW factory software. Typically seat belt tensioner causes airbag light but without INPA you’re just guessing.
    Dec 2018
    Indiana
    00 M Roady '22 Lexus RC
    Quote Originally Posted by z3forlife View Post
    +1, you will probably from time to time, have a need with your 26 year old car, to diagnose an issue. You can't beat the BMW program that the tech's used when the car was new.
    Mar 2016
    Blairstown, NJ, USA
    1998 M Roadster
    The light could be related to the seat occupancy sensor. If so, your have to take the seat upholstery off, or buy a gizmo to fool the computer.
    McLean, VA
    02 MC, 01 MR, 99 Z3C
    My Foxwell NT 510 reads the SRS codes. In my case I have the passenger buckle causing the fault. to date it responds to cleaning with DeOxit sprayed directly into the buckle and then latching and unlatching a few times. But I bought a replacement buckle assembly for the inevitable day when it fails.
    Kelvin
    May 2022
    NYC
    2001 Z3 3.0, 2014 e84 X1
    I agree. Start by spraying some deoxit in the seat belt receptacle and latching and unlatching the the buckle a few times. It has resolved transient airbag lights for me every time.
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by devmast View Post
    This won't clear the codes, so this is working backwards.
    Read codes
    Fix problem
    Clear codes.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2024
    NW Indiana
    All good advise, I have procured a laptop, but not I must read to determine which cable or perhaps based on some recent discussions, may not need a cable after all. Bluetooth has capability too, so must read to see if my Bluetooth will work and get those instructions.
    Here is the OBDBII Bluetooth reader I have: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jul 2004
    Houston, TX
    36 Cylinders
    It needs to be an INPA K+DCAN cable, preferably with a switch on it.
    -Abel
    Dec 2018
    Indiana
    Apr 2020
    Ontario, Canada
    Early '99 Z3 M52TU2.8
    What does the switch do?
    Mar 2023
    Mt Lemmon, AZ
    1998 BMW Z3 M Roadster
    That's the one I ordered a couple of days ago.
    Description says...
    "Switched inpa k+Dcan, You can use the switch to do more cars .Some cars need disconnect to use the inpa k+dcan,but others need connect. It can support more cars after adding the switch.Not every model need switch."
    Jul 2022
    Lake Wylie SC
    1999 Z3 M Roadster
    Disagree with 328 on this, although it keeps coming back maybe twice per year, spraying contact cleaner in the driver buckle buckling/unbuckling vigorously numerous times and then clearing with the B800 has worked 2 or 3 times for me
    The code I'm getting is driver buckle, which has been replaced, methinks this mechanical switch hangs up from time to time...
    Feb 2024
    NW Indiana
    Quote Originally Posted by ZJon View Post
    But I would still need the INPA and Cable to reset AFTER and IF, only IF, that happened to be the one of many possible situations. So still have to reset via the INPA, of which I dont have, nor have a tool to reset such a code.
    Unless, I am missing something.
    Aug 2012
    Kansas
    My issue has never been the buckle but the harness plug below the seat. INPA should tell wether it’s the tensioner/pyro or buckle circuit.
    Feb 2024
    NW Indiana
    Quote Originally Posted by IndianaRoadster View Post
    Ordered. Thank you.
    Any recommendations for the following ? BMW 20-pin to OBD Adapter
    There's no need for an adapter cable, they just jump the pins at the port and then convert to OBD2 plug. The car already converts to the OBD2 plug... at the OBD2 plug... so if you just jump the pins like shown below, you can access all modules via the OBD2 port
    Just remove the cap on the round port, install a jumper wire like pictured and reinstall the cap
    Dec 2018
    Indiana
    I know that you can jump pins, but just out of convenience, I went ahead and ordered the adapter. Here's one from ECS for $18, but like $14 on Amazon.
    Feb 2024
    NW Indiana
    Quote Originally Posted by BimmerBreaker View Post
    As in, set it (jumping like you show) and forget it, regardless of doing any diagnosing or driving car?
    Aug 2012
    Kansas
    No. This allows access to all modules through the obd2 plug instead of the 20 pin.
    Mar 2023
    Mt Lemmon, AZ
    By way of follow-up... I purchased that cable (already had a 20-pin adapter cable) downloaded the INPA to an old Windows 7 laptop and everything seems to work well.
    Dec 2018
    Indiana
    Quote Originally Posted by Ahwahnee View Post
    Glad you're good to go! I just leave the two hooked together and stored in the drawer in my tool cabinet. It's convenient to just pull it out, open the hood and plug it in.
    Quote Originally Posted by kezug View Post
    Yes it's fine to drive like that. I'll use it for real time diagnostics while driving on occasion - but usually if I don't need to access other modules for awhile I will unplug the jumper.
    Aug 2008
    Flowery Branch (NE Atlanta), GA
    MZ3 Roadster
    I bought one like this and added a programming switch.
    Feb 2024
    NW Indiana
    I have 2 codes
    16 analog status belt lock driver
    Error Frequency : 1
    3 Supply voltage
    Error Frequency : 4
    I am not finding much on these codes when searching around:
    for 16 - I found this thread - Unsure which of the 2 things discussed was the solution. Seemed like I could clean the buckle connect and seat if that works. Or mess with wiring under the seat?
    If I do disconnect/spray electrical parts cleaner/reconnect, do I just do ALL the cables or the seat belt lock driver cable (which one is that)? Is this requiring the seat to be removed?
    For 3 - Unsure of what to make of 3 Supply Code - seems this is unrecoverable???
    Also, I am assuming that which ever I do try, I still must do a clear code, then see if my solution worked?
    Also, but since I have INPA, if I am am going to be unplugging wires, do I still have to disconnect battery first or simply just clear the code that pops if I dont?
    I also felt I should ask about this. Why does my Sensor say No?
  1. Replies: 10
    Last Post: 03-25-2016, 10:56 AM
  2. Airbag Light comes on for ~ 2 minutes then turns off
    By bejita in forum 1992 - 1999 M3 (E36)
    Last Post: 10-31-2005, 09:10 PM
  3. Replies: 9
    Last Post: 08-14-2005, 08:18 PM
  4. Airbag light on! Help to turn it off?
    By IzzE46 in forum 1988 - 1996 (E34)
    Last Post: 09-23-2003, 02:31 AM
  5. turning off airbag light
    By tinymcoupe in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-25-2003, 10:20 PM
