Heres the short story. My 95 325i needed it's front left wheel speed sensor replaced. So today I had it done. The sensor being out had caused my ABS and ASC lights to come on and obviously both were not working again because the sensor needing replacement. So once the code was rechecked today and the sensor replaced it says the codes are cleared and there is no sensor code but the lights will not go out in the cluster therefore the ABS and ASC still not working. It is giving one code though " non identified " whatever that means???
We have done the following:
1. Tried resetting via BMW tool/software
2. Disconnecting battery
3. All associated fuses ( 5 )
I need opinions badly.
