Results 1 to 2 of 2
Thread: S50B32 no 2 coil fault
    Mar 2024
    Queensland Australia
    E36 M3
    Have an E36 M3 in Australia. The car recently stopped firing on no2
    Put another coil and plug on and no change.
    Have run multimeter tests on idle and get the 12v positive to negative (on plug) 13.6v
    When I tested signal on no 2 gives about 230mv to negative on plug. A working cylinder plug gives about 136mv at idle. I know this not a great technique but just wanted to check it wasn’t an open circuit
    There has been signs of an animal living on the motor but no obvious cable damage. I would have thought a rat eating a cable would give an open circuit
    The car has only done just over 50kkm so is very young.
    Any thoughts appreciated
    Oct 2023
    Co Louth, Ireland
    1996 M3 Evo saloon
    Rats like the plastic, not the wire. So they're more likely to cause shorts than open circuits.
    Could be fuel too though. Have you tried a noid light on the injector?
  1. S50B32 Carbon Fiber Coil Cover
    By nxhans in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 07-07-2015, 08:29 AM
  2. S50B32 Euro + AEM FIC8 = injector faults ....
    By Will74 in forum Forced Induction
    Last Post: 09-12-2012, 09:06 PM
  3. Ignition Coil Fault Code Help
    By 97redsled in forum 1991 - 1999 (E36)
    Last Post: 03-21-2012, 12:36 AM
  4. ignition output transistors faults, s50b32 misfiring
    By Maleckis in forum 1994 - 1999 Euro M3 (E36)
    Last Post: 11-16-2010, 03:55 AM
  5. Replies: 64
    Last Post: 12-22-2009, 12:00 PM
