Results 1 to 6 of 6
Thread: Fuse 48
    Nov 2013
    Southeast
    Fuse 48
    Chasing a non working hvac blower motor on a 1997 328. I replaced the blower motor and it still won’t work. It does work if I supply voltage at the blower resistor. Fuses are good, relays are good, but I cannot find fuse 48 that is supposedly under the driver kick panel somewhere. Anyone have a better idea where to find it?
    Jan 2005
    Japan
    11/88 E32 750iL
    Fuse 48 on 1997 328 is in relay panel under LH side of dashboard, along with the crash control module, high beam light relay, see page 0670.0-01 , more details in section component location views http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    In the link that Shogun provided, the Aux Fuse Panel is found on Page 17 of his link, the diagram shows a relay panel with 5 relays, F48 is attached to the outboard edge of the panel.
    Furthermore, the Bentley manual says,
    The panel is located next to the steering column under the driver's side dashboard. Remove the dash panel then the knee bolster, lower the relay panel by releasing the retainers.
    Yonkers N.Y.
    1999 BMW M3 Convertible
    Quote Originally Posted by JDStrickland View Post
    I’m in the same boat. Can’t fine fuse 48 under the dash for the life of me. Still haven’t. I’m starting to believe it’s not there. We need pictures of its location.
    Jan 2005
    Japan
    11/88 E32 750iL
    here is a video BMW 318i 1997 Location of radiator fan fuse 48 https://www.youtube.com/watch?v=bmEw0Cxvqas
    https://knigaproavto.ru/shemy/en/bmw...x-diagram.html
    Z3 - The Legendary Fuse #48 sighting https://www.bimmerforums.com/forum/s...se-48-sighting
    interesting, here for a Z3, fuse 48 yes or no depends on the engine, 4 or 6 cylinders, maybe same on E36? see almost at the end of the video https://www.youtube.com/watch?v=qhJ4HjbgRBk
    Nov 2013
    Southeast
    I never found fuse 48. Issue was a faulty blower resistor which had me stumped because I’ve always seen them fail with certain speeds, but still work on full speed. I also was getting 12 volts at the blower motor connector.
  1. Fuse #48 sighting
    By dabigboy in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-04-2017, 12:06 PM
  2. Fuses 48 and 49 (Aux. fan and ABS/DSC)
    By Noname100 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-13-2013, 04:48 PM
  3. Location of fuse #48 in 97 328i
    By cerizoman1 in forum 1991 - 1999 (E36)
    Last Post: 12-10-2012, 05:36 PM
  4. Replacing Fuse 48 on a 97 318i
    By Leeky4 in forum 1991 - 1999 (E36)
    Last Post: 04-03-2012, 03:56 PM
  5. '02 Z3 location of fuses 48, 49
    By Land in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-14-2008, 12:53 PM
