Open Source PNP M52/S52 OBD2 Tuning Board ECU - speediuno M52
I'm pretty excited about this little project.
Open Source, extensible, proven, cheap.
For Turbo applications its supports both MAP and Wideband Sensors.
Plug and play with the M42.1 ECU.
Did I say cheap.
Github Repository
https://github.com/pazi88/Speeduino-M5x-PCBs
Youtube Channel
Speeduino compatible M52 PnP ecu assembly
https://www.youtube.com/watch?v=FzxQXtNtpvE&t=1246s
I designed STM32 MCU card for Speeduino!
https://www.youtube.com/watch?v=yljtZp3HeZI
Board discussion thread
https://speeduino.com/forum/viewtopic.php?t=2527
Over the years I have learned how to tune the OEM ECU with RomRaider ( but it's MAF based so super fussy even if you upscale, add a resistor or use a larger MAF)
I've Looked at VEMS, Megasquirt, and the expensive commercial solutions.
I don't see anything missing from this and if I find a feature I want to add it's possible to do so pretty damn cheaply and there is decent community support for Speediuno and it look to come in at less than a third the price of the next cheapest solution. Other stuff in there (option for hall effect cam sensor, external barometric pressure, sequential injection w/ the 32 bit mcu)
Can't find a downside....
If someone has some negatives to throw at me before I dive into having some PCBs made for me I'd appreciate your insight.
PCB Layout (top view)
https://drive.google.com/file/d/1Q59...ew?usp=sharing
Thanks,
rf.
97 BMW M3 (s52b32) - VF-Supercharger kit ( Vortech V2-SQ supercharger, 32 pound injectors, VF tuning ), VDO/LeatherZ Gauge Kit (Oil Temp, Oil Pressure, and Boost), UUC Motorwerks RSC36 Exhaust, Stainless Steel 6-2 Exhaust Headers, Bilstein Sports, Rear Adjustable Camber bushings, Wheel Spacers 10mm in front 25mm in back, Uprated Clutch, UUC Shift Knob, Short Shifter and Clutch Stop, Cross Brace, Mason Engineering front strut bar, Contour Wheels, Euro Ellipsoid (Angel Eyes) HID Headlights, braided steel brake lines, aluminum thermostat housing, mishimoto aluminum radiator and silicone hoses and a partridge in a pear tree
