Results 1 to 6 of 6
Thread: Squeaky right rear
    Sep 2020
    Bronx
    BMW z3 coupe
    Squeaky right rear
    https://youtube.com/shorts/qmmqLOLVb...UMKDPLsZ4jHc6o
    Hello, I bought Koni yellows new and I have about 1000 miles on them. They’ve been squeaking possibly since the start. I have had a lot more issues with the rear end so I can’t really say if it’s been squeaking since installation. But what is this noise? I want to confirm it is the shocks before I go and buy new ones. TIA
    Regina, Sask, Canada
    82 320i 89 325i
    more likely bushings. sounds exactly like poly bushings.
    Sep 2020
    Bronx
    BMW z3 coupe
    Quote Originally Posted by 82eye View Post
    Idk I took it to two different mechanics and they said the bushing looks fine. Nothings poly. I forgot to add that it sounds like a faint bell ringing consistently at highway speeds. I was also thinking bushings until I took that video. The first two squeaks sound like the shock absorption sound turns into a squeak.
    82 320i 89 325i
    Quote Originally Posted by Mpopaj View Post
    if you're on rubber then it's far less likely to be bushings. not 100% impossible but a lot more improbable. konis shouldn't have issues with such low mileage. might be possible to take the shock off and see it makes a sound independent.
    Nov 2019
    Milwaukee, WI
    1989 325ix, 2003 4.4 x5
    I'm firing from the hip here, but I wonder if you spray individual components with water or wd40 one by one and see if and when the noise goes away that can help identify what's squeezing. Idk if it's a bad idea to spray wd40 or silicon spray up I to the shock but if the noise stops temporarily with a little lube then you for sure found the source. That sounds loud. You're not sure the noise is coming from the shock?
    That might be bad advice, idk if wd40/ would damage seals in the shock maybe silicone spray would be safe.
    82 320i 89 325i
    how healthy is the shock tower? did you use the tower reinforcements?
  1. Noise in Right Rear Suspension...
    By Dark Helmet in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-18-2004, 10:23 AM
  2. Turning right, rear suspension makes a rubbery, squeaking sound.
    By Sacramento M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-13-2002, 12:35 AM
  3. Right rear lock wont work with autolock
    By adeel in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-17-2002, 10:10 AM
  4. Right Rear Squeak?
    By TheBestCow in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-10-2002, 10:36 PM
  5. squeaky right rear suspension....serious problem?
    By gizzard in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2002, 10:42 PM
