Results 1 to 25 of 61
Thread: I really, really like this car but....
    Apr 2024
    california
    1998 bmw z3
    I really love this car, i've already spent like 3k on it replacing parts and upgrades but i still have the damn p1188 code. So far i've replaced the fuel presure regulator, fuel filter, both 02 sensors and the check engine light was off for like 150 miles, then i was like, ok im sure it will pass the smog check now. Took it to the smog center, the guy connected his scanner and told me that 3 monitors were not ready, went ahead with the smog test and it failed it, the guy told told me that the computer is not running diagnostics to those 3 monitors and the results of the test says that the air injection failed. After i drove off from the test center, the traction control, abs and check engine lights came on. Like, what the hell? Pinche carro mamon....
    Car is a 98 2.8 with 54k miles.
    Apr 2020
    Ontario, Canada
    Early '99 Z3 M52TU2.8
    Oh man, you're harshin' my mellow.
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    Since the P1188 is related to the air/fuel ratio and you have already changed a bunch of stuff, in my mind, it could be a bad cat. Also, if the inspection was done on rollers, it can cause the ABS/DSC light to come on, but it should go off again after a few minutes of driving.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Jul 2004
    Houston, TX
    36 Cylinders
    What were the results of your pressurized smoke test of the intake system?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Mesa, Arizona
    2000 Z3 M-Roadster
    You only spent $3k? Talk to me when you're in the 5-figure cohort (this is with me doing most of the work). These are old cars and can be costly to get back to running condition.
    Tony
    "You can't sign away negligence."
    Sep 2022
    Omaha NE USA
    1999 BMW Z3 Roadster
    I've spent double what I paid for mine and it wasn't really all that bad when I got it. ��
    Apr 2024
    california
    1998 bmw z3
    Quote Originally Posted by khammack View Post
    Yes, it was done on rollers and they turned off after some driving. I dont even wanna know how much a new cat is.
    Quote Originally Posted by Shadowjack1020 View Post
    Im getting there dude, is it all good now?
    Quote Originally Posted by ProductUser View Post
    I knew before hand that i was gonna spend more than the cost of the car, funny thing is that the car runs very well, its just the stupid check engine light.
    Apr 2024
    california
    1998 bmw z3
    Quote Originally Posted by Hoyt Clagwell View Post
    I know dude, but its such a nice car that is totally.worth throwing some k's into it.
    Scanners says is fuel control bank sensor 1
    Apr 2024
    california
    1998 bmw z3
    So by the scanner the car was having a vacuum leak, the shop did the smoke and found a couple of leaking, replace them but i dont know if they did a intake sistem test.
    After having 3 codes, now i only have 1 after replacing hoses and other parts.
    Maybe the shop only did a smoke test for.vacuum leaks and not a intake sistem one?
    I thought a smoke test was like overall test.
    Quote Originally Posted by hondaspeedf1 View Post
    Wait, u already spent 5k and you did most of the work? This is bad new 4 me, i've spent those 3k between shop work and 1300 in coil overs oh god.
    Apr 2024
    california
    1998 bmw z3
    Today i've found a wire in the engine bay that is connected to the frame but it does not have a nit to secure it. Also there is a hose that runs from the oil filter casing to idk where that is full of oil. Like, its leaking oil and the power strearing conteiner is full of oil on the outside
    Is that hose the oil return line?
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    I don't know the answer to that question, but if you haven't done a smoke test, you are completely in the dark about the state of the intake system, and potentially your tail. There are plenty of videos online showing how to do it for cheap.
    Apr 2024
    california
    1998 bmw z3
    Quote Originally Posted by BladeRunner919 View Post
    Well turnns out that the computer is the issue here, not tellimg 1 of the 02 sensors to heat up.
    Turned out to be the ecu not talling 1 of the 02 sensors to heat up.
    Apr 2020
    Ankeny, IA
    96 BMW Z3
    I had similar weirdness and it also turned out to be the computer. Got one off eBay for $50 and just needed Able's help to get the keys coded for it using INPA.
