Results 1 to 8 of 8
Thread: 2000 bmw e38 740i sport
    Mar 2024
    Uk
    E38 740i 1/15- E53 4.8is
    Hey guys I am Ricky and a proud owner of my beloved e38 1/15 mora Metallic search E38MOB on Instagram it’s all around on there.
    This is my first post
    E38 running rough since last summer. The car runs rough and shakes
    It is a show car / weekend car so just this week got time to fix it. Thought it would be something small but I was wrong
    Replaced:
    OEM coils
    NGK plugs
    OEM Cam position sensors
    It’s had a full over haul on the cooling chain guide vanos units most of the car has been replaced by oem parts about 1000 miles ago
    Took out the 3-4 ignition coils while running and didn’t make any difference showing they are not working
    Checked all wires to the dme unit no cuts no burns
    Dme is dry and connections clean and dry no corrosion
    Could it be the dme unit internally ?
    I am
    Hoping timm will be able to reply as he is a legend here in the uk
    Thank you all in advance
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Welcome here. Are there any codes?
    Mar 2024
    Uk
    Quote Originally Posted by Mayorchuck View Post
    hey there
    thank you. I did have my friend mechanic come and plug the car up I will try get the codes up today
    as far as I understand it was one of the cam shaft sensor that was flagged.
    we changed them both for oem ones from bmw
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Did the trouble start after the timing chain guides were done? If you can pull coils with no change in how the engine is running, you should have current codes. We really need those details to help you further.
    Mar 2024
    Uk
    hey mayourchuck
    the fault code
    3e misfiring at several cylinders
    22 function inlet camshaft control bank 2
    Feb 2009
    KC North, MO, USA
    1996 740iL
    I strongly suggest you recheck your timing. Did you do this work yourself?
    Mar 2024
    Uk
    no I got it done by someone who specialises in e38s bmw here
    in the uk. I Will get the car sent to him. I will send the dme off today £45 if they don’t find a issue not much to loose
    yesterday we checked continuity of all the plugs /injectors seems fine
    thank you for all your help mayorchuck
    Aug 2015
    california
    1996 BMW 740il
    Not sure if you found the answer but I just went through this exact same thing with my e38. Mines a 2001 740i. Bank 1 was dead, only running on cylinders 5-8. Found the bolt that holds the camshaft in had come undone cam wasn’t spinning with the engine causing the multiple cylinder misfire. Retimed the motor and now running on all 8 again.
  1. Replies: 0
    Last Post: 10-14-2023, 06:19 AM
  2. 2000 BMW E38 740i M Sport (Timing Chain Guides Job Completed)
    By Reflex in forum BMW Cars For Sale / Wanted
    Last Post: 01-16-2023, 03:18 PM
  3. Replies: 0
    Last Post: 12-05-2014, 04:43 PM
  4. Replies: 7
    Last Post: 12-07-2011, 09:13 PM
  5. 95-01 BMW E38 740i 740IL 750IL M-Sport Oval Rear View Mirror
    By MaximilianVO in forum Exterior Lighting & Body Parts
    Last Post: 07-22-2008, 05:39 AM
