Results 1 to 3 of 3
Thread: Tonneau motor does not release
    Nov 2015
    Fort Lewis
    1997 m3
    Tonneau motor does not release from the assembly after pulling the emergency lever. I see the lever move that releases the motor but it is still stuck to the assembly. The two metal wire rod that is connected to it has a lot of tension I don’t know if it’s normal or not. Any tips on how to get the motor released so I can do a resync with my convertible top. TY in advance
    The Netherlands
    DE-spec E36 328i/M3 cab
    what happens if you just press on the release levers on the motors themselves?
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
    USA
    1998 dinan m3 conv.
    May be stuck on the bracket
    I had the same problem. In my case the motor was stuck against the bracket. I was able to tap it gently sideways with a hammer and it came loose.
    Quote Originally Posted by Sandecheekz View Post
  1. 1997 BMW E36 tonneau motor will not close
    By Conv97 in forum Convertible Questions
    Last Post: 12-20-2017, 06:55 AM
  2. Replies: 9
    Last Post: 02-14-2013, 09:22 PM
  3. Help - tonneau cover does not fit "flush"
    By gmiz in forum Convertible Questions
    Last Post: 06-02-2011, 07:00 PM
  4. motor cranks but does not start, takes a couple of goes
    By Bonzi in forum 1991 - 1999 (E36)
    Last Post: 09-12-2006, 12:36 PM
  5. why does it have to be Euro motor but not >
    By d4nn in forum 1992 - 1999 M3 (E36)
    Last Post: 10-24-2002, 12:04 PM