    Claude Berman, 96 Z3 Production Date 2/96 BMW CCA# 581686
    The only good is knowledge and the only evil is ignorance. Socrates, 469–399 B.C.E
    Jul 2004
    Houston, TX
    36 Cylinders
    I really really really really really doubt it's your computer based on a P1188 code.
    -Abel
    Apr 2024
    california
    1998 bmw z3
    So seem likee i need to get a win laptop and that INPA progeam, right?
    Aug 2008
    Flowery Branch (NE Atlanta), GA
    MZ3 Roadster
    Yup
    Apr 2024
    california
    1998 bmw z3
    Quote Originally Posted by sleeperz View Post
    Yup
    On it, so i need to adjust the fuel parameters using the app, where do i get the right parameters from?
    Tnx
    Tnx
    No. I'm not even sure how you came to that conclusion
    Apr 2024
    california
    1998 bmw z3
    Quote Originally Posted by BimmerBreaker View Post
    Oh ok. Im new to cars. So what shoyld i do then.
    Tnx
    Apr 2024
    california
    1998 bmw z3
    So i went to the dealership and made an appointment for 340 bucks for diagnostic what is wrong with the car. More money into the pit.
    Went to several auto electric shops and no1 wants to touch the car.
    Aug 2008
    MZ3 Roadster
    Did you ever load INPA on a laptop and set it up with a proper cable? Old Windows 10 laptops are pretty cheap used.
    It is really not that hard to do and then you can be the diagnostic tech for a lot of issues. I have an expensive Foxwell coding/diag tool that I use for the hobby car work I do, but I use INPA for the old BMW's. It's worth the small investment in time. $340 bucks would have gotten a nice laptop and cable for INPA.
    The District
    S54 e36/8, X3 M40i
    In addition to that, even if you don't have an old windows laptop, I loaded a free download of windows 10 on a 10+ year old macbook air running bootcamp and got INPA set up for the ~$10 that it costs to buy the cable off ebay...
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Don't take this the wrong way, but if this is your approach you probably aren't going to keep this car, so I would just sell it on. They are not hard to work on, but it sounds like you're not really up for following the advice of the very experienced people on the forum, and you're going to throw money at it and then get fed up. Better to get out now.
    Mar 2003
    Winnipeg, Manitoba
    1997 BMW M3
    Definitely need to load INPA and get a cable.
    If you start paying stealership prices you are doomed.
    These cars aren't super complicated but there is a learning curve.
    If you use search on this forum you will likely find everything you ever need.
    97 BMW M3 (s52b32) - VF-Supercharger kit ( Vortech V2-SQ supercharger, 32 pound injectors, VF tuning ), VDO/LeatherZ Gauge Kit (Oil Temp, Oil Pressure, and Boost), UUC Motorwerks RSC36 Exhaust, Stainless Steel 6-2 Exhaust Headers, Bilstein Sports, Rear Adjustable Camber bushings, Wheel Spacers 10mm in front 25mm in back, Uprated Clutch, UUC Shift Knob, Short Shifter and Clutch Stop, Cross Brace, Mason Engineering front strut bar, Contour Wheels, Euro Ellipsoid (Angel Eyes) HID Headlights, braided steel brake lines, aluminum thermostat housing, mishimoto aluminum radiator and silicone hoses and a partridge in a pear tree
    Honestly solid advice. I'm not even sure what he means by "auto electric shops" ? There aren't any shops that specialize in automotive electronics near me and haven't heard of that before. It should have gone to a qualified, reputable independent BMW mechanic in the area. Most the techs at the dealer were probably not even born yet when the Z3 came out and may not have the knowledge to work on cars from that vintage.
  1. Really surprised: weighed my car at SCCA Nationals
    By NoSoup4U in forum 2001 - 2006 M3 (E46)
    Last Post: 06-05-2004, 02:33 AM
  2. FS: Really random stuff (some car stuff, some not)
    By Preppy in forum BMW Parts For Sale
    Last Post: 04-21-2003, 09:25 PM
  3. Names Some Ways To REALLY Screw Someone's Car Up!
    By LS1 Muscleman in forum Off-Topic
    Last Post: 02-10-2003, 11:59 AM
  4. REALLY NEED HELP!!! My car wont let me pump gas!!...
    By TSM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-14-2001, 08:07 PM
