so i have an m50b25tu single vanos from 1995 e36 325i that im trying to build for forced induction. after doing some research i believe the rod length on the vanos version m50 are 140mm i was wondering if i could use 135mm rods and of course i would use pistons that are spec for 135mm rods but im just not 100% sure if that setup would be compatible with my block? in other words using 135mm rods and pistons instaed of the stock 140mm rods and pistons? how would this setup affect my compression if it does?
