Results 1 to 5 of 5
Thread: M70 Oil pump piston
    Sep 2022
    USA
    M3
    M70 Oil pump piston
    Anyone familiar with the function of the piston in the oil pump in this youtube video. Is making sure that is moving something that people have to usually worry about?
    https://youtu.be/4nEsRZabV5A?t=966
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    It is a pressure regulator, and it commonly seizes when people put zinc additives in the oil.
    You've addressed it properly.
    Your scheme with the cylinders and pistons is questionable though, will be interesting to see how that holds up.
    The Sunnen process for alusil bores requires the special lapping paste and felt pads for proper surface. The scotch Brite/ oil step is only part of the complete process.
    The pistons are purposefully coated with a ferric oxide coating to play well with alusil. Hopefully, whatever you used will function the same way.
    '91 850i 6sp (mint) (sold)
    Sep 2022
    USA
    M3
    @Cartoonz thanks! That is not my video thankfully lol
    I also have my engine partly apart. I don’t know what oils were used in the past but it is currently at 80k miles. Would you recommend I take the piston out to make sure it is moving? I haven’t had the oil pressure light come on before when the engine is running
    Sep 2008
    Santa Barbara
    If you have the pump out, by all means carefully free up that piston.
    Jan 2005
    Japan
    11/88 E32 750iL
    as you have your engine partly apart, these engine data might be helpful with plenty of factory spec measurements, for download here ~ 400 pages technical data on various engines https://web.archive.org/web/20110516...cal%20Data.pdf
  1. M70 Oil Pump adjustment
    By ctuls in forum 8 Series (E31)
    Last Post: 01-30-2023, 12:30 PM
  2. M70 Oil pump sprocket nut TQ spec?
    By dragon850 in forum 8 Series (E31)
    Last Post: 06-23-2016, 01:45 PM
  3. M70 oil pump
    By unity in forum 1988 - 1994 (E32)
    Last Post: 06-06-2016, 10:04 AM
  4. m70 oil pump sprocket removal.
    By mitch23 in forum 1988 - 1994 (E32)
    Last Post: 10-12-2015, 08:59 AM
  5. M70 Oil pump
    By RUFAZZ in forum 1988 - 1994 (E32)
    Last Post: 06-20-2010, 10:50 PM
