Results 1 to 7 of 7
Thread: No Crank
    Mar 2020
    San Antonio, Texas USA
    1990 BMW e34 525i
    No Crank
    I have a 1990 525i e34. I parked the car a few days ago. Now it won't start. I have checked almost everything. I did replace the starter and the battery is fully charged. I am able to start the car is a place the key switch to two position and start the starter directly.
    I would like to check the following: the starter relay, the starer power fuse, and the clutch safety switch, but I do not now where they are located. Can anyone tell me where they are located???
    Thanks!!!
    Jan 2005
    Japan
    11/88 E32 750iL
    moved from 5 general to E34 forum, here are the wiring diagrams, there you find relays and fuses by built year https://shark.armchair.mb.ca/~dave/BMW/e34/
    at the end are component location charts and pictures
    May 2017
    Perth, Western Australia
    patrol/safari; falcon
    Quote Originally Posted by tyromechanic View Post
    Thanks!!!
    There's no starter relay, no clutch safety switch, no starter fuse.
    It's all in the ignition switch. Not the key barrel but a clip on electrical switch on the opposite side of the steering column. It goes:
    -battery main fusible link/s
    -key switch
    - pass through anti start relay in fuse box (autos have a relay here for trans Park/neutral saftey but manuals just have a pass through jumper -yellow case with red stripe across the top)
    -starter motor
    The starter load is handled by the ignition switch without a relay.
    Mar 2020
    1990 BMW e34 525i
    Quote Originally Posted by shogun View Post
    Thank you!!!!!
    Mar 2020
    1990 BMW e34 525i
    Can you help me identify the clip on the electrical switch. I hope the picture helps.
    Respectfully,
    May 2017
    My description meant to suggest you didn't have to pull the key barrel out, or access it from the key side.
    The switch is on the back of it, accessed from to other side of the steering column.
    Red is power in, black with stripe is to starter solenoid via fuse box jumper/relay
    Mar 2020
    1990 BMW e34 525i
    Thank you again. I did not take the column out. I found the picture I posted online.
  1. forged vs. cast crank
    By fourfa in forum 1992 - 1999 M3 (E36)
    Last Post: 12-14-2001, 11:33 PM
  2. Crank, rod and piston upgrade for E36 M3
    By fstbmwm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-28-2001, 12:09 PM
  3. Does the crank pulley have to be aligned?
    By C///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-09-2001, 05:31 PM
  4. Stroker Crank?
    By Kenshiro in forum 1992 - 1999 M3 (E36)
    Last Post: 08-10-2001, 05:15 PM
  5. 318is has 138HP at wheels or crank ??
    By Austin in forum 1991 - 1999 (E36)
    Last Post: 06-13-2001, 10:54 PM
